Turboing
whyismyvwbroken
whyismyvwbroken is offline
PostPosted: Thu Aug 14, 2014 8:57 pm    Post subject: Turboing Reply with quote
I've watched so many videos, and googled everything under the sun to find out how to turbo. I need a list as to what I need to turbo. I know how to run the exhaust and everything, but I don't know how to run oil to the turbo, or what carb to use. I just need a list on what I need. If you can help, I will be so grateful.
Quokka42
Quokka42 is offline
PostPosted: Fri Aug 15, 2014 3:55 am    Post subject: Reply with quote
The exhaust needs to be routed to feed into the turbo, oil can be tapped off from the pressure side of the pump, carb can be before the turbo, after if turbo-prepped, or for the best and safest, go EFI (though it is also the most expensive.)
Every turbo install seems to be unique, unless you buy a kit, so I'd suggest doing a few searches here and looking at how others did it for the "everything." Seriously, though, if you know that little you should start with a HiPo N/A engine and work your way up.
There has only ever been one man who was perfect, and they nailed Him to a cross.
madmike
madmike is offline
PostPosted: Fri Aug 15, 2014 4:30 am    Post subject: Reply with quote
Just install a T at the oil pressure to feed the Turbo,If u tap into the pump outlet u can kill 'Skeeters' Laughing outlet on the bottom of turbo needs to be at la good size I think mine is 1/2",good reads are Turbomaina and Turbochargers by Hugh MacInnes,, more turbo guys are over on www.shoptalkforums.com ,Weber sidedraft DCOE or a dell carb work well for 'draw threw',,Madmike
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
madmike
madmike is offline
PostPosted: Fri Aug 15, 2014 4:31 am    Post subject: Reply with quote
Just install a T at the oil pressure switch location to feed the Turbo,If u tap into the pump outlet u can kill 'Skeeters' Laughing outlet on the bottom of turbo needs to be at la good size I think mine is 1/2",good reads are Turbomaina and Turbochargers by Hugh MacInnes,, more turbo guys are over on www.shoptalkforums.com ,Weber sidedraft DCOE or a dell carb work well for 'draw threw',,Madmike
jcmyers
jcmyers is offline
PostPosted: Fri Aug 15, 2014 9:11 am    Post subject: Reply with quote
I use one of these unions for oil return line, dry oil sump can and the rest, also has my oil pressure unit attached to it (similar to this, anyway). also use a sidedraft Dellorto 48
http://www.appletreeauto.com/UNIVERSAL-BRAKE-LINE-UNION-17-2919-0/
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Fri Aug 15, 2014 9:49 am    Post subject: Re: Turboing Reply with quote
You need to know how to tune a turbo engine before you go slapping parts on it, so the logical follow up question is what is your level of tuning ability and do you have the right tools at your disposal? If the answer to those questions is 'very little' and 'none', I'd advise you seek out some knowledge before you make your screen name a reality.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
jcmyers
jcmyers is offline
PostPosted: Fri Aug 15, 2014 10:13 am    Post subject: Reply with quote
ha! didn't even notice that! it's true, my setup takes a lot more time and cussing than my wife's non-turbo dual carb 1776
mightymouse
mightymouse is offline
PostPosted: Sat Aug 16, 2014 8:23 pm    Post subject: Reply with quote
Yup. Mini is right. This isnt a simple endeavor.
Also need to have an oil restrictor at the turbo. Cant just pump 30+ psi and corresponding volume full tilt into it.
You ask the manufacturer of the turbo what restrictor jet size they recommend.
They will tell you and thats what you buy. Keeps your turbo alive and happy and doesnt blow the seals out the first day.
Email aj at lowbugget and get a few outlines from him.
You can get a kit with a standard t3/t4 and a draw through 2 barrel and make very nice power.
Local guy to me has a home made kit with a T3 off a nissan 300zx. One of AJs draw thru 2 barrels.
I tuned it for him, 7 psi and 20 degrees timing his 1679 made 130 WHP.
runs like a top and we havent even turned it up yet.
HAVE to have a wideband so you can see the AFR at all times.
Mappable ignition is very good to have too if you plan to daily drive it. Having fixed timing SUCKS.
Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
miniman82
Samba Swamp Donkey
PostPosted: Sun Aug 17, 2014 6:51 am    Post subject: Reply with quote
mightymouse wrote:
Also need to have an oil restrictor at the turbo. Cant just pump 30+ psi and corresponding volume full tilt into it. You ask the manufacturer of the turbo what restrictor jet size they recommend. They will tell you and thats what you buy. Keeps your turbo alive and happy and doesnt blow the seals out the first day.
Correction: a restrictor is typically only REQUIRED on ball bearing turbochargers. I have never needed one on the journal bearing turbos and I've never had a problem with them, but you do have to make sure the drain is perfectly clear and drains above oil level in either case. The people that seem to have the most trouble are the ones draining to a deep sump below oil level like with the CB sedan header.
clonebug
clonebug is offline
PostPosted: Sun Aug 17, 2014 8:21 am    Post subject: Reply with quote
A -3 feed line without a resrictor will usually work out for most turbos.
A large, straight drain is probably the most important. My Subaru IHI turbo has a 5/8ths or metric equivalent size drain.
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
whyismyvwbroken
PostPosted: Mon Aug 18, 2014 6:32 pm    Post subject: Reply with quote
I'm never dissatisfied with posting to these forums. I have every tool you can think of using (family owns body shop/dad is very extensive with his tool collection). You guys basically just told me everything I need to know. Thank you! Any of you know what kind of HP a stock 1600 DP would put down?
clonebug
clonebug is offline
PostPosted: Mon Aug 18, 2014 7:28 pm    Post subject: Reply with quote
My 1679 with 16 lbs boost and a 2.24 second 60 ft. did 99.2 mph in the quarter. It was spinning heavily in first and short shifted into second at 4800 rpm.
I'm sure it has more in it since I'm at 17 lbs now......
With a better 60 ft. and more boost it could see low to mid 13's fairly soon.
Here is my Iphone Dynoliscious run from last fall.
Acceleration
0-10 MPH: 1.43 sec
0-20 MPH: 2.20 sec
0-30 MPH: 3.20 sec
0-40 MPH: 4.09 sec
0-50 MPH: 5.35 sec
0-60 MPH: 6.72 sec
0-70 MPH: 8.11 sec
0-80 MPH: 10.07 sec
0-90 MPH: 12.68 sec
Elapsed Time
60': 2.24 sec @ 27.4 MPH
330': 6.07 sec @ 59.8 MPH
1/8 mi: 9.17 sec @ 78.4 MPH
1000': 11.88 sec @ 90.1 MPH
1/4 mi: 14.17 sec @ 99.2 MPH
Audi TT intercooler
EcuMaster PMU16
whyismyvwbroken
PostPosted: Wed Aug 20, 2014 8:14 am    Post subject: Reply with quote
Dang. That's nice. Pretty quick little car.
