mattegan Samba Member
Joined: July 01, 2013 Posts: 57 Location: Atlanta, Georgia
Posted: Sun Jul 06, 2014 8:19 am Post subject: Mounting Engine on Engine Stand? - Incompatible Mount? |
Hey guys. I just pulled the engine out of the car yesterday.
Stopped at Harbor Freight and picked up the 1000lb stand (was going for the 750lb, but they were out of stock, and the nice woman at the counter offered a coupon to make the 1000lb cheaper than the 750lb, which was cool). Anyway, I've heard that this one is a better choice anyway because it's of the "H" style feet instead of the "T" style.
So, last night, I tried to get the engine onto the mount, but I just can't find a configuration of the four arms on the yoke that let me get all four onto the engine.
However, I've seen multiple people use mounts that only hook into the bottom two studs on the engine. (Glenn's post on engine mounts has a custom yoke that just locks onto the bottom two).
Would it be bad for the engine to mount it on the stand by the bottom two studs only?
Thanks guys! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33571 Location: Hot Arizona
Randy in Maine Samba Member
Posted: Sun Jul 06, 2014 9:08 am Post subject: |
| You will be mounting the engine so that it only supports one side of the engine. I like that to happen on the 3/4 side myself. 1 bolt/nutand one spacer/nut for the bottom engine stud. |
Her74buggy Samba Member
Joined: September 29, 2013 Posts: 367 Location: Houston
Posted: Sun Jul 06, 2014 10:38 pm Post subject: |
No issues..... |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16800 Location: North Florida, USA
Posted: Sun Jul 06, 2014 11:04 pm Post subject: |
Sounds like you bough one of these engine stands meant for most other engines:
The mounting head for acvw/Porsche engines is different (borrowed from Glenn):
You can find just the heads on eBay:
http://www.ebay.com/sch/i.html?_kw=vw+engine+stand
Here is a whole thread on the subject:
http://www.thesamba.com/vw/forum/viewtopic.php?t=288599 _________________ AshMan40
Posted: Mon Jul 07, 2014 8:43 pm Post subject: |
Okay, so, I got my dad involved and we got creative. We didn't feel safe just getting two or three of the mounts onto the engine, especially because the mounts had large flanges that would be riding up against the lip on the back of the crankcase.
We had some scrap lying around, so we took a piece of cardboard and pressed it up against the lip on the back of the engine (between the crank and the flywheel) to make an impression after rubbing some engine oil on the lip.
We cut this lip out, cut four pieces of bar stock (1/8 inch thick, 3 inches wide) to five inches long, and then traced this lip onto one of the shorter edges. This allows the piece to sit against the lip and distribute the forces a little more evenly along the lip, instead of just meeting at one point and having the sheering forces reliant on the friction between the adapter plate and the crankcase.
We cut holes to mount the engine studs through, then cut some holes to facilitate the mount we got from harbor freight, these were about halfway up the adapter plate (2.5 inches in, we first tried right at the opposite edge, but these actually were too large, and were out of the range of the yolk).
This worked a charm. Only problem was the flat part of the bottom studs on the engine, I just took a stack of washers that was tall enough to cover the flat part, and clear the flywheel, and then ground one side of the washers flat so they would fit by the flywheel.
Here's a picture for all interested!
(We discovered we needed two washers between the mount and the adapter to space the mount outwards so the bolts that held the mounts to the yolk plate could clear the flywheel.)
(Here you can see the curvature we ground into the adapter so that it would fit the flange.) |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80679 Location: Sneaking up behind you
Posted: Tue Jul 08, 2014 3:47 am Post subject: |
Buy the yoke from VW Alley, it's well worth it.
You need the right tool for the just, it's like used a slotted screwdriver to remove a Philips screw. It can be done but you risk damage and hurting yourself. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Tue Jul 08, 2014 5:15 am Post subject: |
It is going to be tough to split that case.
I have that same engine gizmo that came with my Hrbor Freight 1000 pound stand.....I put it someplace for the next non-VW engine I work on. |
Glenn  Mr. 010
Posted: Tue Jul 08, 2014 6:00 am Post subject: |
I also have the 3 arm version at the shop and it provides more support for the case. The last thing you need is for the stand to break off the mounts surface on the case... then its junk.
Yes, it's on the wrong side of the case. _________________ Glenn
Member #1009
#BlueSquare
75smith Samba Member
Posted: Tue Jul 08, 2014 5:03 pm Post subject: |
if you have scrap metal
you can use all 4 universal arms, and still support the engine by the flange without putting alot of stress on it...and you can actually split the case
having used it for a while, I can say that the good one glen has could certainly be worth it, especially if you start to "build" engines _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Posted: Tue May 05, 2015 4:52 pm Post subject: |
Well, here's a long needed update for you guys. I didn't want to pay for the expensive one, and I knew my previous solution wasn't very so good.
So, with the generous help of a mechanical engineering friend, we used Solidworks to dimension out the back of the engine, and then to design a bracket to extend the holes outwards.
Here is the first iteration, which was laser cut out of some wood to check for fit. We were almost on this first try.
A few more design iterations before we had something that we were confident about (made a few more tests on the laser cutter first), and a little modification of the design itself. Here's the CAD model.
I bought a relatively cheap steel plate for about 40 dollars from McMaster-Carr and we went and picked it up south of Atlanta since I was impatient. We split the part in two with a "puzzle piece" fitting so that we could fit it onto a smaller piece of metal, which reduced the cost of the raw material from 100 dollars.
A few nervous moments later... and...
What's awesome, is that without planning it, we created a perfect press-fitting between the two halves. The water jet has some conical cutting shape (the beam spreads slightly as it cuts through the metal) which ended up making this perfect. We put the two halves into a clamp and just tightened down, and...
Turned out absolutely perfect.
What's even cooler is the stud that's already in the engine misses the engine mount completely, so there's no problem of the stud hitting the arms or anything.
And here are a few more shots. Hope you like!
Now to start putting this engine back together..... |
VW_Buggsy Samba Member
Posted: Tue May 05, 2015 6:49 pm Post subject: |
Hey your ad up on the classifieds, I'll buy one of those!
Nice work! |
awreed Samba Member
Joined: January 14, 2010 Posts: 1267 Location: Kirkland, WA
Posted: Tue May 05, 2015 6:55 pm Post subject: |
The only time I've ever used an engine stand was when I accidentally dropped a washer in the pedestal stand hole right after I buttoned up the long block. I like to assemble everything on the ground where I can still move it around (or onto a dolly) by myself.
That said, good job on the yoke adapter. Looks pretty cool. You sure you don't wanna weld those two pieces together though? Not that they're going anywhere after bolting onto the case half, but still...
Good luck with the rebuild. |
kamesama980 Samba Member
Joined: June 22, 2014 Posts: 323 Location: Columbus, IN
Posted: Wed May 06, 2015 7:31 am Post subject: |
| VW_Buggsy wrote: |
Nice work! |
No kidding, since it's CAD/CNC cut just make up about 20 and put them up for sale. I'd be down for one (I'll be welding the joint though) _________________ -Russell
"You don't get to blame me for how I fix what you break"
1970 VW Beetle
1994 Pontiac Firebird
2001 BMW R1200C
2003 Subaru Baja |
ldsvwguy Samba Member
Joined: September 16, 2003 Posts: 1025 Location: Saratoga Springs, UT
Posted: Sun Jan 08, 2017 3:46 pm Post subject: Re: Mounting Engine on Engine Stand? - Incompatible Mount? |
Are you still making those adapters? _________________ "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car." |
Charitha Samba Member
Joined: March 07, 2021 Posts: 11 Location: Victoria, Down Under
Posted: Sat Mar 20, 2021 8:57 pm Post subject: Re: Mounting Engine on Engine Stand? - Incompatible Mount? |
Does anyone know what the PCD is for the mounting studs and holes
cheers |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1650 Location: Buford GA
Posted: Sun Mar 21, 2021 4:18 am Post subject: Re: Mounting Engine on Engine Stand? - Incompatible Mount? |
KISS
Glenn  Mr. 010
Posted: Sun Mar 21, 2021 5:00 am Post subject: Re: Mounting Engine on Engine Stand? - Incompatible Mount? |
Sorry but the right tool for the job. Last think you need is the crack the mounting flange on the case. _________________ Glenn
Member #1009
#BlueSquare
Dark Earth Samba Member
Posted: Sun Mar 21, 2021 5:46 pm Post subject: Re: Mounting Engine on Engine Stand? - Incompatible Mount? |
This is what I use.
_________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Posted: Mon Mar 22, 2021 2:59 am Post subject: Re: Mounting Engine on Engine Stand? - Incompatible Mount? |
| Thanks guys. well i just got a standard engine stand, not a VW one. hoping to improvise something with a few pieces of sheetmetal. i agree with Glenn, i do not want to damage the case in any way. so i'm just taking the time to figure something out. |
