How many hours approx. to lower the rear end?
LeninCas
LeninCas is offline
PostPosted: Sun Mar 02, 2014 4:42 pm    Post subject: How many hours approx. to lower the rear end? Reply with quote
Approximately, how many hours are involved in lowering the rear end of a 71 bug?
one, two, many
one too many
Cusser
Cusser is offline
PostPosted: Sun Mar 02, 2014 5:21 pm    Post subject: Reply with quote
It's a re-setting of the rear torsion bars. If you haven't done it before, you'd better plan on at least half a day. And that assumes that you've done your calculations right and get it right on the first try.
You'll need tools (if memory holds from 3 decades ago when I did this) such as angle protractor, 17mm allen wrench, 8M triple square drive wrench for the CV bolts.
It's essentially the opposite of adjusting the rear torsion bars to raise a sagging rear end, which is what I actually did then. But what I did to raise the rear of my own 1971 was to buy air-adjustable shocks rather than do the torsion bar thing; yes, likely I took the quick but coward's path....
old DKP driver
old DKP driver is offline
PostPosted: Sun Mar 02, 2014 6:25 pm    Post subject: lowering job Reply with quote
X-2 with Cusser (the coward) Laughing
A minimum of 4 hours to do it right not including READING about it before hand.
Probably the hardest or time consuming part will be putting the cover plates
back on without stripping one of the bolts.
Besides all the tools and a good set of jack stands you should also replace
the inner and outer torsion arm bushings and, you also need some BABY powder to coat them
Have Fun
V.W.owner since 1967
Joeys1969
Joeys1969 is offline
PostPosted: Sun Mar 02, 2014 6:46 pm    Post subject: Reply with quote
Theres a guy that posted his video on youtube that was lowering the back of his squareback, watch all of those first so you have a good idea what is needed.
Joey
Old VW's and Old Motorcycles.
jderianSF
jderianSF is offline
PostPosted: Sun Mar 02, 2014 7:30 pm    Post subject: Reply with quote
I agree with the above time frames. Second side is easier than the first.
To make putting the plates on easier, I bought longer bolts and the hardware store. Once the long ones have brought in the plates, I switched over to the stock ones. (not my idea -- just passing it on)
I also used wratcheting straps to pull the assembly back, to free up the spring plates.
Good Luck!
Jason
Cusser
Cusser is offline
PostPosted: Sun Mar 02, 2014 7:34 pm    Post subject: Reply with quote
Yep - I was honest about now being a coward.
The longer bolts is a good idea, I've seen that in a service manual.
LeninCas
LeninCas is offline
PostPosted: Sun Mar 02, 2014 7:54 pm    Post subject: Reply with quote
Hmmm, I should start out by saying that I still haven't read how to do it. I've only looked at my bug and I think I have a pretty good idea of how it's done. I just don't have any idea of how hard it is to actually do.
I would imagine freeing up the splines will not be easy because the car is pretty stock other than what I've done to it. I'll definitely look for that video guys and decide from there if it's something I want to attempt or not.
one, two, many
one too many
Joeys1969
PostPosted: Sun Mar 02, 2014 8:53 pm    Post subject: Reply with quote
http://m.youtube.com/watch?v=MeNdZCf5AzA
This is the guy, watch all 4 videos in a Row before you do anything. It's not that bad, I've done it on 2 cars now and the first time it might have taken me 2 hours.
Joey
[email protected]
john@aircooled.net is offline
PostPosted: Sun Mar 02, 2014 11:29 pm    Post subject: Reply with quote
the 3rd time will take you 1/3 of the time as the first. This is because all the nuts/bolts come off easily compared to when they hadn't been removed in 40 years. The other reason is you don't spend 1/2 the time staring at the car trying to figure out what to do next.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
gt1953
gt1953 is offline
PostPosted: Mon Mar 03, 2014 7:01 am    Post subject: Reply with quote
Took me 5 hrs on the 68. Just be careful. Have all of the correct special tools to do the job.
72 type 1
72 Squareback
LeninCas
LeninCas is offline
PostPosted: Mon Mar 03, 2014 8:45 am    Post subject: Reply with quote
All these "special" tools are what are scaring me. Are these simple to find? I know the "star" tools to remove an IRS tranny took a little bit of looking before I actually found them. Are these tools hard to find?
one, two, many
one too many
peteandvanessa
peteandvanessa is offline
PostPosted: Mon Mar 03, 2014 9:43 am    Post subject: Reply with quote
It's not that hard, I lowered my Bugs rear end in about 2 hours (and I hadn't done it before either). The first side took maybe 2 hours, the second side less than 1 hour.
The only "special tools" are:
1. The star tool for removing the CV bolts
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D7011
2. A tool to safely help "pull" down the spring plates
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D7047
3. Angle finder (to find the spring plate stock angle if you want to go back to stock)
http://www.harborfreight.com/dial-gauge-angle-finder-34214.html
4. Pry bar:
http://www.harborfreight.com/15-1-2-half-inch-flat-pry-bar-2529.html
5. Simple garage jack
My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189
Cusser
Cusser is offline
PostPosted: Mon Mar 03, 2014 11:58 am    Post subject: Reply with quote
I didn't use one of these, they weren't invented then. That stated: if I was to do the job today, I'd buy that.
gt1953
gt1953 is offline
PostPosted: Mon Mar 03, 2014 12:43 pm    Post subject: Reply with quote
All of the tools are needed. I even had to disconnect the emergency brake cable. To do that I have to remove the brake drum, to do that you need a 36mm socket as well.
Be safe.
72 type 1
72 Squareback
Joel
Joel is offline
PostPosted: Mon Mar 03, 2014 1:53 pm    Post subject: Reply with quote
Everyone seems to do this job the long and hard way with fancy tools.
admittedly I've done the job more than a couple times and all my bolts come undone nice and easy but it takes a bit over 30 mins per side with no fancy tools other than an angle finder.
Just unbolt the the spring plate, lower shock mount and the trailing arm pivot bolt.
No need to unbolt the CV joint, brake cables etc
and a length of angle bolted to the spring plate lifts it back up without having to use chains or spring plate tools.....
Been doing it that way for nearly 20 years now.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
LeninCas
LeninCas is offline
PostPosted: Mon Mar 03, 2014 4:18 pm    Post subject: That looks really easy! Reply with quote
Joel, that way looks very simple to follow! I'm guessing that all I'd have to do from there would be lift the jack and it will raise the spring plate. My only concern with that is if it messes up the splines?
I know that in time, bugs tend to sag so I wouldn't want to do that and mess up the splines causing my bug to lower itself whenever it wants to Rolling Eyes
one, two, many
one too many
Cusser
Cusser is offline
PostPosted: Mon Mar 03, 2014 4:43 pm    Post subject: Reply with quote
Once you jack the spring plate higher than the retaining ridge, you need to "pry" it away a little so it doesn't settle right back into place, this can be dangerous, must be careful.
And opposite upon reassembly.
I believe that the "one" time I've done this, I put the jack directly under the spring plate, this way looks better, easier, and safer.
peteandvanessa
PostPosted: Mon Mar 03, 2014 5:11 pm    Post subject: Re: That looks really easy! Reply with quote
[quote="LeninCas"]Joel, My only concern with that is if it messes up the splines?
quote]
I don't think you will have a problem with messing up the splines, it will be firmly in the hole until you have "unloaded" the tension, then the torsion bar will pull out pretty easily.
Joel
Joel is offline
PostPosted: Mon Mar 03, 2014 5:13 pm    Post subject: Reply with quote
I doubt that.
Just putting the jack straight under the spring plates will lift the whole car due to torsion bar tension.
Thats why its necessery to either chain the jack to the car or use the threaded spring plate tool.......or use my angle iron method
LeninCas
LeninCas is offline
PostPosted: Mon Mar 03, 2014 5:47 pm    Post subject: Reply with quote
NOW I am confused. I figured the weight of the car would allow the spring plate to move up a notch.
I thought the angle iron method was to measure the angle of the spring plate? That way I can compare them and make sure they are both the same level.
Cusser: What you are saying makes sense to me but I am not sure where I will have to "pry" it. I thought I would hear a "click" to indicate to me that the spring plate has moved up a notch. I'm really doing this all on imagination, I have absolutely no idea. I just want to make sure I have a good idea first and then watch the videos to confirm what I think. That way, I will feel confident once I go ahead and do it.
one, two, many
one too many
