Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sat Oct 19, 2013 1:52 pm Post subject: 74 Super Beetle antenna |
Here is a pic of the antenna on my 74 SB. I want to replace it but I can't find one like it. Is this a stock antenna?
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sat Oct 19, 2013 1:59 pm Post subject: |
On my 74 the hole is oval, my antenna base is different than yours , so id. Say youres is aftermarket. |
Beeble1 Samba Member
Joined: August 14, 2012 Posts: 595 Location: Manteno, Illinois
Posted: Sat Oct 19, 2013 2:02 pm Post subject: |
Stock ones to dot have screw holes... There is a nut under the body. _________________ Beeble1, 1973 Super (o\_|_/o) 1600cc w/ Dealer A/C
Beeble2, 2013 Beetle 2.5L Daily Driver
Dealership items from Bishop-Wayne Volkswagen & Turner Volkswagen in Kankakee, IL wanted |
mountainkowboy Samba Member
Posted: Sat Oct 19, 2013 4:48 pm Post subject: |
That's the wrong antenna........the right one is a Harada 09V _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
BeetL62 Samba Member
Joined: January 05, 2005 Posts: 146 Location: Pottstown, PA
Posted: Sat Oct 19, 2013 8:35 pm Post subject: |
My '74 Super had the exact same antenna. There was a cover piece that covered the screws so they are not visible. I could not find a replacement, so I welded the screw holes and changed it out to the style that is available. |
Posted: Sun Oct 20, 2013 7:18 am Post subject: |
Has anyone ever tried one of those retractable antennas? Do they fit w/o a problem? I'm thinking of going that route so I can use a car cover. |
Oldchevyguy Samba Member
Joined: November 06, 2010 Posts: 219 Location: California
Posted: Sun Oct 20, 2013 8:20 am Post subject: |
Dwayne1m wrote: |
I have one on my '74 Super. Easy to install, looks good, and works great. |
Posted: Sun Oct 20, 2013 10:44 am Post subject: |
Thanks. I'm gonna give the retractable antenna a try. |
Posted: Sun Oct 20, 2013 11:57 am Post subject: |
The retractable works on a standard and the early flat glass supers, don't remember if they work on a curved windshield...........I imagine it would. _________________ Chuck in Socal
78 Honda CB750K
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun Oct 20, 2013 2:45 pm Post subject: |
Are you talking about power antennas?
Dunno how you'd go in a LHD with the fresh air box in the way but i had one in my RHD 1303 which has heaps more room and it was still a royal PITA to fit.
I had to remove the hood hinge to get it in there and with the lack of space for the motor the mast ends up at a funny angle leaning outwards |
Posted: Sun Oct 20, 2013 4:57 pm Post subject: |
Joel wrote: |
The antenna is not power operated. Have to push it down by hand. Mid America sells them for around $20. |
Joel wrote: |
Mine is just the manual retractable. I tried the power, but as you say, there just isn't enough room. |
galancline Samba Member
Posted: Mon Oct 10, 2016 12:40 pm Post subject: Re: 74 Super Beetle antenna |
did you ever find a replacement for your antenna?
I have the same antenna on my 77 SB convertible |
Posted: Mon Oct 10, 2016 2:11 pm Post subject: Re: 74 Super Beetle antenna |
I never found a replacement that had the 3 screws. I ended up welding the holes shut and went with a manual retractable antenna. |
Posted: Mon Mar 27, 2017 1:00 pm Post subject: Re: 74 Super Beetle antenna |
My 1977 Super Beetle Convertible has the same antenna. I think they changed to this style in the last couple of years they imported Beetles in to the states. |
vwoldbug Samba Member
Posted: Mon Mar 27, 2017 6:57 pm Post subject: Re: 74 Super Beetle antenna |
I believe that is a Motorola antenna that some vw dealers used . You might try google |
rolfestim Samba Member
Posted: Mon Jun 17, 2024 4:04 am Post subject: Re: 74 Super Beetle antenna |
Dwayne1m,
Did you ever replace your antenna? My 79 has something similar and I'd like to replace it, as well. |
