bigluelok Samba Member
Joined: January 28, 2009 Posts: 55 Location: Altadena, CA 91001
Posted: Sun Feb 09, 2014 1:39 am Post subject: Bought a '72? deluxe (pics posted) |
all i know is that it has had 2 owners. slight rust and has a moon roof havent went to look at it yet. it isnt running and all 4 tires are flat motor is blown. its been sitting in his garage for about 20 years. no pics yet but i plan on making a trip to see it. it belongs to a coworker.
what would be a good offer to make sight unseen?
Pics further down the page
curtis4085 Samba Member
Posted: Sun Feb 09, 2014 2:09 am Post subject: |
Rust is the big factor in determining price. 72 is one only year. Deluxe sunroof is desirable. If the interior is solid and all there as well as headliner intact no rips. Straight Cali dry body. Non-op I would give $500-$2500 depending on condition. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Sun Feb 09, 2014 5:39 am Post subject: |
Sounds more like a $300 bus to me if it has a clear title. No title and it should be freebie. |
babysnakes Samba Member
Posted: Sun Feb 09, 2014 5:52 am Post subject: |
I own a '72 and had one in the past. A lot of people don't like it because it has a T-4 engine and no hatch to work on the engine. That and you need an engine and 4 tires, battery and who knows what else are good arguments for a cheap bus. If it has a title 3-5 hundred. |
streamr Samba Member
Joined: February 26, 2007 Posts: 559 Location: Southwest FL
Posted: Sun Feb 09, 2014 6:36 am Post subject: |
Them calling it a Moon Roof bothers me. To me, it sounds like they cut a hole in the roof to install one of those goofy sun/moon roofs that are mostly plastic. If it has a true original sunroof, then, yes, I agree with the 3-500, probably closer to 500 depending on what all is missing. _________________ '03 MV |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17664 Location: San Diego, California
Posted: Sun Feb 09, 2014 10:41 am Post subject: |
If it's near San Diego maybe I could look it over for you _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sun Feb 09, 2014 1:41 pm Post subject: |
I'll try and get pics sometime this week |
rustbus Samba Member
Posted: Sun Feb 09, 2014 1:53 pm Post subject: |
If its sierra yellow buy it! _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Wed Mar 26, 2014 7:06 pm Post subject: |
Looks like this will be happening soon.
What are some must have tools to work on buses? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52927 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Mar 26, 2014 7:13 pm Post subject: |
bigluelok wrote: |
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Bala Samba Member
Joined: December 04, 2003 Posts: 2637 Location: Austin, TX
Posted: Thu Mar 27, 2014 8:14 am Post subject: |
bigluelok wrote: |
Awesome!
You'd be amazed at what you can do with some basic tools.
Do you have the John Muir "Idiot" book? It has a pretty good starting point called the "Phase I Tool Kit".
If you let us know your plans we can better assist you. What tools do you currently own? _________________ 1976 Westy
1966 Beetle |
Posted: Thu Mar 27, 2014 10:50 am Post subject: |
I currently have the basic tools i have sockets and wrenches a couple ratchets, breaker bars, pry bars extensions, . I used to own a honda so basic tools to work on that.
Here's my list of must get tools
Torque Wrench
Jack
Jack stands
Muir book
Bently
for now plans are to just clean it up and get it running. Might have to get the engine rebuilt (worst case)
best case new points, check timing, you know better start with easy things to make sure that's not the issue.
1967250s Samba Member
Posted: Thu Mar 27, 2014 11:27 am Post subject: |
You should also have a torque wrench and Bentley, and get a good large jack. The 1700 is a wonderful engine IMHO. Loves to rev, less expensive and easy to find parts, very robust. One thing to have done is get all new valves in the heads as some had the crappy sodiums that like to break. Most important is rust issues, especiallly in the chassis. Good luck. |
Posted: Thu Mar 27, 2014 12:14 pm Post subject: |
thanks ill add that to my list |
Posted: Thu Mar 27, 2014 3:08 pm Post subject: |
Here is a list of tools and spare parts I inventoried when I got back from a trip to Mexico a few years back. Most of the tools all fit in a fairly small tool box.
Tube high temperature silicone
JB Weld
Tube anti-seize
Tube Loctite
Roll plastic electrical tape
Remnant of a roll of rubber electrical tape
Tube Vasoline
Bottle dry gas
Bottle FI cleaner
Can BP Blaster
1/2 Tape measure
Jumper cables
Brake fluid
Motor oil
1/2 drive sockets 15mm-22mm
1/2 breaker bar and extensions
3/8 socket set regular and deep
3/8 spark plug socket
3/8 ratchet and breaker bar, plus extensions
Metric allen wrench set
17mm tool for tranny fill and drain
Feeler guage and spark plug wire gauge set
12 point adapter for CV joint bolts, long
Hex adapter for CV joint bolts, long
Screwdrivers:
3/8 flat, long
#3 phillips
Replaceable tip #1, #2, 3/16, 5/16
Replaceable tip, jewelers
Radiator hose tool
Small rattail file
Half round file
Cresent wrenches, 4", 6", 12"
10 x 11mm tubing wrench for brake lines
8mm - 22 mm combination wrench set
6mm - 19 mm box end set
3/8 - 5/8 English combination set
VOM meter
Wiring multi-tool with misc asst of wire terminals
Diagonal cutters
Snap ring pliers, two styles
Channel-locks 10"
2# ball peen hammer
Vise Grips, large and small
Battery drill, with bits 1/16 - 1/4"
Ground cloth
Grease gun
Needle adapter
Spare parts:
Alternator belt
Fuel Filters, two |
Posted: Fri Apr 04, 2014 12:13 pm Post subject: |
thank you for the list of tools and parts. |
Posted: Fri Apr 04, 2014 12:35 pm Post subject: |
Alright so after a long wait I finally went to check out the bus.
Its been parked in his enclosed carport since 1983. Some rust on the nose below the windshield. Body looked pretty straight couldn't roll it out since it has 4 flats looks all original, but I'm no expert hell I forgot to look at the odometer. I was just to excited. I pick it up this coming week. I'm so excited don't know the exact year of the bus and wont know until he is able to go get the title from his safe deposit box.
any way enough talk here are the pic's
not the best pics since they are from my phone.
more pics being sent from my phone to email so i can upload them to photobucket to post here |
consvws  Samba Member
Joined: April 07, 2009 Posts: 1007 Location: Roseburg, OR
Posted: Fri Apr 04, 2014 12:48 pm Post subject: |
Elm Green deluxe crossover! That's a good bus there. plus it has AC and possibly a sunroof?? I like  |
Posted: Fri Apr 04, 2014 12:57 pm Post subject: |
here are more pics
