Thetrevornator Samba Member
Joined: February 21, 2013 Posts: 59 Location: Yuma, AZ
Posted: Sun Jul 28, 2013 8:16 pm Post subject: First Bus at 18yrs old 67 panel (pics) |
Hello samba!
I have been a long time lurker of the site for awhile now and a bus came up on my local classifieds and just felt like I had to snatch it right up!
First off let me tell you I am really into photography so there will be plenty of pictures in this build thread.
Plan to get it running and stopping and have a running project as it goes along. I will be enrolled in three Classes that i can use the welding shop at my school to do any body work I need to get done. That adds up to about 15hrs a week. last thing EVERY one at my school knows I am into old vws note my school is about 300 kids. So Everyone is very excited for me that I finally got a bus.
Enough about me now about the bus!
It is a pearl white 67' panel that had windows hacked into it and rear wheels cut and couple previous owners started the resto but I will be the final holder of this beloved bus! I guess it came from Northern AZ before the guy that i got it from so any history would be awesome!
Plan to use it as small advertisement for my photography business and an ICON.
lower rust needs done. any sugestions?
front floor never finished being put in. should i cut to fit make it work or replace full floor instead of 2 sides
some rewire in the near future
FREE CANDY
Any sugestions on finishing the windows new metal redo what?
I for see a new cargo floor
circle in bulkhead cut out for something? any ideas?
it pays for itself
I Made a shift knob out of an old camera lens to fit my taste.
I will be updating as it under see's changes
Will be slow but I am sure i will have the pictures for you.
Very open to any ideas!
Thanks
-TREV _________________ 67 Panel Camper and a 64 OG ratty bug
"Life's a Journey"
http://instagram.com/dubtrevornator/ |
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Sun Jul 28, 2013 8:32 pm Post subject: |
| Congrats on the bus. I'm glad to hear that you want to get it running and driving and then do some of the cosmetic repairs as time goes along. Take advantage of the school shop. Its nice to have the space and equipment to do the work especially as a student. Good luck with the project. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26291 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 28, 2013 8:45 pm Post subject: |
Need to loosen up the axle boots and rotate 90 degrees.
Nice shift knob, but suggest getting the stock knob on it. Heavier shift knobs like that will wear out the shift forks in the transaxle.
Try Bustoration.com for the sheet metal.
Would depend on how bad the rest of the front floor is... _________________ In Stereo, Where Available! |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2694 Location: Phoenix AZ
Posted: Mon Jul 29, 2013 7:55 pm Post subject: |
I know that bus. It was pulled from the sierra vista area by a guy named nate about 5 years ago then sold to a justin which is whom I am assume you bought it off of _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
EmpiGT Samba Member
Posted: Mon Jul 29, 2013 8:36 pm Post subject: |
| From where I sit the cargo floor doesn't look too bad. Patches would be much faster and money saving. It might be worse than the pics show. Show some inner pics of the hacked in window sheet metal. If they used real donor pieces and they have the inner support rib installed I would just finish out what they started. If it doesn't have the inner support rib it might be better to start with correct donor metal cut from a panel or new metal from klassic fab. |
EmpiGT Samba Member
Posted: Mon Jul 29, 2013 8:47 pm Post subject: |
This bus had 3 windows cut into this side. I welded in donor metal from a parts panel bus. You can see the inner supports. If yours doesn't have the supports iI would redo them. The supports will help the long panel from dishing and warping over time. |
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Mon Jul 29, 2013 9:45 pm Post subject: |
| Congrats on your bus. I think it is totally cool that you are 18 and taking the bull by the horns and bought an automobile that is a passion for you.....Good luck on your bus and journey.....Looking forward to more pictures and updates. |
Joxracing Samba Member
Joined: July 27, 2008 Posts: 88 Location: Marquette Mi. In da u.p eh.
Posted: Mon Jul 29, 2013 9:54 pm Post subject: |
Cool bus! Im 19 and having a blast with my first bus as well... _________________ 1966 Baja Bug
1963 Single Cab
1979 F150 TORC Off-Road truck
1996 Ford Bronco |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7125 Location: Lawrenceville, Ga
Posted: Tue Jul 30, 2013 7:22 am Post subject: |
| Eric&Barb wrote: |
Would depend on how bad the rest of the front floor is... |
looks like your cargo floor just needs a patch, front floor outers look like the way to go, you already have them...
i see some rocker repairs in your future, which will give you opportunity to patch your cargo floor on the driver side.
fix the wiring, so you don't set thing on fire when you install the motor. (gotta get one of those) _________________ regards
Uli
Cuñado Wear Samba Member
Joined: December 10, 2006 Posts: 1145 Location: The "O"
Posted: Tue Jul 30, 2013 8:56 am Post subject: |
| mandraks wrote: |
| Eric&Barb wrote: |
fix the wiring, so you don't set thing on fire when you install the motor. (gotta get one of those) |
x2 the only other thing i would add or suggest is go get some 3/4" plywood and put it under your jack stands for a better and safer base.
congrats again. _________________
| Bulli Klinik wrote: |
| I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
63’ ez-camper
63' 15 Window Deluxe
65’ Notchback |
Posted: Tue Jul 30, 2013 11:51 am Post subject: |
| sub-hatchtim wrote: |
| I know that bus. It was pulled from the sierra vista area by a guy named nate about 5 years ago then sold to a justin which is whom I am assume you bought it off of |
I got it from a guy named patrick. he must of got it from justin? _________________ 67 Panel Camper and a 64 OG ratty bug
"Life's a Journey"
Posted: Tue Jul 30, 2013 11:53 am Post subject: |
| Cuñado Wear wrote: |
| mandraks wrote: |
| Eric&Barb wrote: |
congrats again. |
So do you mean full new wiring loom or just fix what is there all the wires in front and engine bay seem to be old and cracking. _________________ 67 Panel Camper and a 64 OG ratty bug
"Life's a Journey"
Posted: Tue Jul 30, 2013 11:59 am Post subject: |
| EmpiGT wrote: |
I didn't notice that well looks like i will be finding correct metal to replace windows. whats your opinion on the wheel wheels?
"Life's a Journey"
Posted: Tue Jul 30, 2013 1:26 pm Post subject: |
wheel wells look good from a mile away.
as far as wiring goes, better is always better, but, knowing myself, i would probably try to fix it first, though.
cargo door hacks look "serviceable". on the panel i would probably make some improvements. _________________ regards
Uli
Posted: Tue Jul 30, 2013 6:14 pm Post subject: |
You should consider whether or not to put windows back in the cargo doors (see the classifieds for panel camper windows that will fit the hole size) or get kombi cargo doors with the windows in them. For a young inexperienced driver not having windows there makes for a real big blind spot that can be hazardous, even with a mirror on the passenger side door hinge. _________________ In Stereo, Where Available! |
Posted: Thu Aug 01, 2013 10:26 am Post subject: |
| EmpiGT wrote: |
think i can just put those supports in or would you think still trying to find bus cut outs with them? like these?
http://www.thesamba.com/vw/classifieds/detail.php?id=1432910 _________________ 67 Panel Camper and a 64 OG ratty bug
"Life's a Journey"
easy e Samba Member
Joined: May 28, 2008 Posts: 3941 Location: 1 hr north of Santa Barbara
Posted: Thu Aug 01, 2013 2:41 pm Post subject: |
The part from your classified link would work for the doors and horizontals of the long panel... but not the vertical on the long panel.
_________________ aka: Evan
“They are about as worthless as the tits on the boars that live in the woods behind their junk yard.” -Weatherly |
69vwcarl Samba Member
Joined: September 14, 2008 Posts: 138 Location: midland michigan
Posted: Fri Aug 02, 2013 2:09 pm Post subject: |
| NOT trying to be rude but welding in the panel windows is a very tricky JOB !!!! tons of tack welds making sure your heat does not warp the panel a butt weld on a sheet steel panel like that is for an experienced welder. SO get some help before you attempt that fix or it could end up BAD. looks like a good Project!!!! |
Posted: Tue Sep 17, 2013 8:52 pm Post subject: |
I Just got a part time job. so hopefully will have it rollin n going in a few months!
Update i got a front bumper dirt cheap just needs a little elbow grease to get top bar straitened out _________________ 67 Panel Camper and a 64 OG ratty bug
"Life's a Journey"
Posted: Tue Dec 23, 2014 3:39 pm Post subject: |
since its been almost 2 years since i have posted here.
I am alot more active on my instagram
go ahead and creep my profile on there see how its come along!
http://instagram.com/thetrevornator/
Thanks
"Life's a Journey"
