Bus Engine Tubes-- Part Question
VW Addict Premium Member
Samba Salesman
VW Addict is offline
PostPosted: Sat Oct 19, 2013 12:55 pm    Post subject: Bus Engine Tubes-- Part Question Reply with quote
What are these called and what purpose do they serve? Thanks!
busdaddy
busdaddy is online now
PostPosted: Sat Oct 19, 2013 2:14 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
Слава Україні!
airkooledchris
airkooledchris is offline
PostPosted: Sat Oct 19, 2013 9:13 pm    Post subject: Reply with quote
those aren't for anything.
ill send ya a few bucks and my mailing address, just to get them out of your hair for ya. Cool
if your heater control valves have the port for them, connect them!
Wildthings
Wildthings is offline
PostPosted: Sat Oct 19, 2013 9:32 pm    Post subject: Reply with quote
You can accomplish 90% of what the dump tubes do by just running a flex (or other) tube down from the flapper valve and terminating it at the level of the bottom of the engine. If you have the full OEM set up then using the dump tubes if fine, but I wouldn't go out to a yard just to look for a set unless I needed them to pass CARB or something.
