VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3081 Location: The Bull City
Posted: Mon Dec 02, 2013 4:15 pm Post subject: Roof Skin Year Changes |
| Does anyone know if later bays use the same roof skins as early bays? I need to put one on a '69 and a '72 is the latest hardtop bus I have to compare it to. Does anyone have an early bay and say a 77-79 to compare it to? Thanks |
Joined: January 01, 2007 Posts: 17903 Location: sticksville, ct.
Posted: Mon Dec 02, 2013 4:22 pm Post subject: |
i think you will need a donor no later than 71. for some reason, i think there is a difference _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
Posted: Mon Dec 02, 2013 4:34 pm Post subject: |
| skills@eurocarsplus wrote: |
| i think you will need a donor no later than 71. for some reason, i think there is a difference |
Yea, that's what i'm trying to confirm before I commit to buying one 2 states away
I was thinking they would change in '72 with the rear corners changing, but I really see no difference between the one I have here and the '69. I am just doing the gutter up. |
Mobiltune Samba Road Ranger
Joined: April 16, 2008 Posts: 499 Location: San diego county
Posted: Mon Dec 02, 2013 5:50 pm Post subject: |
check out the gallery,,, I think there the same.
_________________ Roadster Bus |
babysnakes Samba Member
Posted: Mon Dec 02, 2013 6:32 pm Post subject: |
| I've read a few arguments that they taper towards the rear differently from early to late, I'm not buying it though. I think they are the same. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53079 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 02, 2013 6:43 pm Post subject: |
| babysnakes wrote: |
As do I. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2036 Location: Philly, PA
Posted: Mon Dec 02, 2013 7:04 pm Post subject: |
This is what I recall as well . Though certainly not certain, I think the later models are very slightly wider in the back.
For what it's worth, the early and late roof sections have different numbers in the parts books/microfiche. |
Posted: Mon Dec 02, 2013 7:11 pm Post subject: |
i honestly thought there was something different. i dunno. buy it and confirm it for the rest of us  _________________
| Jake Raby wrote: |
| Brian wrote: |
Posted: Tue Dec 03, 2013 4:10 pm Post subject: |
| mattcuddy wrote: |
What's the VIN cutoff? |
Posted: Tue Dec 03, 2013 5:47 pm Post subject: |
| mattcuddy wrote: |
I don't know about the wider part, the hatch opening is a little different as far as upper seam location on 72+'s, maybe the number difference reflects a stamped in step to clear a lapped seam that moved or something like that? I'm going to do a little rough pattern making and some testing when I get time. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
rustbus Samba Member
Posted: Tue Dec 03, 2013 8:38 pm Post subject: |
| busdaddy wrote: |
I don't know about the wider part, the hatch opening is a little different as far as upper seam location on 72+'s, maybe the number difference reflects a stamped in step to clear a lapped seam that moved or something like that? I'm going to do a little rough pattern making and some testing when I get time. |
Yeah i gotta disagree on the wider thing too. i've heard it mentioned around here, but never backed up with any proof - busdaddy if you present the facts, then this urban legend can be solved and linked to for the entire future of the internet
seriously though, people put early belt trim on lates all the time, so thats not wider. all available body repair panels dont seem to indicate anything either as far as different parts for late vs early
i'd check but all i have here is a 72 and a 75....oh and that '78 storage box, out of town...and my 8' wide caliper is in the shop
thanks B'daddy _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Wed Dec 04, 2013 6:05 am Post subject: |
Wider? Nope. I have roof racks that been on a '66, '70, '74 and a '79 and they fit them all. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Dean Bradley Samba Member
Joined: November 10, 2004 Posts: 440 Location: United Kingdom
Posted: Wed Dec 04, 2013 6:17 am Post subject: |
As far as Im aware Colby there aren't any differences , but a roof closer to the intended model is always better due to the stamping presses wearing out over time etc ..... Yes it does happen , check the difference between a 68 frt wheel arch and a 70
The hardest bit is getting the damn skin off the substructure and then welding/grinding it down again afterwards
Post up some pics though my friend of your finished bus _________________ The Original German Folks UK
The path of the Righteous is Never Smooth ..... |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42850 Location: at the beach
Posted: Wed Dec 04, 2013 8:50 am Post subject: |
| take a look from the last panel seam back to the corner. If there is a difference that is where it will be. I don't recall my 1971 tapering in a little from that last seam, however my 1977 does equally on both sides. |
Posted: Wed Dec 04, 2013 8:31 pm Post subject: |
| VWsArent4Hippies wrote: |
| mattcuddy wrote: |
Not certain. This isn't one of the parts where it shows both numbers in the same parts book, one each for pre and post a vin.
The early paper parts book (this one is from around 73 or so) has a part number of 211-817-111C
The later microfiche (this one is from January of 1983) has a part number of 211-817-111G. I have not scanned this fiche in yet, so all I have is a pic of the reader screen.
A different part number doesn't necessarily mean they were different dimensions, but something was likely different. VW wasn't really in the habit of issuing new parts numbers for no reason.
Will a later roof work on an earlier bus? Certainly, even if its different. And if for some reason its not direct plug and play, I'm sure you can make it work.
| Joey wrote: |
Wider? Nope. I have roof racks that been on a '66, '70, '74 and a '79 and they fit them all. |
If they are different widths, it wouldn't be like one was 5 inches bigger than the other. If anything it'd be, what, an inch or something? Meaning your rack legs on each side would have to move around 1/2 an inch to still fit. Completely plausable, especially given how many racks have tweaked legs anyway. |
Posted: Wed Dec 04, 2013 8:47 pm Post subject: |
Matt Cuddy, you're my hero
Too bad there isn't a progressive refinements for baywindows. I placed a wanted ad for a roof and pretty much everyone who responded has late bays. I will probably end up getting one and figuring it out.
| Dean Bradley wrote: |
| Post up some pics though my friend of your finished bus |
You got it! I will probably dig in over the winter, I need to get some other junk out of my garage to make room  |
Posted: Wed Dec 04, 2013 8:52 pm Post subject: |
There is definitely some roof stuff that changed at end of 71 model year, so who knows. Like some rear roof frame stuff shown in #19 below (use the same early diagram as above)
Colby, if you wanna make the drive, there are some early bays in junkyards up around here. As normal up here, bottoms are completely toast, but roofs are generally not rusted away.
| Quote: |
Too bad there isn't a progressive refinements for baywindows. |
There are the listings in the Molenaar Specification Guide, but not nearly detailed as the early actual VW stuff. |
Joey Samba Member
Posted: Thu Dec 05, 2013 6:09 am Post subject: |
| mattcuddy wrote: |
| Joey wrote: |
Here's my roof racks...
...they are very solid and don't flex or bend. The fit on each bus was identical. _________________ Joey
