djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
Posted: Sun Dec 29, 2013 12:36 pm Post subject: 3M Panel Adhesive Dispenser Gun |
I do Auto Body work for myself. Not a lot of volume so spending big money for the "proper" up to date tools is not high on my priority list!
I recently decided to utilize 3M's Panel adhesive. It us a two part product that mixes in the nozzle, ingenious actually!
The proper dispensers are expensive!
$100-$400 !
Not laying out that kind of coin!
So........
Gather together ....
1 - one quart quality caulk gun (being a builder I have many for subfloor adhesives)
1 - 1-1/4" dowel
1 - 1" dowel
1 - scrap of 1x2 pine (3/4x1 1/2") about 5" long
2 - 1-1/2" pan head screws
Drill bits and screw driver
Saw
Pencil
Tape measure.
The adhesive piston centers are 1-1/2".
I marked my 1 x 2 scrap about mid point for the centers and drilled a clearance hole for the screws.
I cut the two dowels to 5-1/2" long being careful to have square ends so they sit flat on the 1 x 2...........
I Then found the center of each dowel (it helps having the right tools! ) .........
I drilled the dowels with a pilot bit to prevent cracking the dowel when the screw runs in.........
I Assembled the two dowels onto the 1 x 2 ..........
See How nicely it fits?.........
Here are of photos of it in my gun. My gun has a slot in the bottom so I allowed the 1 x 2 to protrude through for balance....... If I had a do it again card, I would recess the screw heads into the 1 x 2.............
Ghia
Vanagon
Beetle
CanadianBug Samba Member
Joined: September 05, 2008 Posts: 222 Location: South Western Ontario
Posted: Sun Dec 29, 2013 1:30 pm Post subject: |
Good thinking!  _________________
skills@eurocarsplus wrote: |
bodywork isn't a fucking race. |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Sun Dec 29, 2013 3:40 pm Post subject: |
Awesome. Does the mixing tip mix the two components sufficiently or do you need to mix it in a separate step before applying it to a joint? _________________ 1958 Karmann Ghia owner |
Der Speed Shack Samba Member
Joined: April 10, 2010 Posts: 164 Location: Fullerton, Ca 92832
Posted: Sun Dec 29, 2013 6:26 pm Post subject: |
while the 3m guns are outragously expensive, the SEM guns are only about $35 and accept all the panel adhesive tubes including 3m. the large cualking guns are still around $20 if you dont have a "bunch lying around", and they're about twice the size, but it does look like it will work. |
brystheguy Samba Member
Joined: October 19, 2011 Posts: 25 Location: Shawnee, KS
Posted: Tue Dec 31, 2013 4:34 pm Post subject: |
This is genius! I splurged on the gun a month ago and it worked great. The mixing nozzle was fascinating to watch! |
Joined: January 01, 2007 Posts: 17857 Location: sticksville, ct.
Posted: Wed Jan 01, 2014 11:00 am Post subject: |
good thinking, but....
i will have to look at my gun. for some reason, i think the plunges are staggered, so if yours are not you won't get the proper mix.
i will double check to confirm _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
MODIFIER Samba Member
Joined: December 09, 2006 Posts: 1560 Location: Summerville SC
Posted: Wed Jan 01, 2014 8:44 pm Post subject: |
no stagger on the length of any of the adhesive guns
some tubes have one tube smaller than the other to provide the proper mix ratio. _________________ Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Mon Mar 09, 2015 8:52 am Post subject: |
Saw this thread via Vanagon forum
http://www.thesamba.com/vw/forum/viewtopic.php?p=7585596#7585596
thanks for posting what you found.
I'll probably try welding first but if my
"skills" prohibit that...... plan B!
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
