1977 Westfalia Slow start
aok-samba
aok-samba is offline
PostPosted: Wed Jan 29, 2014 10:27 am    Post subject: 1977 Westfalia Slow start Reply with quote
1977 Westfalia FI 4 speed (not sure what size engine, different people tell me different things)
I'm really not sure what the deal is here. Used to start great, now it doesn't, regardless of cold or warm weather. I know that my Air Flow Controller is getting worn, but I don't feel that has much to do with how quickly it starts. If you listen, once it starts, it idles low, that's the Air Flow Controller, I believe. Hard to find a replacement for those. But my main problem here is the slow start.
- Battery tested, great!
- Replaced points, have an electronic ignition now
- replaced starter connections
- Checked grounds
Is starting like this going to be wearing out other parts?
Could it be the solenoid? (I have instructions on how to verify in the John Muir handbook, but not sure if that'd be wasting my time)
Anything helps! Thanks!
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jan 29, 2014 10:41 am    Post subject: Reply with quote
does slow starting mean that the engine turns over slowly when you turn the key?
If this is the case you want to monitor battery voltage as it turns over slowly. Batteries often will show good voltage sitting but drop when used.
If the battery voltage holds at 11.8 to 12V when you crank, next check the voltage between cables at the battery and see if it is the same. If it is, check the voltage at the starter post where the cable attaches and car ground. If it is still 11.8 to 12V then I would suspect the starter, the starter bushing, too thick oil etc. However my best guess is that your battery tests Ok under no load or a small load but it can't handle the engine.
George Carlin:
Skills@EuroCarsPlus:
kkjellquist
kkjellquist is offline
PostPosted: Wed Jan 29, 2014 10:48 am    Post subject: Reply with quote
I just went through this recently....I discovered the tachometer I installed was wired to an 'always on' fuse and creating a parasitic draw on the battery. It doesn't take much!
Test the draw on the battery....you need a decent multi-meter and it's easy.
Here's one link on how;
http://www.youtube.com/watch?v=KF1gijj03_0
1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/
aok-samba
PostPosted: Wed Jan 29, 2014 1:59 pm    Post subject: Reply with quote
I'm sensing that the main culprit could be the battery, so I'll check that first.
@kkjellquist: Thank you! I will get that checked out first. I don't have a multi-meter but perhaps I should pick one up! I've played with them before and have almost killed myself. I try to stay away from that stuff, but might be handy to have.
@SGKent Basically as you see it in the video, it cranks for 5-30 seconds and then starts realllll gradually. Regardless I'll check that out for sure, thanks so much!
Wildthings
Wildthings is offline
PostPosted: Wed Jan 29, 2014 5:54 pm    Post subject: Reply with quote
If it cranks that long before it starts then something is getting nice and hot. Feel around and find out what it is. When you say you replaced the connection, does that mean you used the temporary replacement cable ends. If so you probably have added resistance in the system and should consider replacing your cables with new ones.
Yes any one bad part of the charging and starter system will overload and shorten the life of the other parts. The slower an engine turns the higher the current draw and the more energy being wasted as heat.
heerojyuy
heerojyuy is offline
PostPosted: Wed Jan 29, 2014 6:56 pm    Post subject: Reply with quote
Is the ground strap from your transmission hooked up?
Surprising how much that little strap can affect things.
1979 Volkswagen Bus - Daily Driver
2000cc
FI
kkjellquist
PostPosted: Thu Jan 30, 2014 5:52 am    Post subject: Reply with quote
aok-samba wrote:
@kkjellquist: Thank you! I will get that checked out first. I don't have a multi-meter but I should pick one up! !
fixed that for ya. Wink you shouldn't own a bus without one.
merlinj79
merlinj79 is offline
PostPosted: Thu Jan 30, 2014 8:55 am    Post subject: Reply with quote
Like others have said, check all the connections at the battery, the battery neg ground where it bolts to the wheelweel, both tranny ground strap connections, and the connections at the starter.
Make sure they're all clean and tight. I wire brush them periodically and use di-electric grease to fend off corrosion. I agree that you might have a bad fitting on one of those wires but it should be getting plenty hot in this case.
As to whether the solenoid works, well it's kind of "all on" or "all off". If the motor is turning the solenoid should be fully engaged. If it's getting really hot maybe it has an internal short and is sucking up all the juice. But I'd expect it to get at least warm with all that cranking.
Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff
aok-samba
PostPosted: Fri Jun 27, 2014 10:45 am    Post subject: Reply with quote
I thought I would post a reply, though this is totally late, but all of the above were to blame on the Air Flow Meter. You can pick up a rebuilt one, just gotta find the exact one (right amount of pins, correct year). There is a number on the part that identifies which is currently in there, and a couple of guides online will tell you which part exactly yours works with.
Can't believe how much smoother she runs!
Manfreds78bay
Manfreds78bay is offline
PostPosted: Fri Jun 27, 2014 11:00 am    Post subject: Reply with quote
Nice work on the fix. Do you mind if I ask what kind of exhaust you have?
1985 VANAGON GL Digijet
There is no spoon.
aok-samba
PostPosted: Sun Jul 13, 2014 2:17 pm    Post subject: Reply with quote
I'm not sure what kind of exhaust – how do I find out? :/
Manfreds78bay
PostPosted: Mon Jul 14, 2014 8:01 am    Post subject: Reply with quote
get down there and take some pics and post.
There is no spoon.
Ludwig van
Ludwig van is offline
PostPosted: Mon Jul 14, 2014 9:35 am    Post subject: Reply with quote
I'm experiencing a slow start issue as well, but only on the first start-up of the day. After that, it seems normal. I'm only using the bus to run errands, so subsequent shutdowns are usually short - no more than an hour.
If I turn the key to 'on' for 5 or 10 seconds before turning it to 'start' for the first time, the start-up is much quicker. (stock 1978 California-delivered FI bus)
I'm wondering if the fuel pressure regulator is losing pressure while the bus is parked for extended periods. I don't smell fuel, so I don't suspect a leak. Should the regulator hold pressure when the engine is shut off?
If I'm wrong in my suspicion, does anyone have any other ideas?
'78 Sage Green California Westy 'Ludwig Van'
Our iPad e-book "Camping With Ludwig Van"
http://store.blurb.com/ebooks/356253-camping-with-ludwig-van
Tcash
Tcash is offline
PostPosted: Mon Jul 14, 2014 9:38 am    Post subject: Reply with quote
Hi
There are some good pix in the Bentley Service Manual.
Wildthings
PostPosted: Mon Jul 14, 2014 3:27 pm    Post subject: Reply with quote
Yes the fuel pressure regulator is supposed to hold pressure for an extended time. There are leakdown rates given in the manual. But no, if you turn the key on for 10 seconds prior to cranking it will not prime the system, no priming should occur until you turn the key to the "start" position. I am wondering if your FI or FP relay is getting sticky or weak and being slow to close. For starters, you might check and clean your FI grounds.
Ludwig van
PostPosted: Mon Jul 14, 2014 8:36 pm    Post subject: Reply with quote
Thanks for the suggestions, Wildthings. I need to use the bus while I address a problem in the daily driver, so I'm reluctant to take anything apart just now, but I'm sure I can find a minute to look at those grounds.
udidwht
udidwht is offline
PostPosted: Tue Jul 15, 2014 2:31 am    Post subject: Reply with quote
Ignition switch
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
Bala
Bala is offline
PostPosted: Tue Jul 15, 2014 6:57 am    Post subject: Reply with quote
How old is your battery and how did you test it?
1976 Westy
1966 Beetle
SGKent is offline
PostPosted: Tue Jul 15, 2014 7:35 am    Post subject: Reply with quote
udidwht wrote:
Ignition switch
that is my vote too. Or the battery
George Carlin:
Ludwig van
PostPosted: Tue Jul 15, 2014 11:13 am    Post subject: Reply with quote
The battery is only a couple of years old and seems to be in good condition, although I haven't tested it lately. Cranking speed is no different from what I'm used to, it's just the amount of cranking to get the bus to start for the first trip of the day. After that, it's fine. The ignition switch is a little fussy, mostly related to the steering lock function. Sometimes, I have to turn the wheel to the right, putting pressure on the steering lock, to get the key to turn.
The big mystery is why this only happens on the first start of the day, and why leaving the ignition on for 5-10 seconds seems to correct it. I'll try it a few more times to rule out coincidence, but due to the nature of the problem, I only get one or two tries a day.
Is there anything temperature-related that might cause this issue, and go away if the ignition is left on for a bit before the first start?
