Convert. top removal
mkullman
mkullman is offline
PostPosted: Wed Jul 09, 2003 7:49 am    Post subject: Convert. top removal Reply with quote
Is there a way to remove the complete top from the car for painting??
[email protected]
new2buggin@sbcglobal.net is offline
PostPosted: Wed Jul 09, 2003 9:24 am    Post subject: Convert. top removal Reply with quote
Three bolts on the hinge mounts on each side and then remove the cables on the rear, should come off as 1 piece then.
Greg
ach60 Premium Member
ach60 is offline
PostPosted: Fri Jul 11, 2003 12:35 pm    Post subject: Convert. top removal Reply with quote
Don't forget the wires for the rear window defroster.
Good Luck
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
mkullman
mkullman is offline
PostPosted: Fri Jul 11, 2003 11:30 pm    Post subject: Convert. top removal Reply with quote
I see the hinge bolts - no problem. I am not sure where the cables are?? Also it looks like the inside liner is nailed down just below the hinges and a couple of other places behind the back of the seat - I assume I carefully pull the nails. Also there are two screws on the outside on either side screwed through the top and then sheet metal. The rest of the top - bottom seems to go under a lip on the body - do I have push down then up to clear this lip?? Thanks for the help!!
WOWBUG
WOWBUG is offline
PostPosted: Wed Jul 16, 2003 9:25 pm    Post subject: Convert. top removal Reply with quote
The rear cable holds it under that lip. loosen the nuts on either side just behind where the top frame bolts to the body and remove the cable.
j.pickens
j.pickens is offline
PostPosted: Wed Jul 16, 2003 10:22 pm    Post subject: Convert. top removal Reply with quote
marksalot has it right.
Once you loosten the cable, you'll see how simple it is, really nice design.
Yes you have to pull the staples holding the fabric to the inside wood frame along the rear car body.
mkullman
mkullman is offline
PostPosted: Sat Jul 19, 2003 1:08 pm    Post subject: Convert. top removal Reply with quote
It's off!!!! Thanks to marksalot, j.pickens and new2buggin!!!
Hopefully putting it back on after paint will be as easy??????
