First Air cooled.. 70 Camper.
Page: 1, 2, 3 ... 12, 13, 14  Next
khalimadeath
khalimadeath is offline
PostPosted: Tue Jun 24, 2014 6:56 pm    Post subject: First Air cooled.. 70 Camper. Reply with quote
O boy do I have some stupid questions.. Ive been searching but I figure I can ask here and find them easier. Ive been an Audi Guy since I was 18 and the oldest VW I have owned is a Corrado.
I picked up this 70 VW (bus, Westfalia, bay, type2a)??? How would I classify my new project. I got it with NO rust, only rust is in the battery tray. Its really amazing how rust resistant this Bus has been. plus for 1600 bucks running and driving and very complete you cant beat it.
Also Im trying to figure out the best cheapest way to do a disc brake swap in the front.
Where are some of the best places to order parts?
What are the bars on the hinge things in the top of the pop up? Also is there supposed to be anything up there besides more head room?
also when driving my shifter linkage feels really sloppy, it goes back into 1st when im trying to get into third. Is there a kit I can replace all the linkage with?
Whats the best place to buy Subaru motor swap parts?
Thanks for any help. Im pretty excited to get started, everything seems to be there i just need to update it and tighten it up.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Tue Jun 24, 2014 7:10 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=165001
Here's the bay stickies/facts thread. There's tons of info in here that will answer most of your questions.
Nice 70!
The Samba member since 2004.
tolstoy
tolstoy is offline
PostPosted: Tue Jun 24, 2014 7:21 pm    Post subject: Reply with quote
Man.....with all the 70's popping up lately, I feel like we need to start a 1970 club! What is the deal with your turn signal switch?
The sun is the same in a relative way, but you're older. Shorter of breath and one day closer to death.
'70 Westy
VWDruid
VWDruid is offline
PostPosted: Tue Jun 24, 2014 7:38 pm    Post subject: Reply with quote
ASAP get all engine tin in place and that carb looks to new be stock check the jets!
60 to 65 idle, 127.5 to 130 main, air 125?
70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit
khalimadeath
PostPosted: Tue Jun 24, 2014 7:44 pm    Post subject: Reply with quote
not sure. Some hack job aftermarket turn signal attempt.. Not sure how its supposed to look or what supposed to be on there but there are a bunch of wires. Most of the lights work.
khalimadeath
PostPosted: Tue Jun 24, 2014 7:45 pm    Post subject: Reply with quote
Yea guy I got it from put it in there. Ive never re jetted a carb so when I pull the motor im gonna check it out.
Kansas Rob
Kansas Rob is offline
PostPosted: Tue Jun 24, 2014 7:59 pm    Post subject: Reply with quote
http://www.busdepot.com/231101
1968 Beetle
1969 Westy
khalimadeath
PostPosted: Tue Jun 24, 2014 8:01 pm    Post subject: Reply with quote
Yes thats awesome!!
Kansas Rob
PostPosted: Tue Jun 24, 2014 8:13 pm    Post subject: Reply with quote
This is my first year with the camper also.
Those camping trips are truly epic.
I replaced my cot earlier this year.
Good place to stash a kid.
Bus depot has good canvas replacements for your pop top too.
Good luck man.
1968 Beetle
1969 Westy
skills@eurocarsplus
Samba Peckerhead
PostPosted: Tue Jun 24, 2014 8:16 pm    Post subject: Reply with quote
you are going to want your corrado back Laughing
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Danwvw
Danwvw is offline
It has a folding hammock "cot" up top needs cot material to be sewn on. I think Porsche 944 front disc brakes fit. The aftermarket kits to make them disc are pretty spendy and rare! Looks like it's a single port 1600 which should get a little better gas milage. Be nice to rebuild it as a 1971 Dual port engine though! Keep your eye's open for a rebuildable core complete dog-house engine! (Got to have the 3 point rear mount holes in the case!) Or if you have a good dual relief case you could just buy the dog-house fan shroud etc and put dual port heads on. The Dual DRLA or IDF carbs are the way to go on these early bay window busses like ours.
It great that you got a camper! So nice to have a camper! We never want to drive our other cars.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
khalimadeath
PostPosted: Tue Jun 24, 2014 11:38 pm    Post subject: Reply with quote
Im interested in the 944 brake swap we have at least 5 at my local pick an pull. Any links to this swap that can confirm they will work?
Danwvw
Danwvw is offline
PostPosted: Wed Jun 25, 2014 10:02 am    Post subject: Reply with quote
While this link does not answer the question it is a good resource for the differences in bus brakes and years: Disc Brake Conversions,
And Here in this link about rims RCR Jacob's of Vacaville, CA has them: Info on porsche wheels write up. Looks like it's a 1974.
rcrjacob wrote:
I have 944 spindles for the front. Will run 944 vented rotor and wilwood 4 piston calipers. Rear setup is from oldspeed. 944 rear discs with drum in a disc ebrake. Redrilled rear hubs and 944 vented rotors. Stock 944 calipers. I allready have the hubs and brackets for the calipers on the front, and have the complete setup minus rotors for the rear. I can't wait to put them on.
Will be running 18x8 Turbo twist wheels with 245/40/18 tires.
Skoolieman
Skoolieman is offline
PostPosted: Wed Jun 25, 2014 10:49 am    Post subject: Reply with quote
Out of curiosity why do you want discs up front?
'69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion
Tcash
Tcash is offline
PostPosted: Wed Jun 25, 2014 12:51 pm    Post subject: Reply with quote
Tcash wrote:
Here is a little information. Good Luck
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
Volkswagen Type 2 Bus M-Plate Decoder
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
khalimadeath
PostPosted: Thu Jun 26, 2014 2:31 pm    Post subject: Reply with quote
Drum brakes are teh suck IMO. I honestly just want disc up front. I also want the options of swapping to a different wheel type. I plan on lifting slightly and running some meaty tires.
khalimadeath
PostPosted: Thu Jun 26, 2014 2:33 pm    Post subject: Reply with quote
Hmm good to know I will hafe to read up about that some more.
The more I read the more I think it may be too expensive to swap front and rear. If anything i may just get the disc front to fit the wide 5.
khalimadeath
PostPosted: Wed Sep 03, 2014 9:21 am    Post subject: Reply with quote
Finally getting to work! Happy to say I am pleased with the condition of everything. Couple odd things but overall stock with little to no molesting from previous owners. No hacking, no weird wiring.
Once the motor was out I pulled the fuel tank cover to check things out. No rust inside at all and the fuel tank looks pristine. So i sealed it back up since id rather not touch it if i'm not having any issues with it.
I have a few questions in this thread I started of you can help..
http://www.thesamba.com/vw/forum/viewtopic.php?t=605981
Otherwise here are some pics:
Found why it was hard to get it into gear. Parts of the throw out bearing was lying in the bellhosuing.
Wrong dizzy? New Solex H30 31PICT carb running rich?
khalimadeath
PostPosted: Mon Sep 08, 2014 11:33 pm    Post subject: Reply with quote
So my Engine case has a U for the first letter. What does that mean? I thought it was supposed to have an A?
Brian
Brian is offline
PostPosted: Mon Sep 08, 2014 11:37 pm    Post subject: Reply with quote
Means it probably came from a Type 3
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Page 1 of 14
