djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
Posted: Thu Oct 10, 2013 12:10 pm Post subject: How to Clean Electric Terminals? |
You will often read "clean your ground terminals" or "check for corroded terminals and clean them".......
But, I've yet to read much about cleaning them.
The extent of my electrical cleaning experience is...
1. Wire Brushing /sand papering surfaces and terminals until shiny.
2. Using Baking Soda mixed in water to clean battery terminals and hold down hardware.
3. A can of Electric Contact Cleaner on contact switches.
Now. I've got the 86 Vanagon with corrosion at many many points throughout the body.
Interestingly a lot of the green growth on the terminals is on the grounding points......Why? Why does the ground lug attract corrosion?
I've pulled my fuel injection harness out of the Van. I've got many terminals that look brand new, some slightly grey and some down right green and fuzzy!
Is there an acid bath that you recommend to clean all of the terminals?
You certainly are not going to get a wire brush in some of these tiny pin connections!
Suggestions please!
Thanks!
Some photos......
Ghia
Vanagon
Beetle
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19124 Location: Retired South Florida
Posted: Thu Oct 10, 2013 12:55 pm Post subject: |
| I use Wurth Contact Cleaner. You apply it and let it set for say 15 minutes. Some used terminals that you can move in and out of the connectors will help too. Then some compressed air to dry it all out. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15412 Location: Syracuse, NY
Posted: Thu Oct 10, 2013 1:30 pm Post subject: |
this may be far from proper, but you asked what we (I?) do.
I use Muratic acid from the concrete floor cleaning portion of the hardware store
I have LONNNNNG handle medical q-tips and then a quench liberally with a carb cleaner, followed up with a new top sealing coat of something to prevent the newly etched copper from flash corroding.. often a silicone wire grease or fluid film.
makes then shiney copper, but at risk of corroding faster & worse the 2nd time if not properly rinsed and sealed. _________________
| Abscate wrote: |
| These are the reasons we have words like “wanker” |
randywebb Samba Member
Posted: Thu Oct 10, 2013 1:31 pm Post subject: |
I usually mix up some "strong vinegar" i.e. a 10% acetic acid solution - using photographic chemicals and let it sit in that for several hours; soak a paper towel in it and tape to a body panel with plastic over it
then spray with CRC contact cleaner or similar (DeOxit is good)
some will use emery paper but that can remove too much good material
- replace things if needed such as gnd. straps & gnd. stars
for those captive contacts, there should be a little tab you can move to release them from the plastic block _________________ 1986 2.1L Westy 2wd Auto Trans. |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
tclark Samba Member
greebly Samba Member
Joined: August 27, 2009 Posts: 973 Location: Here and now
Posted: Thu Oct 10, 2013 2:34 pm Post subject: |
| randywebb wrote: |
for those captive contacts, there should be a little tab you can move to release them from the plastic block |
Good advice. A vinegar solution will clean corroded contacts extremely well, as will wire brushing or sanding, just realize that it will also strip plating and the terminals will be even more prone to oxidization once stripped of their plating. Use Dielectric grease. Replacing the terminals would be the best method. Your van appears to be quite corroded. |
Posted: Thu Oct 10, 2013 2:50 pm Post subject: |
| greebly wrote: |
| randywebb wrote: |
Well, it is........ Being in NJ not only I we have humidity, we also have salt air! Neither of which is an ideal situation!
It is curious though why the corrosion favors the grounds! I'm sure that there is a scientific explanation with positive and negative ions or some such similar stuff!
Ghia
Vanagon
Beetle
Posted: Thu Oct 10, 2013 3:29 pm Post subject: |
| djkeev wrote: |
| greebly wrote: |
| randywebb wrote: |
Dave |
I would say that grounds are pretty exposed on a car and are often ignored when problems begin to occur. I learned a long time ago to just replace battery cables and tranny ground straps at the first sign of problems, it seems stupid to try and eke a few more miles out of a fairly cheap part. |
Westified Samba Member
Posted: Thu Oct 10, 2013 3:54 pm Post subject: |
I could be Galvanic corrosion. This is common in boats where to dissimilar metals touch. http://en.wikipedia.org/wiki/Galvanic_corrosion
The copper of the connector and the steel of the van. Just a thought. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Alaska-Mike Samba Member
Posted: Thu Oct 10, 2013 7:43 pm Post subject: |
I use vinegar followed by DeOxit. _________________ 1983 Vanagon 1.9L GL - destined to become a dry camper
But I'd rather have a split bus.  |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sat Oct 12, 2013 4:43 pm Post subject: |
An overnight soak in floor stripper will get the terminals shiny looking. It will not hurt the plastic either (test to be sure though). I have done this many times and with some old pennies and they look brand new afterward. When I say floor stripper I am talking about the kind used by professionals to take off the acrylic wax on wal-mart style floors. It's available at home depot or the like in the cleaning aisle in 1 gallon bottles. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1945 Location: Sidney B.C. Canada
Posted: Sat Oct 12, 2013 4:44 pm Post subject: |
The reason you are finding corrosion on the ground connections is due to the electrons that have just passed through the device being powered telling the electrons in the metal contact just how much fun the ride was. So the valence electrons of the metal join up and head on to the battery.
The metal contact loses electrons, oxidation, and thus corrosion is the result.
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
Posted: Sat Oct 12, 2013 5:14 pm Post subject: |
| djkeev wrote: |
Interesting, one tail light, no corrosion, the other...... Corrosion ONLY ON THE BROWN GROUND WIRE TERMINAL.
Why? Why the ground wire? There is no dissimilar metal contact here, brass to brass.???.......
Dave |
There is no Ground system on an automobile, the chassis is a return path. The vehicle is isolated from ground effectively by the rubber tires. As badly corroded as your return system is it indicates something sacrificial is occurring with the chassis. Perhaps you can utilize a sacrificial zinc electrode to act as an anode tied directly to the ground terminal of your battery and alternator. It will deplete instead of your ground corroding. |
Posted: Sat Oct 12, 2013 6:40 pm Post subject: |
| djkeev wrote: |
Interesting, one tail light, no corrosion, the other...... Corrosion ONLY ON THE BROWN GROUND WIRE TERMINAL. |
There is enough difference in the reactivity of the metals in the pins and wire terminals to cause corrosion due to the current flow. Galvanic corrosion requires current flow, it can be self induced flow or can be applied by an exterior force such as your charging system.
I am just glad I chose years ago not to live in a part of the country that uses road salts.  |
