15" rims instead of 16"?!
Ghia 1966
Ghia 1966 is offline
PostPosted: Sun Nov 24, 2013 8:01 pm    Post subject: 15" rims instead of 16"?! Reply with quote
This split has some items not correct for its year (1950) including 15" rims from the later models instead of 16" ones?! I believe previous owner changed the front beam to a later 60s models! Any comments, analysis , advice since I am going to restore that one ! It s working fine like that though!
- Split De luxe 1950
- Oval Ragtop 1956
- Karmann Ghia 1966 Convertible
- Bug 1970 Convertible
Grant Reiling
Samba Slow-Change Artist
Grant Reiling is offline
PostPosted: Sun Nov 24, 2013 8:44 pm    Post subject: Re: 15" rims instead of 16"?! Reply with quote
@ Ghia 1966, My analysis is it happened with the beam swap. Idea
If your plan is fully returning to stock, add another spendy one to your list. Sad
BUT, if your plan is to make it a nice driver, as you said " It s working fine like that though!"
why not roll it on the one it has while you search for a set of 16s plus the correct beam to hang them on? Question Wink
(yeah, the slotted 15s detract, but may be overlooked while you score the many other things it needs/deserves?) Question Arrow
Your car, your budget, your call. Wink
Best,
Grant
1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water
VWLady
Crazy VW Lady
VWLady is offline
PostPosted: Sun Nov 24, 2013 9:29 pm    Post subject: Reply with quote
Find the serial number on the beam and you can tell what year it is. Check the part that the rubber snubber fits on for the number.
eurodub
eurodub is offline
PostPosted: Sun Nov 24, 2013 9:32 pm    Post subject: Reply with quote
My split still looks bone stock but has a later beam and later brakes, later gearbox and also later engine. That didn't stop me from cruising all across Europe and to the major shows. on 15" ... Wink
correct parts do show up occasionally, it's your decision if you want a bone stock or a car to just enjoy.
1960 1200 model 117 deluxe ragtop
1976 MK1 Golf
Ghia 1966
PostPosted: Sun Nov 24, 2013 9:34 pm    Post subject: Reply with quote
Absolutely agree with u! I m intending to try to save every $$$ I could as long as it s ok and not a major cosmetic default
- Oval Ragtop 1956
Rome
Rome is offline
PostPosted: Thu Nov 28, 2013 3:32 pm    Post subject: Reply with quote
For a low $ interim solution on your wheels, just find some 15" "smoothies" from the late 1950's thru 1965 Type 1, and paint them two-tone cream inner and black outer (spray cans are fine). Put on the chrome hubcaps too. Even though the two-tone wheel scheme came slightly later in the split era, and then only on deluxes, to most people it will look "period correct".
Smoothie 15" 5-bolts are usually very cheap here in the USA. 16" wheels are MUCH more expensive, and then you have to buy 16" tires as well. With the 15" smoothies painted like I suggested, you can swap the 15" tires on your current wheels on if they are still OK.
DDub
DDub is offline
PostPosted: Thu Nov 28, 2013 5:19 pm    Post subject: Reply with quote
Looks like '66 or '67 drums front and rear too. Are you sure the pan wasn't replaced?
mandraks
mandraks is offline
PostPosted: Thu Nov 28, 2013 6:05 pm    Post subject: Reply with quote
was thinking the same, easy enough to find out
regards
Uli
Ghia 1966
PostPosted: Thu Nov 28, 2013 7:27 pm    Post subject: Reply with quote
The beams were changed for later models from 60s
- Oval Ragtop 1956
usariemen
usariemen is offline
PostPosted: Fri Nov 29, 2013 6:08 am    Post subject: Reply with quote
We saw the pan already.
And it´s split.
Master of my domain!
SuperSamba
Samba False Idol AI
SuperSamba is offline
PostPosted: Fri Nov 29, 2013 2:46 pm    Post subject: Reply with quote
This seems like you should contain it in the existing thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=577017
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - Split-Window/1938-53 VWs All times are Mountain Standard Time/Pacific Daylight Savings Time
