Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Wed Feb 19, 2014 9:04 pm Post subject: Things Found In Gas Tanks |
To link to this post
| Code: |
[url=http://www.thesamba.com/vw/forum/viewtopic.php?t=585603&start=0&postdays=0&postorder=asc&highlight=]Things Found In Gas Tanks[/url]
| aeromech wrote: |
I once found a rag in a gas tank.
| Resto-raider wrote: |
The fuel coming from the fuel tank was black and it had residue that cluttered the carburettor and fuel filters. Now that the engine is out I removed the fuel tank to flush it. I heard something rattling and found this;
It was some kind of rubber hose that dissolved inside the fuel tank and made the fuel rubbery black.
The rope is what's usually in the rubber to strenghten it.
The tank has been cleaned and coated on the inside and is already back in the bus. |
| SGKent wrote: |
It could be a bad ground or anything, connector to the ECU etc but what I might suspect is fuel delivery. Do you have one of these kind of fuel filler necks below? Did the bus come with a Catalytic convertor when it was born? The ends break off and fall into the tank and block the outlet. you can also get a piece of paper or plastic floating in there. Were it me and I lived with it this long, I would put a. electric fuel pressure gauge on it and mount it somewhere that I could see it. If the pressure falls suddenly when this happens you either have a blocked fuel outlet or a bad pump or pump circuit. If the pressure holds solid then you can eliminate that and remove the fuel pressure gauge. You can also mount a tachometer up front and see if it falls gracefully with the engine slowing, if it goes wildly erratic or bounces when this happens. That will tell you kind of what the ignition circuit is doing. Also feel the coil and see if it is really hot. It could be a bad coil cause that is how they act up when the go bad.
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Wed Feb 19, 2014 9:16 pm Post subject: |
 _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Thu Feb 20, 2014 8:00 am Post subject: |
Does this count?
It's the fuel supply tube that crosses the bottom of the bus. Notice how it's almost pinched shut. The pinched-off end was the end at the tank. It looked like the original hose and original crimped factory hose clamps. I can't help but think that this tube has been like this from day one. This might explain why someone in the past removed the FI because they couldn't figure out why it wouldn't run right. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
Paintedbus Samba Member
Joined: September 14, 2003 Posts: 679 Location: salem, ma
Posted: Thu Feb 20, 2014 7:27 pm Post subject: |
I put a big magnet in my gas tank.
I did it to grab the rust flakes I used to get. I pulled my tank and cleaned it up real nice and put the magnet back. It never bothered anything before, so now its just preemptive.
Now i wonder if i could have just stuck it to the outside... Hmm. _________________ Champagne Edition Roadtrip monster "Juakali"
~"Paintedbus" Ken~
The Mobile Muralist
WWW.PAINTEDBUSART.COM |
