bus boys adjustable springplate / tire clearance issues
Jeff Power
Location: with any luck, in my garage building bass guitars.
Jeff Power is offline
PostPosted: Fri Feb 25, 2005 7:29 pm    Post subject: bus boys adjustable springplate / tire clearance issues Reply with quote
i am running the bus boys adjustable springplates with four lug beetle drums w/ five lug adapters.
i am trying to mount my wheels, but am having problems with my, 195/65/15 tires on stock 15'' wheels, hitting the springplate adjusters.
i need about another 1/2'' to clear the adjuster.
anyone else have these problems, any possible solutions.
I build complete Westy Style camping interiors check them out here > www.rjcampers.com
Check out my basses here www.ellabasses.com
jerry wrote:
Nothing says "I love busses" more than picking up a mouse turd filled with horse hair seat padding
mintonman
mintonman is offline
PostPosted: Fri Feb 25, 2005 7:49 pm    Post subject: Reply with quote
I don't know if type 3's ever had 4 lug drums, but if they did, you may want to try a set of them. Like the bus drum, it's wider, I belive they did have 4 lug in the late 60's & 70's. If like the bus drum, you may have to grind the snout of the drum down to put the avel nut on. I'm not 100% on any of this , but my get you in the rite direction.
Hoockd on fonicks werkt for mee?
under the influance "DUH"
Jeff Power
PostPosted: Fri Feb 25, 2005 8:06 pm    Post subject: Reply with quote
what i don't understand and will have to wait until monday morning to ask is what does bus boys say about this. what have they told other customers to do because they do list 4 bolt beetle drums with 5 bolt adapters as one of the options for brakes in their online instructions.
thanks for that suggestion with the type 3 brakes but it would be kind of expensive and, this early in the game, not an option.
mintonman
PostPosted: Fri Feb 25, 2005 8:15 pm    Post subject: Reply with quote
Bus boys will probably blame your tire size & suggest a 185/65. Do they mention anything about tire size in there add? I wonder if they are sold to be used with stock tires(bastards Evil or Very Mad )
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Fri Feb 25, 2005 8:56 pm    Post subject: Reply with quote
The offset of the wheels is the culprit.
The stock bus wheels have less (or more depending on your viewpoint) than any other wide five wheel.
I think you have two choices ( actually only one choice, but two alternatives)
Use rims with more positive (negative?)offset, or install a spacer to move the whole hub farther "out".
I am running Type 3 four bolt rear brakes with an adaptor, and my stock bus wheels clear the springplate, but not by much. I would like to put wide 5 drums on the rear, but the loss of the 1/2" I get from the adapter means that the tires may not clear the spring plate . I just haven't got around to measuring yet.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
NAES
NAES is offline
PostPosted: Sat Feb 26, 2005 1:23 am    Post subject: Reply with quote
You have to run some sort of a spacer with a busboys kit. I run 3/8" on mine. There are two different styles of bus 15's. The crowsfoot and noncrowsfoot.
The crowsfoot has more backspacing than the other. Since you need about 1/2" your gonna end up with a fatty of a spacer. 4to5 lug adapters should push the wheel out some but I've seen up to 3/4".
Barndoor Mafia
Box On Wheels
SBS #00
oilspot
oilspot is offline
PostPosted: Sat Feb 26, 2005 6:37 am    Post subject: Reply with quote
The type three drum (4 lug) is wider and may give you the spacing. What year bug drums are you running???
The good news is that if that will fix your problem you get to buy drums, wheels cylinders, shoes Mad .
Jeff Power
PostPosted: Sat Feb 26, 2005 6:43 am    Post subject: Reply with quote
my 4 lug to 5 lug adaptors are already 1/2'' . i need another 1/2'' to clear the springplate.
i was thinking last night and maybe i could have a fabricator add another 1/2'' to the 4 to wide 5 adaptors. i wonder if this would be safe.
vwbus67
vwbus67 is offline
PostPosted: Sat Feb 26, 2005 7:42 am    Post subject: Reply with quote
i have the same prob. im running 165R15 and the hit the adjuster. i have a 68 bug tranny with 67 drums and brakes. what do i need to do? if i need a spacer, where would i put it?
roadron
roadron is offline
PostPosted: Sat Feb 26, 2005 8:51 am    Post subject: Reply with quote
another option. buy some 15x5.5 mangels chromies. grind off the 5 small welds that hold the center to the outer. you can then slide the center to any offset position tou want. measure and reweld. it was pretty easy R
73 WESTY SO72-6 with continental bed
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
joe56vw
joe56vw is offline
PostPosted: Sat Feb 26, 2005 9:25 am    Post subject: Reply with quote
are the adjusters on both sides can you flip them around
primer look
primer look is offline
PostPosted: Sat Feb 26, 2005 9:34 am    Post subject: Reply with quote
I have the same prob' running 185/70 and tryed 165/80 both no good they rub biggtime. A was allready running 1" spacer due to my pre 67 bug drums.
I called bus boys they told me to get other wheels or run a 1" and on top of that a 1/2" spacer witch ofcourse is not safe anny more. A just removed them and put them on the shelf.
Now my bus drums are at the machine shop to get the nose cut and the lip removed so they will fit the beetle axle again. in this way i gain some more space and if i use my spacer again they will fit.
Dennis
primer look
PostPosted: Sat Feb 26, 2005 9:37 am    Post subject: Reply with quote
@ joe56vw
no you cant because than the splines will be on the inside.
greetz
Long-roofs
Long-roofs is offline
PostPosted: Sat Feb 26, 2005 9:46 am    Post subject: Reply with quote
I have not seen the adjustable spring plates, but they sound useless, at least for stock rims and low profile tires. I guess you could narrow the rear so the spring plates bolt right up to the short axles/tubes, that is another 1 1/8". Obviously alot of work to go that route.
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Sat Feb 26, 2005 10:08 am    Post subject: Reply with quote
I just put those on a bus I am working on. I have 17X7 wheels with a 55 mm offset. When I put the BB adjustables on the tires hit. I ended up usind a 1/2 spacer to get the clearance I needed.
"no more hacking my sig line"
Jeff Power
PostPosted: Sat Feb 26, 2005 11:12 am    Post subject: Reply with quote
what if i had a 1'' thick 4 lug to wide 5 lug adaptor made would that be dangerous.
Riff Raff
Shivering Sambian
PostPosted: Sun Feb 27, 2005 11:16 am    Post subject: Reply with quote
The 1" thick adapter would have to be damn sure it was true, and composed of the proper alloys to be both hard enough not to bend under the abuse, and soft enough to not crack under the stresses.
Also, you would probably have to get custom lug bolts built that are about 1/2" longer than stock.
From the "For what it's worth department"
Sounds like more pain in the butt than the alternatives.
- Daniel Boorstin
primer look
PostPosted: Sun Feb 27, 2005 11:19 am    Post subject: Reply with quote
Just get your bus drums reworked and get them on (loose the beetle drums) add a spacer and your there.
dennis
