091/1 output flange refurb - Speedi Sleeve
DanHoug
DanHoug is offline
PostPosted: Sun Jan 20, 2019 5:05 pm    Post subject: 091/1 output flange refurb - Speedi Sleeve Reply with quote
i had some dripping from the output flange area of my transaxle from my 87 4 spd. turns out, it was the rubber seal on the flange had popped loose but i decided to put Speedi Sleeves on the shaft sealing surface anyway to eliminate that variable after 235k miles. SKF pn 99177 fit very well. i left the flared driving surface installed instead of trimming it off as i've had some that tear off and raise and edge. it makes a nice surface anyway. sleeve is sealded to the shaft with Kuril K2 but is such a tight stretch fit anyway i don't think anything would ever leak thru. SKF wanted sealer on it.
first, the flange seal surface:
Speedi Sleeve installed:
SKF part number:
-dan
www.thefixitworkshop.com
MarkWard
MarkWard is offline
PostPosted: Mon Jan 21, 2019 12:42 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Dan, thanks for posting. I bookmarked it just incase I need to find those part numbers someday.
T3 Pilot
T3 Pilot is offline
PostPosted: Mon Jan 21, 2019 1:43 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Another tool for the toolbox:
SKF has a free app that helps to hone in on the correct sleeve size required
SKF Seal Select by SKF
I’ve installed speedi sleeves on stub axles a couple of times and the results have been good. What do you guys think about fitting a speedi sleeve onto the sealing surface of a 2.1 flywheel?
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
DanHoug
DanHoug is offline
PostPosted: Mon Jan 21, 2019 2:19 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
done it twice. i had one installed on the sealing surface of the flex plate of an autotrans on a Weekender i had. dealer had replaced the seal only the first time, leak continued. then did the Speedi Sleeve which greatly reduced leakage but ultimately i think i was dealing with high crankcase pressure.
then, had one put on the flywheel of my 2.1 and that worked perfectly. this was all before i did my own work (and had a place to work on it). still have the flywheel, wasn't usable for a core but the sleeve is perfect yet. very hard surface.
-dan
DanHoug
DanHoug is offline
PostPosted: Mon Apr 01, 2019 2:55 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
just an update... 600 miles on the SpeediSleeve and a dry transaxle and consequently, a dry garage floor. you can see from my first photos that it didn't take much of a groove to have seepage. pretty chuffed because every VW i've had has had a drop hanging 'down there'.
-dan
Westaru
Westaru is offline
PostPosted: Wed Jul 31, 2019 8:26 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
DanHoug,
Thanks for this post! I did CV joints, seals, and the works a few weeks ago and still had a drip. Installed the speedi sleeves you posted above with Permatex high temp sleeve retainer (as well as the anerobic activator) and I'm finally drip free in my van.
Mine is an '84 2wd FWIW.
1984 Vanagon Westfalia EJ22
tencentlife
tencentlife is offline
PostPosted: Thu Aug 01, 2019 6:16 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
I need to do these. I've looked around and the sleeves are hella expensive. Dan, did you find a source for them with decent prices?
T3 Pilot
T3 Pilot is offline
PostPosted: Thu Aug 01, 2019 6:24 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
I ordered the last pair from rock auto; if that helps
1988 Vanagon
ARMc
ARMc is offline
PostPosted: Thu Aug 01, 2019 6:31 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
I've done this before on drive flanges with good success. The brand I've used is Shaft-Eze by Dichtomatik. The local bearing supply company had them on hand and for the time it saved they didn't seem crazy expensive. Maybe at most $15-20 each. I'm not sure where I put the part number for the ones that fit the drive flanges... You can always figure it by measure.
DanHoug
DanHoug is offline
PostPosted: Thu Aug 01, 2019 6:32 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
i bought them from Amazon in 2017 for $29 each and i see the same PN is now about $31 each. still drip free, not leaving a single mark on the garage floor.
-dan
tencentlife
PostPosted: Thu Aug 01, 2019 7:00 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Thanks guys. Last time I went looking the prices were in the over-$30 range, actually that's well below list, and I'm not a cheap bastard, but it seems a lot to pay for what it is, especially since I need two. Luckily all the manufacturers use the same p/n on these so it's easy to search. I just found them on ebay, SKF brand, for $21.70 ea., plus $10 shipping. Ordered up. Here's the link if anyone's looking.
https://www.ebay.com/itm/392308290405
Steve Arndt
Steve Arndt is offline
PostPosted: Wed Aug 21, 2019 3:34 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Does the standard seal get used still, or is the ID of the seal ordered smaller to compensate for the sleeve?
Steve
Steve's 87 Syncro project
DanHoug
DanHoug is offline
PostPosted: Wed Aug 21, 2019 3:44 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
standard seal. but you can feel the edge of the sleeve sorta catch on the seal and it requires a good push to insert. but Speedi Sleeves are all thin enough to use the standard seal.
-dan
Gizmoman
Gizmoman is offline
PostPosted: Wed Aug 21, 2019 9:28 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
The "value" of the sleeve is what it provides, not the simplicity of the design or cost of manufacturing.
You buy a drill because you want a hole.
82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale).
erste
erste is offline
PostPosted: Tue Sep 24, 2019 9:21 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
DanHoug,
Thanks for posting this, and tencent, thanks for the link.
Any harm in using loctite as a sealer when installing? I looked up Curtil K2 and a tube is $20 and I'd probably never use it again.
I confirmed with the guy who built my transaxle that 091 CV cups are the same as 091/1 in case anyone else needs that info.
DanHoug
DanHoug is offline
PostPosted: Tue Sep 24, 2019 9:25 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Loctite should work fine. maybe i'd even use red. i used Loctite as a sealer for brass threaded fittings on espresso machines that would weep under hot water/steam. worked great, no drips.
-dan
Westaru
Westaru is offline
PostPosted: Tue Sep 24, 2019 9:36 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Loctite or Permatex sleeve retainer is the correct compound to use with a speedi sleeve:
https://www.permatex.com/products/thread-compounds...-retainer/
Be sure to buy the anaerobic activator compound as well (it is required):
https://www.permatex.com/products/thread-compounds...naerobics/
Steve Marshall
Steve Marshall is offline
PostPosted: Fri Jan 10, 2020 9:41 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
Does anyone have the part number for the speedi sleeve that works on the flywheel?
1988M5
1988M5 is offline
PostPosted: Fri Jan 10, 2020 7:55 pm    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
The “activator” you mentioned isn’t an activator at all, it’s simply a cleaning product. Brake clean, alcohol or gasoline would serve the same purpose giving enough time to dry. Point being is you want the materials being bonded to be completely pristine. I can only speak to Loctite brand stuff as that’s all we use at work but I believe they all have the same job in different ways. The 3 green Loctite grades we use is intended for the exact same purpose but with different use depending on tolerance (gap filling)requirements, heat too.
FYI
Brian
tencentlife
PostPosted: Sat Jan 11, 2020 8:17 am    Post subject: Re: 091/1 output flange refurb - Speedi Sleeve Reply with quote
These threadlocker products are anaerobic cure, as soon as you tighten the threads, slide a sleeve on or stuff a bushing, oxygen is excluded and the liquid quickly starts to harden. That's why when you use them on threads, you need to come right up to final torque and leave it alone, because it's starting to cure before you even move the wrench away and if you reposition anything you're just breaking the adhesion and not getting the full holding strength.
The surface activator is by no means "required", their own literature says so. The PDS says it's mainly a "basic copper salt", so it's likely similar to a soldering flux, it reacts to draw out and neutralise impurities, cleaning the surfaces to allow deeper adhesion of the product. If it enhances cure rate it's probably due to neutralisation of impurities that would otherwise mix with the adhesive. Judging by the warnings about oxygen reactability, I would guess it works the opposite of the adhesive, that it's activated by oxygen, that's why it's a spray.
