Valve Cover Vent Blocking? Cylinder Tins?
one4house
one4house is offline
PostPosted: Tue Jun 18, 2013 2:21 pm    Post subject: Valve Cover Vent Blocking? Cylinder Tins? Reply with quote
1915, Engle 120 Cam, Stock heads and 34 Pict 3 carb
The valve cover vents are blocked off with caps and the caps held on with hose clamps.
This does not seem right to me. What is the proper way that this should be done?
Should I have the valve covers vented or not?
My Old 64 Field Find
My Old 66 Squareback
My Old 66 Beetle
My Old 70 Squareback
mark tucker
mark tucker is offline
PostPosted: Tue Jun 18, 2013 2:25 pm    Post subject: Reply with quote
vent them.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jun 18, 2013 2:30 pm    Post subject: Reply with quote
If you don't need them vented... leave them alone.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
slalombuggy
slalombuggy is offline
PostPosted: Tue Jun 18, 2013 2:36 pm    Post subject: Reply with quote
You have a 120 cam so you are going to spin the motor. Vent the right side cover. If the vent tubes are threaded into the valve cover, you can buy a pipe plug to fill the hole instead of the capped tube on the left side. Clean hte threads in the cover good and loc-tite the plug in
brad
Mr. 010
Glenn is offline
PostPosted: Tue Jun 18, 2013 2:46 pm    Post subject: Reply with quote
brad
Not sure how much spinning it will do.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
one4house
PostPosted: Tue Jun 18, 2013 3:17 pm    Post subject: Reply with quote
Here is what I found when I jacked it up. There is a lot less leaking than I was expecting. It puddles a little in the garage, but I do not see anything excessive under the car.
I am guessing you only need to vent if you have a problem with leaking?
My Old 66 Beetle
one4house
PostPosted: Tue Jun 18, 2013 3:20 pm    Post subject: Reply with quote
Aren't there some tins missing from the bottom of the cylinders? Wouldn't they affect cooling?
My Old 66 Beetle
mxracer
mxracer is offline
PostPosted: Tue Jun 18, 2013 3:35 pm    Post subject: Reply with quote
Yes, the under cylinder or "sled" tins are missing and they affect cooling.
They probably left them off because of the way the j-tubes are routed.
slalombuggy
PostPosted: Tue Jun 18, 2013 5:54 pm    Post subject: Reply with quote
Glenn wrote:
brad
Ya, guess I missed the heads and carb size. You'll be fine without them if you don't want to. You'll run out of air before rpms......
brad
