Fuel Pump Replacement
Page: 1, 2, 3  Next
Colonel Mosby
Colonel Mosby is offline
PostPosted: Sun Jul 27, 2014 9:27 am    Post subject: Fuel Pump Replacement Reply with quote
Well the Colonel sure could use your help. I have a 1970 VW Bus. I believe the fuel pump is failing. I have fuel in the engine oil. I have a light fuel leak around the two gaskets on the fuel pump flange/base. I ordered the parts from Wolfsburg West. Here is what I have. The pump. New flange. Two gaskets. Long push rod. I noticed the original fuel pump has the VW stamp on it. The new one is a Brosol. The orginial has a screw inlet for the metal fuel line and the outlet is a rubber hose to the carb. The new pump will not accept the metal line screw. I was wondering if there are any thoughts on how to proceed. How do you bridge from metal screw inlet on the pump to the metal line? I was thinking now maybe I should get the rebuild kit instead of the new pump? I thought this was going to be very easy. I am sure it still is. Appreciate any suggestions!
Code:
[img]http://www.thesamba.com/vw/gallery/pix/1236479.jpg[/img]
babysnakes
babysnakes is offline
PostPosted: Sun Jul 27, 2014 9:31 am    Post subject: Reply with quote
Cut the metal line and use a piece of fuel hose for the bridge.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 27, 2014 9:34 am    Post subject: Reply with quote
It'd be a shame to cut the end off the threaded fuel line, you may be able to push the nut back a few inches on the line and put a hose on the end. The VW pump is the best you will get but the quality of the rebuild kits lately has been really dissapointing, if you do go the rebuild route try to find an older NOS one.
Слава Україні!
Colonel Mosby
PostPosted: Sun Jul 27, 2014 9:35 am    Post subject: Reply with quote
Just behind the distributor I have a brass fitting. You can't see it in the picture. Should I just disconnect the metal line from the pump, disconnect the brass fitting, get a fuel hose, cut, clamp, done? Do you know what size of hose might work. Thank you for the reply.
Colonel Mosby
PostPosted: Sun Jul 27, 2014 9:37 am    Post subject: Reply with quote
I like your suggestion. Perhaps I could do this until I get the VW pump rebuilt with a NOS.
Brian
Brian is offline
PostPosted: Sun Jul 27, 2014 9:39 am    Post subject: Reply with quote
I think its either 1/4" or 5/16" for the hose
I'll take that pump off your hands though.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
busdaddy
busdaddy is offline
PostPosted: Sun Jul 27, 2014 9:47 am    Post subject: Reply with quote
5.5mm is what VW used but German braided fuel line is dangerous when combined with modern fuels, 1/4" is a little loose but will work, don't skimp on clamps, the worm ones cut into the line, spend a couple bucks more and get the good ones:
When shopping for line get one with a J30R9 rating or higher preferrably with a barrier liner, most FLAPS have it, ask for fuel injection hose.
Слава Україні!
Colonel Mosby
PostPosted: Sun Jul 27, 2014 9:59 am    Post subject: Reply with quote
That is what the guys at WW said. I did not pay enough attention to that threaded part and was not expecting that. I think I can do this though with no trouble. Heading down to the flaps to see what they got.
babysnakes
PostPosted: Sun Jul 27, 2014 10:01 am    Post subject: Reply with quote
I PM'd you, busdaddy says you should be good with that.
Brian
Brian is offline
PostPosted: Sun Jul 27, 2014 10:08 am    Post subject: Reply with quote
http://www.airheadparts.com/vintage-vw-parts/new-l...-111198555
I'd take this over that Brazilian
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
busdaddy
busdaddy is offline
PostPosted: Sun Jul 27, 2014 10:33 am    Post subject: Reply with quote
Beware, I was recently told of a new rebuild kit failing in only a couple hundred miles, the end of the pull rod apparently wore away, China strikes again Crying or Very sad
I don't know where he got the kit but he's not a cheapskate so it would have been a supposedly good quality one, it's likely all the kits come from the same supplier anyways.
Слава Україні!
kreemoweet
kreemoweet is offline
PostPosted: Sun Jul 27, 2014 10:37 am    Post subject: Reply with quote
That's not the right rebuild kit for the OP's pump. Some of the parts
might work. If the main diaphragm, which is probably all he needs, works in the VW/Pierburg round-top
pump he has, that would be my choice also
Quality of rebuild kit parts seems to be all over the place. It may be impossible to get the correct fuel pressure with kit parts.
Using the old diaphragm spring with the new diafram might work.
'67 bug: seized by the authorities
Tcash
Tcash is offline
PostPosted: Sun Jul 27, 2014 10:37 am    Post subject: Fuel Pumps Reply with quote
To link to this post
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=7302183#7302183]Fuel Pumps[/url]
1968-70 T2 fuel pump VW prt#?
Pierburg VW 3 8289
40 HP fuel pump rebuild kit 111-198-553.
Replacement Airtex 1070
Hello, note there are two styles of pumps out there.
One has a recessed plunger arm. Generator style = 107.5mm (4.25) pushrod.
One has a protruding plunger arm. Alternator style = 100mm (4") pushrod.
There was also a angled pump with a Generator style base produced.
Thanks sxuxrxf.
You will also need to adjust the pushrod height and pressure per your repair manual. Good Luck
http://vwparts.aircooled.net/Mechanical-Fuel-Pump-Upright-Engine-w-Alternator-p/113-127-025g.htm
http://vwparts.aircooled.net/Mechanical-Fuel-Pump-1961-65-Type-1-1960-65-T2-p/211-127-025.htm
Tcash
Tcash is offline
PostPosted: Sun Jul 27, 2014 10:40 am    Post subject: Rebuilding the Pierburg Fuel Pump Reply with quote
http://www.hotvws.com/content.php?contentID=45
Brian
Brian is offline
PostPosted: Sun Jul 27, 2014 10:50 am    Post subject: Reply with quote
http://www.wolfsburgwest.com/wired/wired_12_99/wired_12_99.htm
1. Early 25hp pump
2. 36hp, 1954-1957
3. Late 36hp
1. 40hp with threaded inlet pipe
2. 1300-1600cc
3. Alternator style fuel pump
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Tom Powell
Tom Powell is offline
PostPosted: Sun Jul 27, 2014 11:18 am    Post subject: Reply with quote
I faced a similar fuel line situation. I started at the tank with new hose, used a double barb brass nipple to go through the fire wall. That hose can go to a filter or directly to the carburetor. After an OG fuel pump failure I bought a "made in Brazil" fuel pump at a FLAPS. The instructions were in Portuguese and the inlet and outlet were reversed from the OG pump. Entrada and salida. Keep your hoses out of alignment with the fan belt and away from the distributor and high tension wires. Many Sambans recommend keeping filters out of the engine bay.
Aloha
tp
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Jul 27, 2014 1:04 pm    Post subject: Reply with quote
Another bus regular posted that you can buy the 5.5 MM braided hose now at the VW dealers. He posted a pic of the hose with the VW/Audi logo on it. You'd wonder if it's a new rubber compound in it for todays fuels? I'm going to go by my VW dealer tomorrow and check it out.
The Samba member since 2004.
busdaddy
busdaddy is offline
PostPosted: Sun Jul 27, 2014 1:11 pm    Post subject: Reply with quote
Please do, perhaps you can soak a section in known ethanol gas to see how it looks in a few weeks.
Слава Україні!
Brian
Brian is offline
PostPosted: Sun Jul 27, 2014 1:18 pm    Post subject: Reply with quote
subscribed
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Wed Jul 30, 2014 11:23 am    Post subject: Reply with quote
lustig69 wrote:
subscribed
So.. I went to my local VW dealer and asked if they had the 5.5MM braided fuel hose w/the Audi/VW logo on it. He said VW discontinued it 6-8 months ago. He stated there was no demand for it since none of their new cars use it. I'm not this parts guy was the brightest bulb in the light strand but he stated Wolfsburg West sells the same thing. I said, no they don't. The fuel line I saw had the Audi logo on it and WW does not. He then looked puzzled.
I may call a couple of other VW dealers parts departments in the next couple of days just in case this guy was FOS.
Page: 1, 2, 3  Next
