Portland Steve Samba Member
Joined: January 28, 2012 Posts: 15 Location: Portland Oregon
Posted: Sat Apr 19, 2014 11:09 am Post subject: New Squeaking Brake Pads |
Hi,
I've finally got my new brakes to stop squealing.
I replaced everything, new Brembo rotors with bearings and seals, Rebuilt Calipers, ATE Brake Pads. I did some front end work 1st replacing the top ball joint and the tie-rod ends.
You think with all that I would have minimal brake noise but no, I was a screaming 83 Vanagon going down the road.
I started by checking the rotor bearing axle nut, 1 seemed too loose so I tightened it just a little so the rotor didn't have any play and re-peaned the nut.
Then I got a brake pad lubricant as described in many reviews; Brake Pads Silicone Lubricant - ATE 70015. This was applied to all areas where the metal contacted other metal parts but mostly between the brake shim and the brake pad.
Lastly I found a reference to chamfering the brake pad edges. The ATE brand does not factory chamfer its pads. I put a 1/4" 45 degree bevel on the leading edges of the pads with my bench grinder.
Sadly I found later that the Bosch QuietCast has a special rubber shims and is also factory chamfered. In hindsight this would have been my 1st choice.
Still with these all these improvements all of my brake noise is gone.
I wanted to share so you can benefit from my search. |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2074 Location: Ontario Canada
Posted: Sat Apr 19, 2014 11:14 am Post subject: |
and sometimes just using them for a hundred miles will clean off any dust or dirt and that cures the squeal _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
williamM Samba Member
Joined: August 07, 2008 Posts: 4342 Location: southwest Arizona
Posted: Sat Apr 19, 2014 11:38 am Post subject: |
NAPA has so orange rubber shit that you can coat both sides of the pad shim with- it works sometimes. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Terry Kay Banned
Posted: Sat Apr 19, 2014 12:09 pm Post subject: |
Scuffing upper the face of the new rotors with some 80 on a DA prior to installation will allow the pads to seat faster without the squeaking. _________________ T.K. |
Terry Kay Banned
Posted: Sat Apr 19, 2014 12:10 pm Post subject: |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8431 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Apr 20, 2014 8:54 pm Post subject: |
Half a dozen hard stops from 55mph can shake out the squeaks.
Gotta get through the glaze & seat those new pads to the rotors...
 _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
