T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1509 Location: Deep South of the Great White North
Posted: Wed Jul 24, 2013 7:25 pm Post subject: Stub axle Speedi Sleeve Repair |
Just finished another speedi sleeve repair on a pair of Vanagon rear stub axles and remembered to take some pictures. Ipad camera, so not crystal clear, but you can see the wear rings and general pitting on the counter-face on the axle on the right in the top image. That was after cleaning it up in preparation for the sleeve installation. Completed install on the left hand axle in the same image.
These things are simple to install and provide a better than new seal counter-face.
_________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19111 Location: Retired South Florida
Posted: Thu Jul 25, 2013 6:48 am Post subject: |
| Pictures are helpful, the part number would be too. Thanks for posting. |
Posted: Thu Jul 25, 2013 6:55 pm Post subject: |
I used sleeve 99187.
Needed to trim 4 mm off the top after install and carefully chamfer the top edge so that it would not damage the seal when installing.
Good Luck. _________________ 1988 Vanagon
Posted: Fri Jul 26, 2013 5:49 am Post subject: |
| Bookmarked. Thanks for the research and result. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5951 Location: Bemidji, MN
Posted: Thu Nov 30, 2017 1:03 pm Post subject: Re: Stub axle Speedi Sleeve Repair |
does anyone know if the dimension of the output shaft flange that enters the transaxle change between years or transmission types? i've got some auto trans stubs i could measure to double check this PN but the Speedi Sleeve will go on manual stubs.
after i rebuilt the transaxle i had a disappointing output flange drip. i know my axle flanges had a slight groove but i thought i could get by with it. appears not.
i DID do a Speedi Sleeve on my crank pulley and that came out great!
-dan |
Posted: Fri Dec 01, 2017 7:10 am Post subject: Re: Stub axle Speedi Sleeve Repair |
Dan, I think the drive flanges in the above thread are the outer ones, but it's not clear.
First step would be to compare the seal dimensions of the auto and manual transaxle seals. I don't know the answer to your question. It sounds like you can't have the van down while you wait for sleeves and seals. It's a little more labor, but you could drop one cv, remove one flange, and measure. Then put it back together while you search for and order sleeves and seals. |
Posted: Fri Dec 01, 2017 7:30 am Post subject: Re: Stub axle Speedi Sleeve Repair |
that's the safest way, Mark! i can have the van down for a long time, just don't like tying up my single car garage/shop. it'd be nice to find a sleeve that didn't require trimming, as i know that never ends up with a perfect edge.
i'm always amazed at how purty the seal surface is after installing a Speedi Sleeve. nice product. my 87 2.1 had a sleeve put on the flywheel seal surface and when i tore it apart, it was still in great shape. very hard metal.
-dan |
T3messie Samba Member
Joined: October 03, 2017 Posts: 215 Location: Germany
Posted: Fri Dec 01, 2017 8:06 am Post subject: Re: Stub axle Speedi Sleeve Repair |
| SKF 99177 will work. |
Posted: Fri Dec 01, 2017 8:18 am Post subject: Re: Stub axle Speedi Sleeve Repair |
do you know if that PN required trimming on the outer edge?
-dan |
Posted: Fri Dec 01, 2017 8:24 am Post subject: Re: Stub axle Speedi Sleeve Repair |
I don´t know what you mean with "outer Edge".
You can peel away the tear off, but you don´t have to.
The length is perfect. |
Posted: Fri Dec 01, 2017 8:29 am Post subject: |
| T3 Pilot wrote: |
Good Luck. |
good to know PN 99177 is the correct length!! thanks for the PN.
-dan |
bub0815 Samba Member
Posted: Mon Mar 02, 2020 11:53 pm Post subject: |
| T3 Pilot wrote: |
Good Luck. |
Hi there,
I know it's some time ago but I hope T3 Pilot is still acitve here.
I've just registered to raise that question. I'm from Germany and just working on a Vanagon Multivan built in 88. Unfortunately my rear stub axles looking similar so I'd like to do the same reapair using speedi sleeves.
I took the measure just to double check prior ordering sleeves 99187.
Taking the measures and browsing the SKF documentation fo the speedi sleeves, 99187 is to tight. It's supposed to work from 47,55 to 47,70 mm.
Unfortunately the next size (99189) is supposed from 47,93 to 48,08 mm.
In addition I'm asking myself how you managed to install the sleeve with the stub in the way. Have you drilled a hole in the SKF tool or used something else (e.g. a metal tube)?
Your help would be appreciated. Thank you in advance and best regards from Germany.
Tobias |
Posted: Tue Mar 03, 2020 4:51 am Post subject: Re: Stub axle Speedi Sleeve Repair |
| I just did this repair on my Syncro. The part number listed above did not require trimming and was a snug fit. I used a piece of tubing I had laying around the shop to drive it on. I used a film of loctite bearing lock to ensure it sealed. |
Posted: Tue Mar 03, 2020 2:47 pm Post subject: Re: Stub axle Speedi Sleeve Repair |
Thank you for the response. I'm still confused why the size fits in contradiction to the SKF manual but I've just ordered a pair . |
WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 172 Location: Canada
Posted: Mon Jul 14, 2025 6:50 pm Post subject: Re: Stub axle Speedi Sleeve Repair |
Reviving an old thread to contribute to the community wisdom.
I just did my project vehicle's rear axle stub seal surface repair.
If you bottom it out upon installation, Speedi Sleeve # 99184 fits perfectly - no cutting or adjustments.
On the top photo, you can see where the seal's contact was, just before the corrosion starts, about a third down from the top of the flange, the narrow shinny band. The bottom band is likely a combination of corrosion and mechanical wear.
I used the bottom end of an old windsurfer mast as a tube to drive it in place.
W _________________ Science has sacrificed Truth on the altar of its narrative. |
Posted: Wed Jul 16, 2025 8:38 am Post subject: Re: Stub axle Speedi Sleeve Repair |
| WiboBusMan wrote: |
Thank you for updating this thread. |
