Horn button wiring?
Page: Previous  1, 2
johny__utah
johny__utah is offline
PostPosted: Tue Jun 30, 2009 10:18 pm    Post subject: Reply with quote
Put a new 12volt German horn in last week. Tapped into the fuse box were there is spark only when key is turned. Left side if faceing the horn. Right side ground wire up the steering colum to the small screw behing the horn buttom. I had to remove the horn button spring and round flat plate. Tap the center flap a bit for better ground contact.. Horn beeps with a light touch sounds great and super loud. $13 bucks..
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Wed Jul 01, 2009 9:28 am    Post subject: Reply with quote
JacsWagen wrote:
is the old wire still in the steeringbox?
either way, you just run a wire through the steeringbox up to the steeringwheel. If the old wire is still in the shaft, splice the new wire to the old and pull the new wire up through the shaft, then cut the splice off. Another way is to use .32 safety wire (or similar) and run it down the shaft and attach the wire to the wire and pull it up through the shaft. No need to take the box apart.
easy money.
The old wire is still completely intact, just has a crack in the insulation right where it comes out. I am concerned about it grounding the the box and sounding the horn intermittently.
I was assuming there was some sort of special oil seal or connection where the wire comes out the bottom. Guess not. Thanks
grey60
grey60 is offline
PostPosted: Wed Feb 19, 2014 7:01 pm    Post subject: Reply with quote
A few folks mention taking the button completely apart in this thread… However? Nothing provided in the way of a description (or pics) as to how that actually gets done.
Mine is the early 60s commercial bus variety which sits at the end of long ground wire coming up through the steering column… so --
Once you remove the button from the steering wheel and back-out the tiny grub screw that holds the wire in the back of the button, then what?
How do you get the plastic pieces apart so you can clean-up in there?
I see a single small slot in the lower lip of the chrome-ish trim ring between the moving 'button' and the upward-facing part of the base… and seems like there are some locking tabs holding the spring/base assembly together…
How to open it up without breaking (theoretically) 50+ year-old plastic?
1960 grey panel
novetti
novetti is offline
PostPosted: Wed Feb 19, 2014 9:44 pm    Post subject: Reply with quote
That is a risky job to do but with some precaution you might not damage any of the parts.
The metal (Al rim) has 3 tabs folded securing the rim to the outer plastic rim.
Get the thinnest screwdriver you have at your toolbox and carefully try to unbent the Al tab. Pressing the centre button at the same time might help.
After you finished cleaning etc, put it back together folding the tabs in place.
I just done that last week because the centre metal circle was too dirty and with some corrosion where it makes contact with the spring which grounds into the Steering Wheel hub.
BarryL Premium Member
BarryL is offline
PostPosted: Thu Feb 20, 2014 8:44 am    Post subject: Reply with quote
True that ^^^^ what he said.
Be really vigilant of the clearance all the way around the chrome ring to the bakelite center before bending the final-vinyl as the center will perpetually stick "on" if it's not sweet before assembly. Just go around the ring and fix any little imperfections that occurred with needle nose pliers with blue tape on the tips.
grey60
grey60 is offline
PostPosted: Thu Feb 20, 2014 11:24 am    Post subject: Reply with quote
Thanks, y'all. I'd been looking at it wrong -- thinking the aluminum tabs were the back side of plastic tabs, like you see on small electronics, e.g., for battery access panels.
Which they are not Smile
And what I thought was a tab visible under the top edge of the button is actually the ONE aluminum tab now holding everything together -- the other two were already open/bent-back Laughing
1960 grey panel
oodeftone
oodeftone is offline
PostPosted: Wed Jun 25, 2014 10:10 pm    Post subject: Reply with quote
easy money.
What gauge is the wire that runs up the steering box column?
BarryL is offline
PostPosted: Thu Jun 26, 2014 8:38 am    Post subject: Reply with quote
My guess is it might be as light as #18 or it might be #16. It could be thinner than both but what is important is it's a fine fine multi strand with a soldered ferrule to screw down with the horn button setscrew. It must be able to wind and unwind almost infinitely as you steer back and forth.
On the wiring diagram somewhere on this site is the metric wire size of it printed next to the wire.
PostPosted: Thu Jun 26, 2014 9:31 am    Post subject: Reply with quote
Bus Wiring page
I picked a random year - 1963 Bus Wiring diagram - USA
(I also spot checked a bunch of other years and they were all the same)
The horn wire is size 1.0
From the Bus wiring page above, there is a link to this page:
Wiring size conversion chart - German mm to USA AWG
From that page
1.0 = 16-gauge
In reality if you look at page it's between 16 and 18 gauge since it's a metric size so use 16.
oodeftone
PostPosted: Thu Jun 26, 2014 1:09 pm    Post subject: Reply with quote
Thanks guys!
oodeftone
PostPosted: Thu Jun 16, 2016 12:15 am    Post subject: Re: Horn button wiring? Reply with quote
Here's another random horn wire question. Who repops the little metal wire holder tab that bolts to the bottom of the steering box and holds the horn wire in place? I saw a picture on here recently were someone had a nice shiny new one installed.
Stocknazi
Stocknazi is offline
PostPosted: Fri Dec 05, 2025 5:03 pm    Post subject: Re: Horn button wiring? Reply with quote
Anyone know the horn button wire grub screw size?
WANTED:
Thomas Jefferson
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Dec 06, 2025 12:36 pm    Post subject: Re: Horn button wiring? Reply with quote
I don’t know the size but I do know that the part # is N130751. Wolfsburg West stocks them.
My original low mileage 1957 Kombi had a steel wire sheath that the brown ground wire runs through from the steering box to just short of the horn contacts. That would offer a measure of protection. I’ve never seen it on another Bus but can’t see why one couldn’t added to a later Bus.
Roads Scholar
Member# 2059
70bus Premium Member
70bus is offline
PostPosted: Sat Dec 06, 2025 1:11 pm    Post subject: Re: Horn button wiring? Reply with quote
Some discussions of alternates below. And of course we all wish Neil Pickett made more!
https://www.thesamba.com/vw/forum/viewtopic.php?p=7248203&highlight=#7248203
Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater
PostPosted: Sat Dec 06, 2025 5:44 pm    Post subject: Re: Horn button wiring? Reply with quote
55-67 is listed as N130721 in the Bus parts book and says:
Stud M 2.6x5 DIN 551
N130751 mentioned by tasb is the pre-55 horn button and is:
Stud M 4x5 DIN 551
Page: Previous  1, 2
Page 2 of 2
