Are Empi Lug Bolts unsafe?
Rathbone
Rathbone is offline
PostPosted: Sat Mar 22, 2014 7:27 pm    Post subject: Are Empi Lug Bolts unsafe? Reply with quote
I don't know why I thought I could buy anything Empi and not have problems. Everything I've ever bought of that brand I've had to return or throw away. But I wanted to replace the old rusty lug bolts since I'm putting on new wheels and I was having trouble finding the right size chrome bolts. They arrived today and I attempted to install them by hand using a T bar. Of the 20 bolts I stripped one out and broke one off inside the wheel drum. I guess if I'd been using an impact wrench they would all have broken off.
Normally after installing bolts I'd drive a few miles and re-tighten them. I'm afraid to try these or they may break off. I've never had this problem before with any car. am I doing something wrong?
So what are people using for lug bolts? Should I just count this as an $80 loss and throw them in the trash?
So here is the buggy with new front wheels that now match the rear:
And the offending bolts:
(o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal
Rathbone
Rathbone is offline
PostPosted: Sat Mar 22, 2014 7:30 pm    Post subject: Reply with quote
Lo Cash John
Lo Cash John is offline
PostPosted: Sat Mar 22, 2014 8:38 pm    Post subject: Reply with quote
Never tried the EMPI lug bolts but I will say some of their products ARE good. If I were you I'd contact the seller about a refund. If they give you any grief, be prepared to contact your credit card company (ALWAYS use a cc when buying car parts) to help settle the matter.
BTW, the buggy is looking awesome!!!
www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
MOON BUGGY
MOON BUGGY is offline
PostPosted: Sat Mar 22, 2014 8:49 pm    Post subject: Reply with quote
doesn't surprise me in the slightest.
If you look up the word Empi in the dictionary it means poor quality cheep Junk.
I only use Empi if theirs no other option.
Rathbone that is one nice looking buggy!
"Dune Buggies and Watermelon Rock! .” (MOON BUGGY)
kevin3406
kevin3406 is offline
PostPosted: Sat Mar 22, 2014 8:59 pm    Post subject: Reply with quote
im an advocate of the press in studs. DORMAN part number 610-024 worked great on my 65 Baja, along with BALL SEAT lug nuts. cost me 90 bucks & I pressed them in myself. definitely money well spent!
[insert various aircooled vehicles here] if the women dont find you handsome, they should at least find you handy.- Red Green
wythac
wythac is offline
PostPosted: Sat Mar 22, 2014 10:34 pm    Post subject: Reply with quote
I don't have any personal experience with that kind of hardware but I have heard from others that some of the aftermarket lug bolts don't have the appropriate degree of taper on the mating shoulder on the bolt. This can lead to rim damage as well as bolt failure.
I can't really tell looking at your rims but they may not have the same taper as a stock beetle rim, which may be another reason the empi ones failed. Worth taking a look at anyway.
I think your next set of lugs should come from WCM or another high quality parts supplier. Were I you, I would look at the failure during installation as a blessing.
slalombuggy
slalombuggy is offline
PostPosted: Sat Mar 22, 2014 11:45 pm    Post subject: Reply with quote
I use EMPI press in studs and trust my life with them at high speeds. Use a torque wrench and fasten to 75ft/lbs. That's all I ever torque lug bolts to even with autocross slicks.
brad
Tom_Kathleen
Tom_Kathleen is offline
PostPosted: Sun Mar 23, 2014 3:05 am    Post subject: Reply with quote
May be a case of hydrogen embrittlement. If you use high strength steel and don't heat treat it after nickel or chrome plating, that can happen. When we 1st built Kathleen's buggy, I had the rotors nickel plated with the Moroso 1/2" race studs in them. I broke several of them off by hand with a small breaker bar taking the wheels on & off several times like you have to when building a car. Don't trust any of those bolts now. Tom
Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Sun Mar 23, 2014 3:31 am    Post subject: Reply with quote
I use stock vw bolts with a cheap set of slip on chrome covers from an eBay supplier.
They look great.
andk5591
andk5591 is offline
PostPosted: Sun Mar 23, 2014 4:25 am    Post subject: Reply with quote
Tell ya what I use for lug nuts.....a freakin' torque wrench....
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
dan macmillan
dan macmillan is offline
PostPosted: Sun Mar 23, 2014 5:59 am    Post subject: Reply with quote
Rathbone wrote:
I would never even consider using those bolts. Threaded portion much too short and threads are cheap. They will probably fail far below VW's recommended torque
Stock lug bolt. design for comparison.
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
Lo Cash John
PostPosted: Sun Mar 23, 2014 6:39 am    Post subject: Reply with quote
Every
Mistake
Passes
Inspection
Laughing
Dale M.
Dale M. is offline
PostPosted: Sun Mar 23, 2014 6:43 am    Post subject: Reply with quote
Only way to go..... Note the "press in" not "screw in"....
Besides studs make wheel mounting so much easier....
Check for "stud installation" threads in wheels and tires section of forum.... Several good how to's over last few years ....
Dale
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Mar 23, 2014 6:54 am    Post subject: Reply with quote
Always use a torque wrench, when available, to tighten lug nuts/bolts.
If they are breaking by hand..yeah.. they are JUNK.
Send them back for a refund.. lick your wounds.. and move on.
They look great.
Yep...
I wanted chrome exposed lugs on my "Operation X'..
I didnt like ANY of the chrome lug bolts found for the Wide 5's.. mainly the quality looked BAD..
and since I have good drums.. no need for studs..
Picked up a pack of 30 plastic chrome lug nut caps..for $25 including the remover tool.
Done..
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Rathbone
Rathbone is offline
PostPosted: Sun Mar 23, 2014 8:26 am    Post subject: Reply with quote
They weren't that short before they broke off in my drum.
pallen
pallen is offline
PostPosted: Sun Mar 23, 2014 8:38 am    Post subject: Reply with quote
I have those same empi ones on my buggy... They seem decent quality and I have been torquing them to 90 foot pounds, have had them on and off multiple times.
I wonder if the 1 set of 5 were from a bad batch or something.
Buggy Build > http://www.thesamba.com/vw/forum/viewtopic.php?t=499786
Ecotec Street Rail Build > http://www.thesamba.com/vw/forum/viewtopic.php?p=8146270#8146270
wythac
wythac is offline
PostPosted: Sun Mar 23, 2014 8:56 am    Post subject: Reply with quote
Take a look at the difference in the shoulder on those two bolts from Moore parts and from Empi. Not the same at all..
VOLKSWAGNUT
PostPosted: Sun Mar 23, 2014 9:10 am    Post subject: Reply with quote
The nut/bolt seat all depends on the wheel used.
VW original 5 x 205 wheels use a Ball or Bulge seat (not cone)
Use the correct nut/bolt seat for the wheel used.
If wheels are changed from original, sometimes a different seat style must be used as well.
aka Ken {o\!/o}
grinNbarritt
grinNbarritt is offline
PostPosted: Sun Mar 23, 2014 10:55 am    Post subject: Reply with quote
your buggys lookin sharp! Jim
VOLKSWAGNUT
PostPosted: Sun Mar 23, 2014 12:53 pm    Post subject: Reply with quote
I agree.. the red with those white wheels sure pop...
Good looking combo
aka Ken {o\!/o}
