1835 Single port build!
Matthew
Matthew is offline
PostPosted: Wed Jul 31, 2013 12:21 pm    Post subject: Reply with quote
What's the valve job like? A three angle would help flow.
1965 Beetle sedan
Click to view image
JRKman
JRKman is offline
PostPosted: Wed Jul 31, 2013 3:38 pm    Post subject: Reply with quote
3 angle Smile
1969 Type I
House paint red
1835cc single port:
Scat C25, ICT's, SVDA
Matthew
Matthew is offline
PostPosted: Wed Jul 31, 2013 5:10 pm    Post subject: Reply with quote
It's gonna be sweet. I don't care what any of the Single Port haters say.
1965 Beetle sedan
Click to view image
Quokka42
Quokka42 is offline
PostPosted: Wed Jul 31, 2013 5:26 pm    Post subject: Reply with quote
Haters gonna hate.
There has only ever been one man who was perfect, and they nailed Him to a cross.
JRKman
JRKman is offline
PostPosted: Wed Jul 31, 2013 8:58 pm    Post subject: Reply with quote
I'm pretty stoked.
So it's looking like its cheaper for me to just buy a set of 8 1.25 rocker arms. What's the benefit of only running them on the intakes? If I have 8 shouldn't I just run them all?
-Josh
1969 Type I
House paint red
1835cc single port:
modok
modok is offline
PostPosted: Wed Jul 31, 2013 9:20 pm    Post subject: Reply with quote
I don't recall how much lift a c-25 has anyhow, but if it is less than .450 with the 1.25 then shoot, run em all.
JRKman
JRKman is offline
PostPosted: Wed Jul 31, 2013 9:40 pm    Post subject: Reply with quote
.365" with 1.1:1 and .415" with 1.25:1
What is the purpose of running them on intakes only anyways?
-Josh
1969 Type I
House paint red
1835cc single port:
modok
modok is offline
PostPosted: Wed Jul 31, 2013 9:49 pm    Post subject: Reply with quote
Well, you can have different reasons... but, usually in most engines, the intake valve is bigger so it has more lift.
Specific to the VWs, some heads have too much exhaust flow in comparison to intake, so you can dial it back a little with the rockers. And while running extra lift won't usually hurt power much, more lift wears out the guides faster, and you know the exhausts usually wear twice as fast as the intakes.......so there is that too.
JRKman
JRKman is offline
PostPosted: Wed Jul 31, 2013 10:43 pm    Post subject: Reply with quote
Alrighty so you'd just run 1.25's all around with .415" of lift?
1969 Type I
House paint red
1835cc single port:
ralf
ralf is offline
PostPosted: Wed Jul 31, 2013 11:34 pm    Post subject: Reply with quote
engle w100 lift @ valve is 0.420" (most of the time 0.418")
engle w110 lift @ valve is 0.430" (most of the time 0.424")
and thats been run/used on alot of stock sized valve heads
from small 1776cc to slightly big 1900-2000cc range bus motors
generally working well, the valvejob and portwork would dictate that
so, with your cam
and SP , seeing you have a decent 3 angle valve job etc
0.415" would prolly be something your heads can take advantage of
the cam is smaller in duration vs the 2 mention cams above
prolly helps in giving you a smooth idle
+ you compensate on more lift, with the lesser duration (valve curtain area)
so as modok says, i think running both would be ok.. if not great! Smile
Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk
Quokka42
Quokka42 is offline
PostPosted: Wed Jul 31, 2013 11:42 pm    Post subject: Reply with quote
Yeah, the exhaust valve is lighter and stainless valves don't lose their heads as easily as the stock ones any way. The different rocker idea comes from Harleys, where the valves are canted toward each other so you have to avoid them hitting.
JRKman
JRKman is offline
PostPosted: Thu Aug 01, 2013 12:19 pm    Post subject: Reply with quote
Awesome sounds like il be running 1.25's all around then.
1969 Type I
House paint red
1835cc single port:
catbox
catbox is offline
PostPosted: Thu Aug 01, 2013 1:09 pm    Post subject: Reply with quote
JRKman wrote:
Looks like I'm gonna have to wait a few weeks for my case to be ready. What can I do while I wait for the case. Can someone teach me how to use Emory cloth so I can polish the journals and assemble the rods to the crank?
-Josh
If you used Steve's Machine Shop, I think he does the polishing while it is there. At least he did on mine.
I would call and check on it before doing anything to them.
Cool
"...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume.
JRKman
JRKman is offline
PostPosted: Thu Aug 01, 2013 1:54 pm    Post subject: Reply with quote
Oh that'd be nice. I pick everything up on Monday so we'll see if its done already.
-Josh
1969 Type I
House paint red
1835cc single port:
JRKman
JRKman is offline
PostPosted: Tue Aug 06, 2013 11:30 am    Post subject: Reply with quote
Got my stuff from balancing today. I had a very good experience through mikes precision machine so if you need balancing I do recommend him. I asked about polishing the crank and he gave me a worn out belt to use for polishing which I thought was pretty cool. I also resurfaced the flywheel while I had it there. Total came out to be $157.
1969 Type I
House paint red
1835cc single port:
bvilletom
bvilletom is offline
PostPosted: Tue Aug 06, 2013 4:54 pm    Post subject: Reply with quote
I have been following this single port motor build for some time now. I have built several single port engines in the past 4 years, some for Bonneville racing & the rest for a VW baja Ariz desert exploring & prospecting car. For the desert car low end torque & smooth reliable operation are most important. The last desert motor was just a 1600 (69x85.5) with a real 8.5 compression ratio. And .040” deck stock cam with Hoover mods, with fully ported single port heads with no step, with a real Solex 30 PICT 1 blueprinted off road carb and EMPI exhaust. Also I used the heaviest 200mm flywheel I could find, it smoothes out the low rpm for rock crawling on tough trails.
I think the single port heads are greatly underrated for performance and can be made to perform very well. I have a Super Flow bench and have been modifying heads for many years. Most singleports can be made to flow equal to or better than stock dual ports, it’s about port shape, valve shape, and attention to detail. I will try to print out some result sheets with this post of last winter’s single port heads. More later on my current 1835 single port build.
Enclosed is a picture.
bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction
tobiism
tobiism is offline
PostPosted: Tue Aug 06, 2013 5:05 pm    Post subject: Reply with quote
Sounds really cool, I would love to see more!
"There has never been a genius without a hint of madness."
-Albert Einstein
JRKman
JRKman is offline
PostPosted: Wed Aug 21, 2013 4:52 pm    Post subject: Reply with quote
So I feel like installing the rods to the crank while I wait for my case. Anyone care to give me a step by step on the connecting rod install? Is it as simple as putting the bearings in, lubing and installing on crank? What measurements should I be taking?
-Josh
1969 Type I
House paint red
1835cc single port:
Quokka42
Quokka42 is offline
PostPosted: Thu Aug 22, 2013 1:39 am    Post subject: Reply with quote
Plastigauge the bearings. If it is a bit loose when torqued up, gently sand the mating edges of the bearing shells on a piece of sandpaper on a sheet of glass, clean well and try again until they are within spec. Then re-oil and assemble.
modok
modok is offline
PostPosted: Thu Aug 22, 2013 5:42 pm    Post subject: Reply with quote
Plastigauge and faith in the rods is about all you can do without a dial bore gauge.
Page 6 of 8
