Manx soft Top Interior Frame
frizzardking
frizzardking is offline
PostPosted: Fri Oct 04, 2013 8:44 am    Post subject: Manx soft Top Interior Frame Reply with quote
Does anyone have some pictures of how the tube frame is on the Manx soft top. I have a nos top that came with side curtains with one of my buggies and it matches up to exactly to my Manx II , So I need to have the tube frame made.
Here are some pictures in a moment.
thanks Marc.
Not sure if if its a real Manx top were their several manufactures? I know some had rear side windows. It has the spike receptacle and you press it over; the side curtains zip on the top to the top ,and has snaps to the body on the inside.
So again the white top came with my emerald Manx and was never installed.
There are no snaps screwed into the green Manx , it just came with the top.
It even has the brown paper in between the windows.
So I saw the snaps on my yellow Manx and they Match up perfect even the inside snaps.
That's why I am wondering if this is a factory Manx top?
frizzardking
PostPosted: Fri Oct 04, 2013 9:16 am    Post subject: Manx soft Top Interior Frame Reply with quote
Here are Picture's of the Manx II and the soft top that lines up perfect ,If it's a real Manx top I don't know
frizzardking
PostPosted: Fri Oct 04, 2013 9:18 am    Post subject: Manx soft Top Interior Frame Reply with quote
Inside Snaps
frizzardking
PostPosted: Fri Oct 04, 2013 9:22 am    Post subject: Manx soft Top Interior Frame Reply with quote
Top on without frame
RedBaronofRedBud
RedBaronofRedBud is offline
PostPosted: Fri Oct 04, 2013 9:24 am    Post subject: Reply with quote
Here are a couple of pics of mine. The dimensions are as follows:
17.5x43x17.5 and 23.5x43x23.5
The 23 one goes to the rear and the 17 to the front. It adjusts for fit. The rear bow is inside a sleeve and there is a strap that keeps the bows from spreading too much.
LMK if you need more information
Or you can call me………Tim
My two pennies…your mileage may vary
I’m not a complete idiot, there are parts missing
kustoms
kustoms is offline
PostPosted: Fri Oct 04, 2013 10:02 am    Post subject: Reply with quote
The Manx top would have had three windows in the rear. If I had the buggy here I could make a frame for you.
Google this.
"Bread and Circuses"
And wondering what the heck happen to my Samba post count?!?
Tom Thompson
Tijuana Kustoms Inc. (TM)
1-516-338-8746
www.tjkustoms.com
frizzardking
PostPosted: Fri Oct 04, 2013 10:12 am    Post subject: Manx soft Top Interior Frame Reply with quote
Thanks Guys ! Were there several manufactures that made variations of the top or did Manx tops always have a three rear window?
frizzardking
PostPosted: Fri Oct 04, 2013 10:17 am    Post subject: Manx soft Top Interior Frame Reply with quote
Here is a picture of Vince's top from his buggy from last year and I thought he said it was the original top , it looks just like mine
RedBaronofRedBud
PostPosted: Fri Oct 04, 2013 10:18 am    Post subject: Reply with quote
Mine has the three windows, but I really dont know who all made them. This was the one that came with my buggy. Just had the bindings and snaps redone. The lady did a great job, IMHO.
Mike1991
Mike1991 is offline
PostPosted: Fri Oct 04, 2013 10:43 am    Post subject: manx soft top Reply with quote
This picture shows top bows for an original style top as seen in the original Manx catalog. This configuration hides bows when using this style 3 window top from being seen from the outside. Note straps between loops to keep the top tension tight so it does not flap at speed. The velcro strip around perimeter of body holds the top on without any snaps showing (not original).
Picture of original style top. No blind spots when driving. No snaps showing.
Picture from original Manx catalog. Price approx. $127.00 or so with side curtains, top bows, and all fasteners.
kustoms
kustoms is offline
PostPosted: Fri Oct 04, 2013 10:49 am    Post subject: Reply with quote
There was a few companies that made tops for buggies. The top in the Manx catalog is what I consider the original.
Google this.
Tom Thompson
1-516-338-8746
www.tjkustoms.com
surfnc
surfnc is offline
PostPosted: Fri Oct 04, 2013 11:35 am    Post subject: Re: Manx soft Top Interior Frame Reply with quote
Marc
Mine was definitely not a Manx top. It was original to the build in 1968 but not from Meyers Manx. The bow system is just like this.
Yours uses a "lift the dot" fastener which I think is sturdier than the snap set up. You also have the holes for the bow bases in the body. You may want to contact the seller and see if they have the bows laying around.
Vince
LOOKING FOR VINTAGE MEYERS MANX STUFF!!!
http://www.thesamba.com/vw/classifieds/detail.php?id=1105228
weasel_ugs
weasel_ugs is offline
PostPosted: Fri Oct 04, 2013 7:02 pm    Post subject: Reply with quote
The way the frame work is designed looks just like the frame on my Jeep YJ for use with the "family cage". I think I will have to see how close it is to fit my buggy because I really want a full top for it.
frizzardking
PostPosted: Fri Oct 11, 2013 8:33 am    Post subject: Manx soft Top Interior Frame Reply with quote
Just had a boat canvas guy come and mock up the frame for the yellow Manx 2, with the aluminum frame, should be done when i get back from the Banx .
Thanks for the Pics and dimensions it really helped , going to have one made for the signature manx too.!
RedBaronofRedBud
PostPosted: Fri Oct 11, 2013 9:14 am    Post subject: Reply with quote
My pleasure. If you need more dimensions or more pics, just LMK.
Have fun at MoTB! Safe travels!
