Installing door panels
Page: Previous  1, 2
Clara Premium Member
Clara is offline
PostPosted: Wed Mar 26, 2014 3:05 pm    Post subject: Reply with quote
Bret Young wrote:
Another question somewhat similar to this topic. Might as well ask it here instead of starting a new thread.
Any of you guys out there have issues with your door mechanisms in your front doors rattling?
Any processes/materials that you guys use to minimize rattles? Now is the time to address it. Dont want to have to pull the panel off to fix noises.
Is this a bus with the icepick outer handle?
does the mechanism have the rubber sheathing over the black piece between the part for the outside handle and the part for the inside handle?
That gets tucked in the hook of the door.
That makes no sense w/o a pic, but often that part of the door breaks off, and also the rubber anti-rattle sheathing has fallen off years ago.
otis_bartleh
otis_bartleh is offline
PostPosted: Wed Mar 26, 2014 3:32 pm    Post subject: Reply with quote
Bret Young wrote:
Maybe part of my rattling noise is because the door handle isnt installed yet. I am assuming once you put that spring under the door panel and put the pin into the handle it will put some tension on the mechanism.
I have been driving my bus for a month without door panels (put the door handle on when I need to get out), but I get a decent amount of rattling around inside my door.
Anyone else noticed this?
Yes, mine rattled a bit too with no panel on, and yup, went away when I put the panel, spring, and handle back on.
-Adam
'59 Mango Bus
'69 Bug - Cobalt Blue
otis_bartleh
PostPosted: Wed Mar 26, 2014 3:37 pm    Post subject: Reply with quote
Hmm, I have the black piece on mine, not sure about the sheathing though. But with the panel on it doesn't rattle anyway, so that's good.
-Adam
'59 Mango Bus
Bret Young
Bret Young is offline
PostPosted: Wed Mar 26, 2014 4:07 pm    Post subject: Reply with quote
Yes. Ice Pick door handles. My bus was built in Nov. 63
The handles have the black rubber seal between the handle and the door, but I dont remember seeing any other rubber pieces in there during the assembly of the bus.
Rubber anti-rattle sheathing? Anyone have a picture of what that should look like?
PostPosted: Wed Mar 26, 2014 5:42 pm    Post subject: Reply with quote
Rubber pieces here
Bret Young
PostPosted: Wed Mar 26, 2014 8:04 pm    Post subject: Reply with quote
Rubber pieces here
My mechanisms have those on them still. That little sheathing dampens noise? Hmm. Interesting.
Maybe the door panel installation will fix the vibrations.
Red Fau Veh
Red Fau Veh is offline
PostPosted: Tue May 24, 2016 10:35 am    Post subject: Re: Installing door panels Reply with quote
Well I want to use the existing holes on my doors and Clara mentioned this tool, but I couldn't quite figure out what it looked like. But here is a drawing and all makes sense to me now, its ingenious! Cool
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
Stocknazi
Stocknazi is offline
PostPosted: Tue May 24, 2016 4:39 pm    Post subject: Re: Installing door panels Reply with quote
I just made one of these today with a piece of pallet-banding.
I folder a piece over on itself, drilled one hole for a screw/bolt near the middle; drilled another hole through the end with a small enough hole a short screw would thread into the banding and secured with Loctite.
It works awesome. Wish I would have made one years ago.
Thanks to all who posted the information.
WANTED:
Thomas Jefferson
bustermot
bustermot is offline
PostPosted: Tue May 12, 2020 1:49 pm    Post subject: Re: Installing door panels Reply with quote
Hello all, Thanks to everyone who posted in this area. After much procrastination and with quarantime on my hands.I just finished installing WW panels on my 61 SC using advice from some of the posters, clara, stock nazi and one other who i can't remember. I have some pointers.
I tried buying the expensive hole finding tool. It did not work well, except on the front roof panels. Elsewhere the bulge next to where the panels sit is in the way. Unless you get a hole finding tool that has real bendy metal, don't bother. I'll explain how I did it based on a modified method someone else put forth. To be fair; for maybe 10 holes out of maybe 70 it worked well.
I spray painted the backs of all of the panels with 123 primer. Be careful, it is easy to get paint on the nice side if you aren't a careful type. yeah.
I waxed the edges of the panels with a candle to help with any water that could drop on the edges from open windows. I used unscented white candle. For one part that I mashed a little I actually melted the wax and kinda stuffed it in the papery area.
I removed the inner door handles.
I removed any existing panel screws or gunk.
I pounded down existing holes even those not to be used to be flush so panels seat well.
I vacuumed out, then blew out the inside of the bases of the doors.
I affixed a shower curtain to the door using duct tape, making sure it is up where the screws will be so that they keep it in place. But not visible when panels are in place.
Now here is the part I hadn't fully read about before, just the first half of the method;
I put a 1.5 inch strip of masking tape at the edge of all locations of where I determined screws should be--the tape -running parallel to the edge line bulge of the door ( or the panel itself when it is there) and perpendicular to a line drawn from that tape line to the hole or the location of the hole to be made.
Some existing holes will work for the screw diameter in the WW kit, some are too big. Ones that are too big are not used, therefore a suitable location super close is determined and the tape method is employed; Here it is... I marked the location on the making tape using pen with a dot or line or arrow, whatever.
I then put another piece of masking tape perpendicular to the one already down (on all tape put down). The edge of this tape runs directly over that little hash mark andthe hole or the to-be hole. That spot is marked (Imagine there being a panel there, then make the mark. it'll be raised in the air like a few millimeters by the panel.) I also marked up where the tape sat in relation to the other tape in case it got knocked off I could replace it without bending the panel to hell to look under it.
It is necessary to bend the tape backwards or the introduction of the panel will hide all of the little tape tails swinging in the wind.
Then put the panel in place and clamp it with a giant clamp if you don't have friends with socks you don't mind smelling nearby, that is.
Put handle back on, with escutcheon helping hold the panel now.
Gently put tape in place being careful to pull with even force so the mark on the tape is right over where you will place your drill bit tip.
Starting on the upper right rear screw, using a 1/8" drill bit screw the first hole in the panel making sure the panel is in the correct position, because there isn't much movement after this, Put that screw and washer in place. Then do the one on the bottom right corner of the door.( see clara)
One thing to note is that of course most times you will hit the exact hole and you just go through, on the areas where you are making holes in the metal there will be resistance and you have to drill into the metal. This may not appeal to some people with more valuable super stock vehicles. Most of these vehicles have multiple holes from previous owners so it is an easy thing to not sweat.
Repeat many times. And it looks great I think, yay. I will post pictures later. I just had to write this up having just done it.
One note, WW was out of kick panels when I ordered so I got a set from Jbugs. They are waaaay lighter in color than WW, so light they should be painted grey to match. Or I might have my daughter paint a mural on them. They die eventually anyhow, why not.
hitest
hitest is offline
PostPosted: Tue May 12, 2020 3:39 pm    Post subject: Re: Installing door panels Reply with quote
Great write up! I employed this exact technique a few years ago during camper panel replacement day. I only had one near hole miss- causing a slightly crooked screw install near the floor of a panel. It's a very rewarding job. and nice to know I drilled zero new holes in my camper.
FU#5
dirtyfrank
dirtyfrank is offline
PostPosted: Sun Oct 18, 2020 2:30 pm    Post subject: Re: Installing door panels Reply with quote
I’m gearing up for the door panel install, and I made a hole finder tool using stuff I had laying around the house. I found some old metal blinds and cut a couple short sections to size. Drilled a hole, and attached both sides together with a small nut and bolt. Then drilled a hole to match the original holes in the door. Installed another small nut and bolt, and then filed the head and the threads of the bolt down. I used a vice grips to bend the tool to roughly match the curved ridge around the inner rim of the door. I hope this helps somebody else!
missmybus
missmybus is offline
PostPosted: Sun Mar 21, 2021 4:25 pm    Post subject: Reply with quote
Clara wrote:
cru62 wrote:
As an aside, I was looking at the rear hatch on my Kombi and noticed that there are tiny pilot holes punched into the inner frame right where the screw holes for an inner trim panel would go. That way there would be a hole for the tip of the screw to go into when the panels are being installed. I noticed several on the cargo doors as well. I didn't see any on the front doors, but that would be because there were door panels installed which would necessarily use the pilot holes.
I saw a pair of NOS early doors at a show once. But they were some kind of crossover door with icepick handles and the door panel buttons, so no pilot holes.
My point is that it doesn't make sense to try and use the trim screws to start a hole as they would skitter all over the place. And predrilling would be immensely time consuming. Pilot holes just make more sense.
Cab door panels (pre mid Dec 1963) did not have standardized screw placement, and NOS doors did not have screw holes. (Dec 63 & later, with push button handle, cab doors had the holes for the clips)
Door panels from one bus won't have all the holes line up if you move them to another bus.
Cargo door panels do have standard door placement. There are holes punched in from the factory. Smile
You can screw through the panel into the holes, they are the right size for the interior panel screws. Though I like to use a drill bit on the panels rather than the screws.
Rear hatch 55-63 also has standard screw placement, and factory holes.
You can transfer cargo door panels or 55-63 rear hatch panels from one bus to another and the holes will line up.
Hey Clara, when I picked up my panels a few weeks ago Greg mentioned a slightly longer screw that he uses. I’m having issues with the front door panel and the short screws from WW. Do you know the dimensions of the ones he uses? They were longer which will help. Thanks, Brian
64 Deluxe
campingbox Premium Member
campingbox is offline
PostPosted: Sun Mar 21, 2021 9:45 pm    Post subject: Re: Installing door panels Reply with quote
I’ve always found the WW screw sets were fine for the cab door panels. It was the bulkhead panels I recommended some longer ones but for your bus they may want rivets instead. I’m not 100% sure when the change was but you can probably tell by the existing holes in the bulkhead.
Try metric specialties or Metric MCC. It’s a slotted oval pan head screw. They carry them. If you measure the size and length I expect they will have something longer for you with the same head size.
junichi
junichi is offline
PostPosted: Thu Jul 03, 2025 12:56 am    Post subject: Re: Installing door panels Reply with quote
I’ve gotten pretty good and making mistakes that others can learn from. Firstly, I bought the wrong kick panels for my 64. This is painfully obvious when ordering from Wolfsburg West, but the later have cutouts for some vents that the earlier kick panels lack. 64 is a crossover year, so you have to check a lot of parts before ordering.
I didn’t make a hole finder since I found it would be very hard to use on the kick panels due to lack of clearance. I just measured and ended up slightly missing most holes, but no big deal on the little screws. I just drilled a couple new holes.
For the doors, my 64 has standardized locations for the clips. The holes are pretty big, so a plastic sheet template worked. I’d do the hole finder for the small screws on earlier doors. The bonus of the plastic template is you can trim and use the same plastic sheet for vapour barrier if you want. Then I layed it all flat, template on top and just poked a little dent at each hole location. Once on the bus, I clamped the panels to the door and drilled a tiny hole to check location, then bigger, then full size. I went one hole at a time with the big drill bit, checking that nothing shifted. Or so I thought. When I got to the bottom, it had shifted! The panel was about 1/4” low, having slipped during my drilling and pushing in clips. Make sure to clamp well and check your door panel alignment often! I had to pull the clips, adjust the panel and then bore out several of the holes in their new locations. In some cases, the hole is not completely covered by the head of the clip. : ( When I did the next door, I actually started at the bottom as there is less margin for error on the alignment. That was successful. All in all, the method worked well on the second door, but a little more care in keeping the panel aligned would have been great for the first one!
I used Clara’s tutorial for the ceiling panels and had no issues. For the screws to hold it in at the back on the roof member, I just eyeballed it and was able to hit every existing hole.
1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf
Clara is offline
PostPosted: Thu Jul 03, 2025 9:40 am    Post subject: Re: Installing door panels Reply with quote
FWIW, I offer the cab door panels with the 12/63- 67 clip holes pre-drilled.
Vents for the foot heat means your bus was buildt 4/64 or later.
I now make 4/64-67 kick panels with the mounting holes pre-drilled. This version of the kick panel has standard hole placement, the earlier ones don't. The hole for by the foot vent for 64-65 is near the top of the vent, for 66-67 at the bottom corner of the vent. So I pre-drill that hole partway. Check your bus and drill the rest of the way through the one that matches your bus before installing the kick panels. The metal on the nose by the foot heat grill is a little different as well 65 compared to 66.
VW installed the cab door handles pointing forward and up at about a 45* angle. Pulling up should open the door. Spin the forward part around if it works the other way. I recommend you check that the door mechanisms work smoothly, and lube them, before installing the cab door panels. Lube the 64-67 door props too, that'll ease strain on the lower door hinges.
junichi
junichi is offline
PostPosted: Thu Jul 03, 2025 1:54 pm    Post subject: Re: Installing door panels Reply with quote
Thanks, Clara! I will fix my door handles. I didn’t know how they were set so I appreciate that tip. I did spend some time getting them working right- especially getting the driver’s door to lock. So far so good!
Page: Previous  1, 2
Page 2 of 2
