type11969 Samba Member
Joined: September 12, 2004 Posts: 484 Location: Collingswood NJ
Posted: Thu Nov 21, 2013 8:25 pm Post subject: Mallory unilite w/ vac and FI? |
Anyone running stock FI with a vac advance Mallory? If so, how did you get the can to clear the CSV, maintain enough sweep to dial in timing, etc. Did you have to dent the tin around the dist or? It's close, but I'm not seeing a way around some hammering - and I'd like another way.
Thanks,
Chris _________________ 1969 VW Beetle - t4ed indeed
1971 Porsche 914 - jackstanded
1976 Westy - DD |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13534 Location: West Coast, USA
Posted: Fri Nov 22, 2013 9:06 am Post subject: Re: Mallory unilite w/ vac and FI? |
type11969 wrote: |
Thanks,
Chris |
I don't know the setup, but could you reindex the drive gear? _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Fri Nov 22, 2013 11:15 am Post subject: |
Yeah, I'm assuming the plug wires will go where they need to (reindexed) in order to get everything to fit - assuming it can to begin with.
-Chris _________________ 1969 VW Beetle - t4ed indeed
1976 Westy - DD |
whip618 Samba Member
Joined: October 16, 2002 Posts: 762 Location: Albuquerque
Posted: Fri Nov 22, 2013 7:00 pm Post subject: |
This is on a dual carbed type IV 2.0 but i had to reindex the drive gear to get mine to work.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Posted: Sat Nov 23, 2013 3:04 pm Post subject: |
Phil-
Thanks. The challenge is fitting the vac can next to the cold start valve used on the stock FI . . . but I think I may be able to weasel it in the way you have it. Good to know you can dial the timing in with the dist in that position.
1976 Westy - DD |
