Bus Front Floor Replacement
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Mon Sep 30, 2013 11:07 am    Post subject: Reply with quote
You are very welcome. This was something I was looking for two months ago when I decided to replace my floors. The only things I could find were bits and pieces of other peoples build threads, and the information on doing the floors was not very detailed.
Big Bill
Big Bill is offline
PostPosted: Mon Sep 30, 2013 2:07 pm    Post subject: Reply with quote
Yes ditto on the thank you Ken. Looks very nice and the thread itself has given me a few tips I will use. Could you post a few pictures of the area were the front part of the wheel well meets the floor, mine is going to need a little help there like yours did. Thanks again
kenshapiro2002
PostPosted: Mon Sep 30, 2013 5:09 pm    Post subject: Reply with quote
I did quite a bit of work in that area where the cancer had spread upward above the floor. I fabricated (and I'm a total rookie with metal) that few inches in a few places. In retrospect, I might have bought some funky green seat pedestal parts because of the contours. As it is, I'm pretty happy with the work I did in there. I'll post something tomorrow.
&Dan
&Dan is offline
PostPosted: Mon Sep 30, 2013 6:37 pm    Post subject: Reply with quote
Aces! Nice job.
kenshapiro2002
PostPosted: Tue Oct 01, 2013 8:00 am    Post subject: Reply with quote
Bill, your best avenue is to check out this other thread of mine where I was doing my first welds ever. On pages 2 & 3, you can see examples of where I patched up that area, and also where another member, gave up doing it that way and patched in some Gerson pieces:
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
kenshapiro2002
PostPosted: Tue Oct 01, 2013 8:03 am    Post subject: Reply with quote
Just HAD to prime and paint a little...just to sooth my soul and give me a great big freakin' smile. Still need to do some small "finishing " patch work to make it prettier (not too much), and seal everything up for longevity. At my age (60) I'm guessing this new work will still outlast me.
zuggbug
zuggbug is offline
PostPosted: Tue Oct 01, 2013 6:50 pm    Post subject: Reply with quote
Applause Applause
Great job...thanks for sharing
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
zimblewinder
zimblewinder is offline
PostPosted: Tue Oct 01, 2013 7:13 pm    Post subject: Reply with quote
I have the same process only I use pop rivets to pull the plug weld line together. As long as the area behind isn't blind I just drill the heads out and push out the rest before I weld. Fairly quick.
Cheers
Dale
58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism
kenshapiro2002
PostPosted: Wed Oct 02, 2013 8:24 am    Post subject: Reply with quote
Using POR 15 Filler / Seam Sealer on the edges, over the welds, etc. VERY pleased with how it fills, dries and hardens. Supposed to take 4 days for a total cure. About $15 a tube and had enough to do more than the floor...top and bottom. It also does the same trick on any rust it hits as regular POR 15.
mandraks
mandraks is offline
PostPosted: Wed Oct 02, 2013 9:00 am    Post subject: Reply with quote
if you put some tape down before you put the sealer on, you get really nice looking seams
regards
Uli
kenshapiro2002
PostPosted: Wed Oct 02, 2013 9:03 am    Post subject: Reply with quote
Nice point. Even though I'm pretty OCD, I'll survive this one since it'll be under a mat and only a driver...not a show car.
nice dad
nice dad is offline
PostPosted: Sun Oct 06, 2013 5:14 pm    Post subject: Reply with quote
Well you inspired me to take my rusted floor pan out. I just want to mention how I removed the Cab Heater Tube Assembly.
I ground down a total of 5 welds (@ B & D) and popped out (according to your drawing) sections 2 & 3 as one piece. Tapped the tube down and out with no problems.
Thanks
1967 Single Cab
kenshapiro2002
PostPosted: Sun Oct 06, 2013 5:24 pm    Post subject: Reply with quote
Great! If you leave the e-brake assembly in, like I did, you'll need to remove the upright section if the heater tube as well to fit and install the new floor... Not difficult. I'm installing the steering column and various pedals this week. My new found skills and confidence will have me attacking the right side rocker, B-pillar and surrounding area soon. After the floor, these other jobs seems almost easy.
nice dad
nice dad is offline
PostPosted: Mon Oct 07, 2013 11:52 am    Post subject: Reply with quote
Yeah that E-brake is a Mad Dog to get out, that pin is rust welded to the handle. Might have to just bust out the sazall and see what happens.
1967 Single Cab
kenshapiro2002
PostPosted: Mon Oct 07, 2013 5:44 pm    Post subject: Reply with quote
Nah...leave it in. That's what I did. You'll just have to remove the upright section of the heater tube to get the floor in...slips right over the e-brake handle.
kenshapiro2002
PostPosted: Wed Oct 16, 2013 9:05 am    Post subject: Reply with quote
Finally got the correct paint. I'm finished other than reassembly of ancillary stuff. VERY pleased with the results and that this job is over!
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed Oct 16, 2013 1:10 pm    Post subject: Reply with quote
Nice job! I just caught up with the thread since commenting on it at the beginning. You can really gain an appreciation of what's involved once you actually do one.
How about a couple of before after pics to really see the difference?
Congrats!
Mike K
Bulli Klinik
Colorado Springs
kenshapiro2002
PostPosted: Wed Oct 16, 2013 2:32 pm    Post subject: Reply with quote
Mt "Befores" are on page #1.
kenshapiro2002
PostPosted: Thu Oct 17, 2013 1:45 pm    Post subject: Gerston's Hole Isn't Where It Should Be ! Reply with quote
Trying to reinstall the steering column today and just couldn't do it. First problem was the hole was 30mm and the column is 32mm. Then, still couldn't get the bus high enough off the ground to get the column back in. Brett tells me that on 2 of the 4 floors he's bought from Gerston, he had to move the column hole rearward 1/2"...that Gerston has moved the placement of the hole multiple times (waiting for a call back from Gerston), and still has complaints from folks. I'm not upset, these things are always gonna need tweaking.
My plan is to cut a horizontal box out around the hole, off set to be 1/2" deeper to the aft end. Hopefully, I'll just be able to swing the piece around 180ยบ and have it right. Chances are I'll still have some "fudging" to do.
Gerson
Gerson is offline
PostPosted: Thu Oct 17, 2013 2:05 pm    Post subject: Reply with quote
this is the first I hear of this with the steering column......we are checking right now what the hell is going on.... Confused Confused Confused Confused Confused
that's not patina, that's fucking rust man!!!!
we (klassicfab) make the funky green panels...........
Page 6 of 9
