Dreaded1's build
Dreaded1
Dreaded1 is offline
PostPosted: Fri Apr 25, 2014 7:21 am    Post subject: Reply with quote
small update
I had charging issues with the generator all last summer so I decided to go with the alternator swap. It went smoothly except the alternator worked for week, then failed, had it rebuilt, worked for another week then stopped charging again. After that the rail was put on the back burner due to buying a house.
The weather finally broke here in the north east so I fired it up last weekend. Still no charge so I pulled the alt one more time for a rebuild, the shop said the alt was fine. So I retraced my wiring all the way again, and found the 10g wire that went from the alt to ign inside the center console had fallen off. I never inspected it before because it was in the console and was a simple crimp, maybe I should have. Last night I replaced the 10g with 16g and replaced the diode set up with a dummy light. Did not have a chance to fire it up and check everything out because I finished at 11pm and I did not want to wake up the neighbors.
With all the charging issues hopefully fixed I can move on to other things.
The threads that hold the throttle cable to my current gas pedal are stripped and barely holding so I upgraded, definitely need the bumper and I hate the current stinger exhaust.
I will try to get some new pictures later.
dirtkeeper
dirtkeeper is offline
PostPosted: Fri Apr 25, 2014 7:35 am    Post subject: Reply with quote
Not totally familiar with the alternator wiring specifically but if the original wire was a 10g.. A 16g wire is probably not appropriate
Dreaded1
Dreaded1 is offline
PostPosted: Fri Apr 25, 2014 7:41 am    Post subject: Reply with quote
I installed the 10g and it was overkill., it only needs to carry 12V.
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Wed Jun 18, 2014 4:38 am    Post subject: Reply with quote
It's not the voltage that determines gage it's the current.
Was just reading through your write-up because you mentioned something about kayaks and I'm researching kayak racks. I like your rig. Very unique. Have you found time to do anything with it recently?
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
Dreaded1
Dreaded1 is offline
PostPosted: Wed Jun 18, 2014 5:43 am    Post subject: Reply with quote
Thank you, I had to make it unique because I am 6' and the cage was just too small for me.
Time and money are very scarce these days. I am running in 2 rally events in July so I am saving for those. Trying to find time to hook up with my friends that know how to weld is a PITA during the summer. I have a rear bumper I want to install, purchased a dual cannon exhaust that I want to return because I did not research the performance aspects of them before I ordered them. I also need to get a new canvass cover made because the old one no longer fits after raising the windshield.
Still toying with the roof rack idea for mounting a kayak but that is still in it infancy due to my lack of welding skills and time constraints.
fishybastard
fishybastard is offline
PostPosted: Wed Jun 18, 2014 6:48 am    Post subject: Reply with quote
I like to cage mods to make it bigger. Im 6'2 amd my noggin sits about 2 inches below my upper bar. I am tying to figure out how to make more room in it. Looks good!
Dreaded1
Dreaded1 is offline
PostPosted: Wed Jun 18, 2014 6:54 am    Post subject: Reply with quote
We were going to raise the cage 6 inches but it looked too goofy. After a trial fit 4.5 inches worked out well. If I needed more room I would have lowered the seats an inch or so below the frame. With ~13 inches of ground clearance I would not have been sacrificing much.
fishybastard
PostPosted: Wed Jun 18, 2014 7:25 am    Post subject: Reply with quote
I am thinking about just moving both of my upper bars in so it will kinda look like the old "t" top cars. That will give me enough room.
Dreaded1
Dreaded1 is offline
PostPosted: Wed Jun 18, 2014 7:34 am    Post subject: Reply with quote
That was another option we thought about, but mine already had the custom canvass top installed, and moving those bars would require me to get that remade. Luckily there are very few rails in the northeast so nobody really notices how much different the cage looks now.
fishybastard
PostPosted: Wed Jun 18, 2014 7:57 am    Post subject: Reply with quote
Well it looks good. Looks like its a lot better to drive now too with the steering wheel moved
Dreaded1
Dreaded1 is offline
PostPosted: Wed Jun 18, 2014 8:02 am    Post subject: Reply with quote
Ha! I forgot that moved too, and I put a larger wheel on. It is 100% more comfortable to drive now.
fishybastard
PostPosted: Wed Jun 18, 2014 9:18 am    Post subject: Reply with quote
You were quite wedged in it before! Looks like you actually fit now!
71StandardReduction
71StandardReduction is offline
PostPosted: Wed Jun 18, 2014 5:19 pm    Post subject: Reply with quote
The pic of your head poking through the canvas made me laugh out loud uncontrollably!
Then I realize that's probably how I look playing with my children on the play grounds.
It looks good with the lifted top, most people over think the idea of more head & leg room and never are really satisfied with the mods they make, I think that was a good idea and it didn't take away from structure or ground clearance.
I happen to like ground clearance and a flat pan makes it more usable.
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
https://www.thesamba.com/vw/forum/viewtopic.php?p=10355566#10355566
Ruby Red 1966
https://www.thesamba.com/vw/forum/viewtopic.php?t=779597&highlight=
66 Baja
https://www.thesamba.com/vw/forum/viewtopic.php?t=792544&sid=1cfbb0e31e0ef24f8a1e9379e16fb18f
Dreaded1
Dreaded1 is offline
PostPosted: Fri Jun 20, 2014 7:52 am    Post subject: Reply with quote
It is definitely a better fit now. I am still tempted to buy a new frame and pull everything off this one and put on the new one. The head room in the one is fine but it is still a bit narrow.
Vanapplebomb
Vanapplebomb is offline
PostPosted: Tue Feb 10, 2015 10:19 pm    Post subject: Reply with quote
Where did you get those grab handles on the top of your rail? They look nice.
1800 Type 4 Berrien 295
Dreaded1
Dreaded1 is offline
PostPosted: Wed Feb 11, 2015 9:41 am    Post subject: Reply with quote
I picked them up in the local auto parts store, I think it was NAPA. They are just generic velcro grab handles for a Jeep or UTV.
Dreaded1
Dreaded1 is offline
PostPosted: Thu Apr 30, 2015 8:03 am    Post subject: Reply with quote
I had decided to pull the engine this weekend to replace seals and gaskets. My buddy swung by last night to drop off his toolbox. Neither of us had anything going on so we got started last night. 3 hours later we had it removed and apart. Not bad for our first time. He was used to working on larger engines so it was easy for him. I would post pictures but it doesn't seem like the image tag is working right now.
We didn't run into anything that looked disastrous when took the valve covers or heads off. Friday we will replace the seals and whatever else came in the kit I purchased.
The pics can be seen on the last page of this thread in this link if you are interested.
http://www.unysoc.org/board/index.php?topic=9488.msg170688;topicseen#msg170688
Bashr52
Bashr52 is offline
PostPosted: Fri May 01, 2015 4:17 am    Post subject: Reply with quote
IF I can make a suggestion, re-think your exhaust decision. I agree stingers are loud as hell, but you can go with like a bobtail style or something. I have one on my baja and it has a way better sound than the stinger I had on there (not my car in the pic).
ORANGECRUSHer
PostPosted: Fri May 01, 2015 4:36 am    Post subject: Reply with quote
I agree. I think when it's time that is what I will get as well. Right now I have the Bugpack that has the headers arranged similarly but the muffler sits at a vertical angle higher up and exits to the passenger side. I like it but it shakes so bad that it's literally vibrating itself apart. First the muffler bracket broke away from the muffler. Then when I replaced that the tab off the muffler snapped off at the weld. Just to much leverage on that muffler although it does sit nice and close to the engine. When I make my cage I will leave room for one of these Tri-mils.
Brian H.
Dreaded1
Dreaded1 is offline
PostPosted: Fri May 01, 2015 4:58 am    Post subject: Reply with quote
I understand that I will be losing horsepower by installing the dual exhaust. Unfortunately it's already purchased and I am ready to put the engine back together tonight. My plan is to run the duals for this year and if the HP loss drives me crazy then I will purchase a different style for next year.
Page 3 of 4
