Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Mar 03, 2014 6:36 pm Post subject: |
| LeninCas wrote: |
NOW I am confused. I figured the weight of the car would allow the spring plate to move up a notch.
I thought the angle iron method was to measure the angle of the spring plate? That way I can compare them and make sure they are both the same level. |
You seriously need to watch a video or read a guide on it before tackling the job so you have a full understanding of whats going on.
heres a written guide I did years ago
http://forums.aussieveedubbers.com/viewtopic.php?tid=78303
but the vids on youtube are better to watch so you can phyiscally see whats being done.
The torsion bar needs to be removed from the splines of either the spring plate or the inner chassis and turned to lower.
there is a lot of tension on the spring plates before they are unloaded so you really need to be careful around them. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
LeninCas Samba Member
Joined: February 05, 2013 Posts: 447 Location: Orange County, CA
Posted: Mon Mar 03, 2014 9:17 pm Post subject: |
Joel, I just read the article. It seems pretty straight forward, thanks!
I will definitely watch the videos too and see how it goes ! _________________ one, two, many
one too many |
Joeys1969 Samba Member
Posted: Mon Mar 03, 2014 9:52 pm Post subject: |
| LeninCas wrote: |
I will definitely watch the videos too and see how it goes ! |
Yeah man you need to educate yourself before you tackle this job. I used to be "that" guy, do something with no backround knowledge and get screwed in the end.
Read up on it, watch tons of videos on it. Know exactly what you're doing and what needs to be done before you even start. Take it or leave it, that's my .02
Joey _________________ Old VW's and Old Motorcycles. |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Tue Mar 04, 2014 12:00 am Post subject: |
OMG yes, please do your research before attempting to do this. that spring is no joke. even with the car jacked up with the wheels off the ground, there is a LOT of tension in the torsion bar. Its putting a lot of downward force on the springplate. When you jack the plate upwards, you want to use a prybar to pull the plate out, JUST A LITTLE BIT!!! just enough to clear the stop. you should only need to pull it out like 1/8''. just make sure your hands are no where near the spring plate itself, incase something slips, or the jack fails.
And depending on which way you go about moving the trialing arm out of the way, I like joels method better, about taking the pivot bolt out. but it needs a 17mm allen wrench to do so. if you decide to remove the CV bolts, advance auto sells the proper 6mm tool. its in the specialty tool section, and its called a "12pt triple square" bit set. basically like allen wrenches, cept with the 12 point ends. it only comes in a 4 pack (3 other sizes besides 6mm). but its cheaper on CIP1 if you don't mind waiting on shipping _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
TJ's68Beetle Samba Member
Joined: June 07, 2011 Posts: 7 Location: Rising Sun, MD
Posted: Tue Mar 04, 2014 5:16 am Post subject: |
This guy makes it look easy. Well except for the whole grinding thing. But he does explain why he has to do it and it's something that can be avoided if you can get everything apart correctly.
http://www.youtube.com/watch?v=ocO0Tf8z_vQ |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33512 Location: Hot Arizona
Posted: Tue Mar 04, 2014 6:59 am Post subject: |
| BugMan114 wrote: |
| I like joels method better, about taking the pivot bolt out. but it needs a 17mm allen wrench to do so. |
But such 17mm allen wrench is also needed to fill and drain the transmission.
| BugMan114 wrote: |
| if you decide to remove the CV bolts, advance auto sells the proper 6mm tool. its in the specialty tool section, and its called a "12pt triple square" bit set. basically like allen wrenches, cept with the 12 point ends. it only comes in a 4 pack . |
I'm pretty darn sure these use the 8mm size: the 8M Triple Square. They are NOT Torx. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13960 Location: White Mountains Arizona
Posted: Tue Mar 04, 2014 7:23 am Post subject: |
I would not work on that in shorts and flip flops for safety reason. To me that is just plain stupid. The grinding thing nope nadda. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Mar 04, 2014 8:52 am Post subject: |
Yes, I have both 8mm star drives and 17mm allen for tranny so either one will work. I like the pivot way better.
GT: I ALWAYS work in shorts and flip flops but I definitely will not be doing so for this job! Thanks for the advice, definitely don't want someting falling on my foot even though I'm sure a shoe won't protect me if the car falls on me  _________________ one, two, many
one too many |
Posted: Tue Mar 04, 2014 8:57 am Post subject: |
| Cusser wrote: |
| BugMan114 wrote: |
| BugMan114 wrote: |
I'm pretty darn sure these use the 8mm size: the 8M Triple Square. They are NOT Torx. |
Oops, sorry. Brain fart. Yes I do believe it's the 8mm one. I just did the disc brakes on my super which uses a 6mm allen, and I guess just had it on my brain, lol. That 4 pack has a 6, 8, 10, and 12 or 13. And no it's not a TORX bit. Torx is 6 point. These are 12 point
And I've never tried Joel's method, because I never thought of it, lol. Ive always disconnected the CV which is a royal pain in the ass. But I need to lower the rear of my 72, and will try it out. _________________ 1974 Super Beetle: Custom resto in progress
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Cusser Samba Member
Posted: Tue Mar 04, 2014 11:42 am Post subject: |
| LeninCas wrote: |
| GT: I ALWAYS work in shorts and flip flops |
Aren't you the guy who hurt his hand pretty badly working on the VW recently??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Joel Samba Member
Posted: Tue Mar 04, 2014 3:21 pm Post subject: |
| Cusser wrote: |
| BugMan114 wrote: |
Just about any junkyard will give you a free 17mm wheel bolt from a watercooled VW, Audi, BMW, Merc etc then you just need a wheel nut with the same thread (M12x1.5 very common) and weld the 2 together and you have a free trans drain plug/pivot bolt tool
Posted: Tue Mar 04, 2014 9:17 pm Post subject: |
Cusser,
Yes, that was me. Silly mistake. It actually happened when pulling out a tranny..... and I WAS wearing flip flops.
Definitely not working like that again though. Scary, valuable lesson. _________________ one, two, many
one too many |
EXJAY Samba Member
Joined: October 04, 2009 Posts: 1109 Location: Myrtle Beach, SC
Posted: Mon Apr 25, 2016 1:29 pm Post subject: Re: How many hours approx. to lower the rear end? |
So where Im stuck at is I have the CV, shock disconnected, removed bump stop, scribe/marked the plate orientation and removed the bolts and torsion cover. I cannot drop or raise the trailing arm enough to clear the spring plate and my e brake cable is pretty tight. Seems Im at the same point as the flip flop dude but refuse to cut or notch the plate to clear. I looked at my training arm piviot bolt and appears someone had stripped out the allen head portion so that's not really a option to remove. Any ideas? _________________ EXJAY
'74 Superbeetle (Family owned since new)
'73 181 Thing (sold) |
EXJAY Samba Member
Posted: Tue Apr 26, 2016 6:26 pm Post subject: Re: How many hours approx. to lower the rear end? |
Update to my issue above: Found I needed to free up more of the e-brake cable and brake line for just enough to get the plate over. Once I got the t-bar loose and adjusted up (one inner to lower the rear some) I could use a large screw driver to leverage it back on the perch since it was now physically closer to it. (Never used a spring plate tool for this job) _________________ EXJAY
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Wed Apr 27, 2016 5:00 am Post subject: Re: How many hours approx. to lower the rear end? |
| I just unbolt the pivot arm from the spring plate (after marking the position of the arm on the spring plate), remove the torsion end cap, and chain the car to the jack, lever it off the stop, and let it settle back down SLOWLY. |
Cusser Samba Member
Buggeee Samba Member
Joined: December 22, 2016 Posts: 5023 Location: Stuck in Ohio
Posted: Tue Feb 14, 2017 4:13 pm Post subject: Re: How many hours approx. to lower the rear end? |
Is it possible to lower one side more than the other? Can I put it up a little on one side to fix this using the spline method?
I got this bug as a project, the build thread is below, so I don't know the history. But its lowered all around.
The rear is not on the bump stop on the driver side but it is on the bump stop on the passenger side. The drivers axle is straight. The passenger axle angles up (or put another way, the car sits lower on the passenger side). Could it have been dropped an extra spline on that side as a mistake when it was lowered? Or is this something else. I'll try this spline adjustment technique on the one side if that is what I should do. Here are the two pictures.
Thank you Samba people.
_________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
vamram  Samba Member
Posted: Tue Feb 14, 2017 4:21 pm Post subject: Re: How many hours approx. to lower the rear end? |
At the very least I'd bet the one shock is shot and the other not far behind. Spring plate and torsion bar bushings are probably worn out as well. Get yourself the tools others have used for this, order replacement bushings from Wolfsburg West, and get to work! _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
