3M Panel Adhesive Dispenser Gun
djkeev
djkeev is offline
PostPosted: Sun Dec 29, 2013 12:36 pm    Post subject: 3M Panel Adhesive Dispenser Gun Reply with quote
I do Auto Body work for myself. Not a lot of volume so spending big money for the "proper" up to date tools is not high on my priority list!
I recently decided to utilize 3M's Panel adhesive. It us a two part product that mixes in the nozzle, ingenious actually!
The proper dispensers are expensive!
$100-$400 !
Not laying out that kind of coin!
So........
Gather together ....
1 - one quart quality caulk gun (being a builder I have many for subfloor adhesives)
1 - 1-1/4" dowel
1 - 1" dowel
1 - scrap of 1x2 pine (3/4x1 1/2") about 5" long
2 - 1-1/2" pan head screws
Drill bits and screw driver
Saw
Pencil
Tape measure.
The adhesive piston centers are 1-1/2".
I marked my 1 x 2 scrap about mid point for the centers and drilled a clearance hole for the screws.
I cut the two dowels to 5-1/2" long being careful to have square ends so they sit flat on the 1 x 2...........
I Then found the center of each dowel (it helps having the right tools! Smile ) .........
I drilled the dowels with a pilot bit to prevent cracking the dowel when the screw runs in.........
I Assembled the two dowels onto the 1 x 2 ..........
See How nicely it fits?.........
Here are of photos of it in my gun. My gun has a slot in the bottom so I allowed the 1 x 2 to protrude through for balance....... If I had a do it again card, I would recess the screw heads into the 1 x 2.............
Dave
Ghia
Vanagon
Beetle
CanadianBug
CanadianBug is offline
PostPosted: Sun Dec 29, 2013 1:30 pm    Post subject: Reply with quote
Good thinking! Smile
skills@eurocarsplus wrote:
bodywork isn't a fucking race.
Northof49
Northof49 is offline
PostPosted: Sun Dec 29, 2013 3:40 pm    Post subject: Reply with quote
Awesome. Does the mixing tip mix the two components sufficiently or do you need to mix it in a separate step before applying it to a joint?
1958 Karmann Ghia owner
Der Speed Shack
Der Speed Shack is offline
PostPosted: Sun Dec 29, 2013 6:26 pm    Post subject: Reply with quote
while the 3m guns are outragously expensive, the SEM guns are only about $35 and accept all the panel adhesive tubes including 3m. the large cualking guns are still around $20 if you dont have a "bunch lying around", and they're about twice the size, but it does look like it will work.
View user's profile Send private message Send e-mail Visit poster's website Facebook Instagram Classifieds Feedback
djkeev
djkeev is offline
PostPosted: Sun Dec 29, 2013 10:30 pm    Post subject: Reply with quote
Hmmmmm...... Maybe years ago.
Today's prices.........
$70
http://www.amazon.com/SEM-Paints-SEM70029-Dual-Mix-Applicator/dp/B000BHL1HI
$99
http://www.tcpglobal.com/itemdetail.aspx?itemno=SEM%2071119
Yes, the mixing tip is a highly effective miracle of in tube mixing, quite simple, yet oddly fascinating.
One of those "Why didn't I think about that?" Devices! Crying or Very sad
Here is the mixing nozzle. Utilizing a series of baffles inside the two parts are forced to intermix with each other exiting the nozzle properly mixed together! ........
Dave
Ghia
Vanagon
Beetle
brystheguy
brystheguy is offline
PostPosted: Tue Dec 31, 2013 4:34 pm    Post subject: Reply with quote
This is genius! I splurged on the gun a month ago and it worked great. The mixing nozzle was fascinating to watch!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Jan 01, 2014 11:00 am    Post subject: Reply with quote
Confused good thinking, but....
i will have to look at my gun. for some reason, i think the plunges are staggered, so if yours are not you won't get the proper mix.
i will double check to confirm
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
djkeev
djkeev is offline
PostPosted: Wed Jan 01, 2014 11:51 am    Post subject: Reply with quote
Hmmmm, I can't imagine why they would be but if they are let me know and by how much.
Easy enough to fix! A little snip here and a tiny snip there..........And I'll change my instructions also.
The mix ratio quantity is determined by the tube size, not the piston travel.
Dave
Ghia
Vanagon
Beetle
MODIFIER
MODIFIER is offline
PostPosted: Wed Jan 01, 2014 8:44 pm    Post subject: Reply with quote
no stagger on the length of any of the adhesive guns
some tubes have one tube smaller than the other to provide the proper mix ratio.
Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Mar 09, 2015 8:52 am    Post subject: Reply with quote
Saw this thread via Vanagon forum
http://www.thesamba.com/vw/forum/viewtopic.php?p=7585596#7585596
thanks for posting what you found.
I'll probably try welding first but if my
"skills" prohibit that...... plan B!
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
