Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL
Page: 1, 2, 3 ... 17, 18, 19  Next
xoo00oox
xoo00oox is offline
PostPosted: Thu Aug 29, 2013 7:05 pm    Post subject: Project Quattro-Syncro. 1.8t, 5speed, AWD, ABS,EDL Reply with quote
I have had a Syncro van sitting in my lot for many years, parked because of a broken transmission like many others out there waiting for the day the affordable syncro trans will come along.
I'm hoping to make it happen by attempting to use the very affordable, available, and reliable 01A transmission and front diff used in the Audi and B5 4motion Passat.
The engine I'll be using is the AEB 1.8t used in the Audi A4 and B5 Passats.
The wheel base of the Vanagon is 96.7", the Audi A4 is 103.0". The A4's with Tiptronic transmission had a driveshaft that was four inches shorter because the manual trans was shorter. If I use the shorter driveshaft, that will bring my front CV to rear CV length down to 99" or just 2.3" of the vanagon length. I believe the CV's will allow for that difference.
I'll first focus on making it drivable, then look into adding the ABS brake system from the Audi as well. The reason I want the brake system is more for the traction control than the antilock breaking. With this Quattro system, the brakes can grab a wheel that has lost traction so the wheel opposite it can drive or as Audi puts it, EDL (electronic diff lock).
Here is the Syncro being towed in the shop by our trusty "lot pusher" A6
This poor syncro has seen better days.
That's a 2001 inspection sticker, last time on the road was 12-13 years ago.
Andrew-
Syncroincity
Syncroincity is offline
PostPosted: Thu Aug 29, 2013 7:23 pm    Post subject: Reply with quote
I was gonna say something about the spelling, but I just got the joke... Laughing
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
shadetreetim
shadetreetim is offline
PostPosted: Thu Aug 29, 2013 7:36 pm    Post subject: Reply with quote
Geez, you sure know how to make a guy jealous.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Aug 29, 2013 8:11 pm    Post subject: Reply with quote
I'm as useless as testicles in a bra, but I'm all over this thread.
Casey--
'01 Weekender --> full camper
y u rune klassik?
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Aug 29, 2013 8:50 pm    Post subject: Reply with quote
Zeitgeist 13 wrote:
I'm as useless as testicles in a bra, .....
ha. Reminds me of an old joke, which I won't tell, b/c it involves the pope. The punch line is "viola solo".
Andrew, this post made my day.
I know you know what you're doing, but for me to envision things.....
In terms of the CV's, could one ballpark by measuring the angle at CV's on a lifted Syncro, and its' CV lifespan, against the 2+" difference? (or is it more like 1+" per set of axles?) ..... if that makes sense.
Way to rock the VW thing man.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
hans j
hans j is offline
PostPosted: Thu Aug 29, 2013 9:15 pm    Post subject: Reply with quote
Why not just have a propshaft shortened/lengthened to the exact length? All they do is cut out a section and weld it back together. That's what I am doing for my CV conversion. I'll be using a B6 propshaft with the center CV joint and carrier bearing, it's much lighter than the u-joint driveshafts.
Definitely looking forward to the conversion!
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
shadetreetim
PostPosted: Thu Aug 29, 2013 10:01 pm    Post subject: Reply with quote
Will you be using the Quattro rear diff in the front of the Syncro?
Tim Potts
'74 Jeep CJ5
xoo00oox
xoo00oox is offline
PostPosted: Fri Aug 30, 2013 2:32 am    Post subject: Reply with quote
'nut-
Looking at my blue van with the 2wd version of the same transmission, there is plenty of room to move the axles back a couple inches.
Hans-
I know that is an option, I always try to use stock parts when I can. I'm hoping if I plan ahead I won't need the expense or have to rely on someone else to get it done. Thanks for suggestion.
'Tim-
Yes, the Audi rear diff will be my new front diff.
Andrew-
chojinchef
chojinchef is offline
PostPosted: Fri Aug 30, 2013 6:18 am    Post subject: Reply with quote
Popcorn Popcorn Popcorn Popcorn Popcorn Popcorn
Gonna need lots of it for this thread.
LP
Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory.
danfromsyr
danfromsyr is offline
PostPosted: Fri Aug 30, 2013 7:14 am    Post subject: Reply with quote
This I have to see.. there's not alot of room up front and I'm curious to the fitment of the Trans with the Syncro fuel tank.
Andrew-
*subscribed
Abscate wrote:
insyncro
Banned
insyncro is offline
PostPosted: Fri Aug 30, 2013 7:17 am    Post subject: Reply with quote
Spacing the driveline for more wiggle room is not a huge issue...as long as everything is equally spaced.
Looking forward to your project Andrew.
Will this need to retain 14" wheels and stock tire diameter as well?
dixoncj
dixoncj is offline
PostPosted: Fri Aug 30, 2013 7:26 am    Post subject: Reply with quote
Could be a magical project.
rs4-380
rs4-380 is offline
PostPosted: Fri Aug 30, 2013 12:33 pm    Post subject: Reply with quote
so are you going to spin the engine backwards?
Dave
87 EJ25 Syncro GL
xoo00oox
xoo00oox is offline
PostPosted: Fri Aug 30, 2013 12:49 pm    Post subject: Reply with quote
yes, engine running backward.
xoo00oox
xoo00oox is offline
PostPosted: Fri Aug 30, 2013 4:37 pm    Post subject: Reply with quote
I was able to spend a few hours today on my syncro. I actually have very little syncro experience, almost all the vans that come here are 2wd. I had never dropped the front sub-frame from one before. It is really neat that in just a few hours even with very rusty hardware you can drop this down like this.
here is the Audi rear diff compared to the syncro front diff
and here is the Audi diff in place on the Syncro sub-frame
The axles just bolt right on! I measure the distance between the left and right CV flanges, there is only 1/4" difference in that the Audi diff is narrower. This is all very good news.
The next step is to pull the springs off the struts and wheel this back under my van and bolt the frame back up. by having the springs remove, I can still bolt the top of the struts on to the body to locate the suspension correctly and be able to easily move the suspension up and down as well as steer the spindles left and right to check for and see if I have all the axial movement I need from the CV joints.
Andrew-
SCP_Austin
SCP_Austin is offline
PostPosted: Fri Aug 30, 2013 8:16 pm    Post subject: Reply with quote
This is totally rad!
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
dobryan
dobryan is offline
PostPosted: Fri Aug 30, 2013 8:37 pm    Post subject: Reply with quote
Popcorn I love that you think of doing something and then just dive right in and make it happen. Looking forward to the results. Very Happy
Dave O
The Western Syncro build
Zeitgeist 13
PostPosted: Fri Aug 30, 2013 8:42 pm    Post subject: Reply with quote
This thread is moving too fast. Slow it down
Casey--
y u rune klassik?
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Aug 30, 2013 9:13 pm    Post subject: Reply with quote
Yeah, slow it down some - I'm dizzy! Based on the pace of this thread, someone with a vinyl sign cutter needs to already start making a Quattro nose sticker in the Syncro font, 'cause by the time you make it and mail it, he'll be driving this thing! Heh.
So will it be a "SynQuatt", or a "Quancro"? Either way, one of those front to rear Audi emblem fades along the lower doors would look great.
DougM
kirsplat
kirsplat is offline
PostPosted: Fri Aug 30, 2013 9:34 pm    Post subject: Reply with quote
I'd just call it SQuatt Very Happy
What an awesome project you've started here...
I'm really looking forward to watching this come alive!
86 Syncro|EJ253|Carat
Page 1 of 19
