Solar Mythbusting: 100 Watts Solar in the Luggage Rack?
Howesight
Howesight is offline
PostPosted: Sat Apr 26, 2014 9:52 am    Post subject: Solar Mythbusting: 100 Watts Solar in the Luggage Rack? Reply with quote
I have been researching and searching for some time on line for portable or other solar panels that will fit in the luggage rack or another handy space in my Westy. This is a work in progress.
I have no intention of leaving the panel(s) in the rack while in use since I want the van in the shade and the panel(s) in the sun. My criteria are based on a few considerations:
1. Solar panel should be quick to set up;
2. If I want to camp, but don't need to set up solar overnight, the panel(s) should NOT BE IN THE WAY; This means that any indoor/inside panel storage solution needs to be carefully thought out;
3. If carried on the roof or roof rack, the panel(s) should be flush or easily removable for height reasons. (I can just get my Westy in the garage with ballast aboard (Mrs. Howesight and daughter).
Research is ongoing, but here's a reasonably-priced item from Renogy that, by my measurements, will fit in the luggage rack:
http://www.renogy-store.com/100W-Suitcase-p/kit-stcs100d.htm
Another option:
Flexible, thin panel(s) stored in the upper bed "sandwich" when driving. I would probably use 2 of these panels. They are less than a quarter inch thick. I don't need the flexible attributes, just the thinness for storage. I would add a DIY frame/easel for portable set up:
http://www.renogy-store.com/100watts-bendable-panel-p/rng-100db.htm
For those in Western Canada who are not picky about storing a folding solar panel in the luggage rack ( as I am), here's a heck of a deal in Burnaby, BC:
http://www.papsolar.ca/
His units are:
100W FOLDING SOLAR PANELS $289
120W FOLDING SOLAR PANELS $329
140W FOLDING SOLAR PANELS $379
I have dealt with this gentleman in buying a solar setup for Howesight Junior who wilderness dry camps with a 4x4. We got the 140W unit which works very well. Remember that all these folding units do not use a sophisticated charge controller, but they are so cheap that you can make up for this with more watts. When you decide to get nerdy, you can bypass the cheap controller, combine the 2 panels into 24V nominal, and use a good MPPT controller to maximize total power utilization.
While researching, I found the informative, if crotchety, blog of Solar Bob who cuts the crap so you don't have to. Here's a link:
http://handybobsolar.wordpress.com/the-rv-battery-charging-puzzle-2/
Main points emphasized by Solar Bob (he is not brief):
1. RV dealers get 80% of their solar installations wrong.
2. Mainly, they use wire gauges that are too small, both panel to controller and controller-to-battery and also battery-to-inverter (for those who use inverters), and they do installations that allow or force partial shading of solar panels.
3. Most people either buy a solar charge controller that charges at too low a rate and is not adjustable for a higher rate, or fail to set the charge controller at the correct charge voltages for the three or four stages of charging.
4. Most people do not get a proper state of charge battery monitor and never know the true state of charge of their batteries.
5. As a result, most solar setups leave the batteries chronically under-charge which wastes all the expensive solar capacity they bought and leaves users short of power and kills expensive batteries prematurely.
6. You MUST charge at voltages, current and time recommended by the battery manufacturer, not the charge control manufacturer or some other guru. These voltages and rates differ between models and manufacturers.
7. Gel Cell batteries are a poor choice for solar set ups because they can only accept a lower charge rate than AGM (Absorbed Glass Gat)or flooded lead-acid batteries. AGM batteries, with proper charge controller properly set up, charge fastest, next fastest is flooded lead acid.
8. Flooded lead acid batteries give best value for dollar/cycle. They do require monthly equalization charging to address stratification of the electrolyte. They also need to be watered with distilled water from time to time. AGM batteries are more suitable for vehicle locations where gassing from charging cannot be tolerated or physical jarring of the battery is likely.
9. Solar Bob preaches the importance of buying, before anything else, a proper battery monitor. He recommends the TriMetric TM-2030 monitor by Bogart Engineering:
http://www.bogartengineering.com/
So do many people and many happy customers. Google TriMetric TM-2030 and see.
10. Bulk and absorption charging for AGM and flooded lead acid batteries MUST be at 14.8 volts, NOT the 14.2 or 14.4 that most solar controllers either use or, if programmable, use as default settings. Some batteries bulk charge at 15.2 volts. ALWAYS use the battery manufacturer's specs for charging rates, not the charge controller information.
Here's an excellent link for learning about battery and charging information:
http://batteryuniversity.com/learn/article/how_to_measure_state_of_charge
'86 Syncro Westy SVX
PDXWesty
PDXWesty is offline
PostPosted: Sat Apr 26, 2014 10:11 am    Post subject: Reply with quote
Check here as well. They often have 120watt folding panels for $199 but they are out. Here's a 160 watt setup that may fit.
http://www.solarblvd.com/Solar-Panels-&-System..._info.html
Another topic:
http://www.thesamba.com/vw/forum/viewtopic.php?t=573136
89 Westy 2.1 Auto
Corwyn Premium Member
Corwyn is offline
PostPosted: Sat Apr 26, 2014 3:46 pm    Post subject: Reply with quote
I bungee my100 watt panel to my Yakima bars. When I camp, I take it down and put it in the sun, while I park in the shade(30' cord). Simple.
'90 White Westy ("White Lightning")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
Howesight
PostPosted: Sat Apr 26, 2014 8:45 pm    Post subject: Reply with quote
Hey Corwyn:
You have a great and simple approach. Unfortunately, I can't use a rack and still get in the garage, hence the nerdy research.
goffoz
goffoz is offline
PostPosted: Sat Apr 26, 2014 9:31 pm    Post subject: Reply with quote
I use a 120W foldable, thru a cig plug wired direct to each battery, when camping.
I use a 20W thru the dash cig plug on an isolated Aux battery, daily, this works to keep everything full capacity thru the colder less travelled months.
So far most of the "solar on the roof" threads have semed Bogus for me
The controllers don't isolate, as well as pulling the plug Rolling Eyes
IE: if I leave it all plugged in overnight..cranking battery is close to dead in the AM.
Un plug it at sundown, good to go next day Very Happy
I don't care what the specs say..
...Real World Xperince.(RWX)proves it WRONG
Corwyn is offline
PostPosted: Sun Apr 27, 2014 6:16 pm    Post subject: Reply with quote
Howesight wrote:
Hey Corwyn:
The rack comes off. I only put it up to carry the solar panel and other camping items.
FAS Gen V 2.0
~ Captain Ron ~
Steve M.
Steve M. is offline
PostPosted: Sun Apr 27, 2014 7:10 pm    Post subject: Reply with quote
This setup is using a controller that is built into the back of the panel. Just thinking a separate controller is better just in terms of having an independent controller that is easily replaced if it fails as opposed to having it built into the panel.
yycwesty
yycwesty is offline
PostPosted: Sun Apr 27, 2014 7:21 pm    Post subject: Reply with quote
I think it would be great to have a foldable panel that would fit in the luggage rack which you could plug in. Therefore, while driving you have a 50 watt panel charging things. Unplug it and then plug it into the side of the van and you can now open it up and use the full 100 watts..
madspaniard
madspaniard is offline
PostPosted: Sun Apr 27, 2014 8:53 pm    Post subject: Reply with quote
I have this same foldable 120w panel. Three things I did to it. Converted all connections to MC4, got rid of the 16 awg wire extension for remote deployment of panel (made my own marine grade 12 awg extension and also upgraded all other small wire runs to 12 awg) and removed controller from panel (it only takes two very small bolts) so that I can use my on-board controller which is also controlling my rooftop solar panel. I still keep the controller I removed just in case I want to use this foldable panel in another vehicle.
yycwesty
yycwesty is offline
PostPosted: Sun Apr 27, 2014 9:31 pm    Post subject: Reply with quote
madspaniard
does this unit you have fit folded in the luggage rack?
madspaniard
PostPosted: Sun May 04, 2014 11:01 am    Post subject: Reply with quote
yycwesty wrote:
madspaniard
The 120w version does not fit in luggage rack when folded up and stored in the bag it comes with, just by a few inches. However, it dies fit perfectly over the engine lid or rear mattress over engine lid.
The 100w version might fit in luggage rack.
aspendog
aspendog is offline
PostPosted: Tue Jun 10, 2014 8:05 pm    Post subject: Reply with quote
Just ordered the Renorgy 100 watt folding unit. I'll be testing it out in two weeks for a trip east.
91 Westy
02 Passat
outwesty
outwesty is offline
PostPosted: Mon Jun 30, 2014 11:30 pm    Post subject: Reply with quote
I'm curious. How did this panel work for you ? These renogy folding panels look to be the next best deal since the solar blvd ones. I ordered one but have not used it yet. The quality of the panel looks very nice.
If you go to their Ebay store you can get them for $250 shipped right now. For a MADE IN THE USA panel it looks to be a good deal. I know the included charge controllers on portable panels are usually junk but these look much better than any others I've seen. They are fully parameter adjustable as well. At 19.8x27.1x2.3 it fits behind the upper bunk too.
edit I just heard back from Renogy. The panels are not USA made. If you read some of the customer reviews it appears that they are. oh well. still a nice looking panel.
Howesight
PostPosted: Mon Jul 21, 2014 9:56 pm    Post subject: Reply with quote
Here are a few pics of my solar set up. Very happy so far.
The Renogy 100W panel, with "briefcase" fits in the luggage rack. Despite my modified pop-top, my luggage rack is stock sized.
I hard-mounted the solar charger inside where I could easily see the panel and have the charge controller at the same temperature as the Trojan battery.
I re-purposed the city water connection into a solar connector with MC4 connectors.
Trojan battery, Surepower battery separator, 80 amp main circuit breaker:
Ghetto Battery cover prevents short circuits from my under-seat items:
15 amp, 12V circuit breaker is my fool-proof "solar off" switch for those times I fail to set the charge controller setting properly for solar panel disconnect. For the Where's Waldo crowd, find the spare rad hose and spare brake hoses:
And here's why I like to be able to move my solar panel. The Howesights at Lillooet Lake where the first part of the day required constantly moving the panel. That's the price you pay for the waterfront campsite, I suppose:
Westified
Westified is offline
PostPosted: Tue Jul 22, 2014 7:41 am    Post subject: Reply with quote
Howesight can you have the panel open in the luggage rack? If so, does it fit below the top lip of the rack so it can't be seen? I wanted my panel to be charging even when I drive to a hiking trail and park there for several hours. I would like it to be stealth for security reasons. Looks like a nice setup you have. Good price to.
1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022.
Howesight
PostPosted: Tue Jul 22, 2014 12:30 pm    Post subject: Reply with quote
No, the panel only fits in the luggage rack folded. Using solar while driving is not particularly useful. Remember that you only have 100 watts of solar power if everything is perfect. While driving, you cannot guarantee you will have sun, variations in sun will make your charge controller work poorly (they take time to "shift gears", so to speak), and you will not use the huge, consistent, charging power of your alternator. I find the solar panel most useful if I know I will not be running the engine for a couple days or more.
One caveat: If you have a stock WBX engine, you need to upgrade the alternator by installing an adjustable voltage regulator. Stock Vanagon alternator voltage regulators put out low 13 volt numbers. You need to have 14.4 to 14.8 volts for best charging. Here's a link to one seller:
http://vwparts.aircooled.net/Adjustable-Voltage-Re...ulator.htm
madspaniard
PostPosted: Tue Jul 22, 2014 1:02 pm    Post subject: Reply with quote
It would be ideal to find a bendable type solar panel to fit in the luggage rack so that you can top off your batteries while parked for days or weeks at home without moving the van but the dimensions of the luggage rack don't usually match up to typical solar panel dimensions for effective use of this space.
Howesight
PostPosted: Tue Jul 22, 2014 2:07 pm    Post subject: Reply with quote
Agreed. If the flexy panels came in luggage rack size, I think I might have got myself a couple of them, but alas, no small flexies yet.
I have a theory about the flexy panels: Now that the actual solar cells that are used to build a panel are so cheap, manufacturers are looking for a way to reduce the cost of supplying aluminum frames and glass and the high shipping costs. Looks like they found a solution, yet we end consumers are paying more to get less. Hmmmmm . . .
