A new split sheet metal part
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 13, 14, 15  Next
virtanen
virtanen is offline
PostPosted: Wed Jan 29, 2014 3:34 am    Post subject: Reply with quote
Removing old rotten sash. This is for left side.
I used 12x12 mm iron bar to get correct distance.
And distance from end approx 18 cm
Spot welding to original points
Ready to use
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
splitjunkie
splitjunkie is offline
PostPosted: Thu Jan 30, 2014 12:26 pm    Post subject: Reply with quote
I just got my email copy of Wolfsburg West Wired and look what they are now selling.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111837572
The bottom part looks very different than what I have ever seen.
Chris
virtanen
virtanen is offline
PostPosted: Fri Feb 07, 2014 8:39 am    Post subject: Reply with quote
The first proto of crank pulley for 25hp Very Happy
My plan to use old used hubs.
Mika
New projects
veskovici
veskovici is offline
PostPosted: Fri Feb 07, 2014 1:33 pm    Post subject: Reply with quote
Shocked Shocked
Oval 1954
Barndoor1954
Doubledoorsunroof
virtanen
virtanen is offline
PostPosted: Mon Mar 24, 2014 8:37 am    Post subject: Reply with quote
Complete bottom plate for early heater channel.
Mika
New projects
Derosse
Derosse is offline
PostPosted: Mon Mar 24, 2014 8:50 am    Post subject: Reply with quote
OMG Shocked all beetles with bad heater channels can smile from now on Very Happy
SplitPersonality
SplitPersonality is offline
PostPosted: Mon Mar 24, 2014 2:31 pm    Post subject: Reply with quote
Wonderful parts Mika! Thank you for your suppport to the hobby!
Could you briefly explain the difference of the heater channel bottom throughout the Split/Oval-era? What are the "generations" of pressings?
virtanen
virtanen is offline
PostPosted: Mon Mar 24, 2014 11:29 pm    Post subject: Reply with quote
I made this according a late '51 original part, and have not inspected later versions so close. I have noticed some changes for outer cutline later versions.
One question is not clear for me, there is a douple hole at front, does the douple rectangular nut belongs to the bottom plate, spot welded there? I think it does. So some more work to do to be complete bottom plate Smile
Mika
New projects
Robert Chambers
Robert Chambers is offline
PostPosted: Tue Mar 25, 2014 12:29 am    Post subject: Reply with quote
I think the double nut block needs to be free so it can be moved around for alignment of the bolts. I have removed and replaced several bodies from the pan. On each body the block was free to move.
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
virtanen
virtanen is offline
PostPosted: Tue Mar 25, 2014 8:27 am    Post subject: Reply with quote
Yes, nut needs a holder which allow some movement.
Mika
New projects
virtanen
virtanen is offline
PostPosted: Fri May 09, 2014 5:24 am    Post subject: Reply with quote
Protos of early pre49 bumper irons, made of special spring steel. One for rear (both left and right are the same) and one for front left side.
Mika
New projects
virtanen
virtanen is offline
PostPosted: Tue May 13, 2014 8:32 am    Post subject: Reply with quote
Not a sheet metal part, but anyway a test molding for aluminum oil pump cover for pre'49.
Mika
New projects
virtanen
virtanen is offline
PostPosted: Tue May 13, 2014 8:35 am    Post subject: Reply with quote
Test piece for breather cap for early engines and transmissions.
Mika
New projects
veskovici
PostPosted: Tue May 13, 2014 9:29 am    Post subject: Reply with quote
Wink
Oval 1954
Barndoor1954
Doubledoorsunroof
virtanen
virtanen is offline
PostPosted: Fri Jul 04, 2014 12:56 am    Post subject: Reply with quote
KdF heater channel closing plate.
Mika
New projects
vwhelmot
vwhelmot is offline
PostPosted: Fri Jul 04, 2014 2:40 am    Post subject: Reply with quote
Do you make floor pans?
virtanen
virtanen is offline
PostPosted: Mon Aug 18, 2014 6:34 am    Post subject: Reply with quote
I make only repair sections for floor pans.
Mika
New projects
virtanen
virtanen is offline
PostPosted: Mon Aug 18, 2014 6:37 am    Post subject: Reply with quote
New part, pre 49 luggage rails.
Mika
New projects
GLHTurbo
GLHTurbo is offline
PostPosted: Mon Aug 18, 2014 3:47 pm    Post subject: Reply with quote
beautiful work as always! keep 'em coming!
1957 Beetle
1966 Bus
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Mon Aug 18, 2014 5:08 pm    Post subject: Reply with quote
Very nice,
Mika!
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
Page 6 of 15
