Kirk Samba Member
Joined: December 05, 2003 Posts: 5492 Location: North Texas
Posted: Wed Sep 17, 2014 8:15 pm Post subject: My new '73 Fasty |
A friend of mine bought a Fasty, and had me and another friend go get it for him. So we did. When we did, I found the nastiest fastback I have ever seen in my life. In this backyard since forever, and under the nastiest trees ever.
A long winch cable, some swapped wheels, and the Fasty rolled free. Yikes.
Anywhoo, we loaded it up, and delivered it to his house! I offer to buy it on the spot, before it comes off the trailer. He says no, because hes going to part it out to convert his auto square to manual. Im pretty dissapointed, because its honestly a pretty clean car. Good pans, good rockers, etc. Very very oddly, the metal around the engine (the deck) is completely gone. Nothing else, just that area is rusted. Weird. Oh well, its a parts car now.
But Kirk! How does this involve you?! I thought you had a new car! Keep reading. So he washes it, and sends me pics.
A few weeks later, he offers it to me for sale! Says he has too much at the moment, and instead of parting it out, he wanted me to have the option to buy it for what it cost him. I readily agree. Back we go! Save another!
And now I own a fasty. On the way home, I find a buddy has a non beat up late type3 hood for nearly free. Nabbed it as this one doesnt close anymore.
Yellow doesnt match, and I dont like that. Hmm. Mines just so bad!
It definitely stinks and is covered underneath and inside by some cottony mess where it came from. The nose is punched, Oh and the passenger door is frozen on the bottom hinge and the top one is broken. Yikes. Last registered in 1986, when she was but 13 years old. Weird. _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super
Kirk Samba Member
Posted: Wed Sep 17, 2014 8:15 pm Post subject: |
So the first thing we do is swap the hood. Doesn't match but it closes! (Not closed here)
You can see the door is hanging in that pic. While the hoods off we clean it out!
Might as well vacuum the interior too and scrap that junk out.
I can't clean the other side so...
Now I can! Yeah this is broken. I bet we spent 45 minutes trying to coax that door open. Squirt. Wiggle. Squirt. Wiggle. ITS BREAKING! No its not. Squirt, wiggle squirt, wiggle. Repeat. Finally it opened! Those door screws were a PITA to beat out.
Through magic goop of Parker's and some continual work the top hinge starts swinging! Bottom was stifffffffff. Gotta undo the fender to get to the back side....
Bear
Fasty
Super
Kirk Samba Member
Posted: Wed Sep 17, 2014 8:16 pm Post subject: |
Grinding and Cleaning continue! My friend Parker the automotive wiz runs the grinder, and dummer, slower me runs the vaccum.
Were type3s made of better interior materials? (Kidding) I swear the type 3s i find are not nearly as shot out as their beetle counterparts. Its as if they were better cared for or better something. So odd.
Parker gets it ground down and reattached!
We wrecked his driveway tho. After much much much much more hinge work, and 15 minutes of alignment, both hinge and door:
Bolted up! And shuts like a damn Mercedes! _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super
Kirk Samba Member
All in all it's a clean little car. (We cleaned the glass too. That helps.) The engine surround metal is rusty but nothing else on the car is. Pans rockers etc all great. Weirdest thing. Bolted up some non flat rollers.
Parker decided we should see if he ran. Fantastic idea! Let's pull the back seat and take alook. Under the seat was the worlds oldest car battery. So using the might of a ford truck and some jumper cables we attempted to turn it over. Nada like nada.
Yes I have jackstands. Got underneath to verify the starter wiring. Looked janky, so I replaced a spade and tightened stuff up. Still wont spin. Beat on it. That’s better! So I climb out and Parker and I disassemble the distributor, fiddle with points, swap condensors, nothing seems to work. Check the plugs, coil, nothing! As self doubt begins to creep in, we swap points to a new set and set them. He goes to start the car again, and I lay my hand on the plenum while pulling a wire off to test. That would prove to be a bad idea as I immediately get the sh*t shocked out of me. Yowzer. Guess we have power now. Crank crank nothing. Starterfluid aint doing it, but now it wont crank again! BFH to the rescue! I beat he cranks.
It is about this time, Parker is enveloped in the black smoke monster from Lost as this beast fires to life running on starter fluid, half eaten pecans, rust flakes and rat pellets. Belching its displeasure, it pops once and dies. Parker, alternating between celebrating and coughing, suggests we try it again. He goes to the front to crank, and I go to the rear to spray. Nothing. Starter dead again. I climb under from the rear (Bad Idea) and whack the starter about the time he cranks the key. Boom! Fires off again! This time Kirk had been scootching out from under it about the time it decided to shower me in rat turds, rust and pecans from the rotted out header. Literally, I began to yell but all pleas of help were drown out by a Volkswagen trying to come to life after a (literal) 28 year nap. (Last tagged in 1986) After a brief moment, the car dies, Parker celebrates, and I climb out coughing. Parker takes one look at me and hands over the air hose. Success! He runs! Before lowering him down, I swapped the starter with a used unit Parker had laying around.
Now I roll the car forward and begin to sweep up all the crap that fell out of the car. Its gonna need more work before it runs on its own, that’s for sure. Fuel pump is bad, tank is probably junk, and fuel lines are old. Fuel injection is coming off and Im going with carbs. Oddly, the fuel injection on this car is complete unlike how my square was. _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super
Kirk Samba Member
Time to polish! I love to bring them back. First, my weapons:
So I didn't have buffer pads so I did it by hand, one panel at a time. Wash car, rubbing compound, wax. It will need it again but this is a good start. How about I let pics tell it?
Before:
After:
Bear
Fasty
Super |
Kirk Samba Member
WOW Wednesday!
Might as well clean the interior too just for giggles.
Thanks for following along! Now all I need is a nice set of carbs, and an exhaust:
well for starters. Thanks for following along! And feel free to explain how that rear deck got rusted completely out, and nothing else on the car is. _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed Sep 17, 2014 11:22 pm Post subject: |
COOL! your an official TOOB member now
welcome to the club. want to see which of us bus drivers gets his t3 on the road fastest? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23598 Location: Kimball, Mi
Posted: Thu Sep 18, 2014 9:46 am Post subject: |
| Stuartzickefoose wrote: |
welcome to the club. want to see which of us bus drivers gets his t3 on the road fastest? |
Stuart, Kirk already has a Squareback, and is a TOOBer. This car (the Fastback) is new to him.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Thu Sep 18, 2014 10:08 am Post subject: |
| Kirk wrote: |
Were type3s made of better interior materials? (Kidding) I swear the type 3s i find are not nearly as shot out as their beetle counterparts. Its as if they were better cared for or better something. So odd. |
Yes, they were made with better materials, and were better cared for (well most of them were). The type 3 was afterall an upgrade for the beetle owner.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Thu Sep 18, 2014 10:37 am Post subject: |
didnt know that....my bad kirk....i dont catch it all sometimes. still a cool fasty  _________________ Stuart Zickefoose
206-841-7324
[email protected] |
9pin Samba Member
Joined: August 07, 2012 Posts: 130 Location: Minneapolis
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18054 Location: Eugene, OR
Posted: Fri Sep 19, 2014 7:31 am Post subject: |
Got to get that air conditioning working & just enjoy the rare center console & rain gutters!  _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2207 Location: Gardnerville, NV
Posted: Fri Sep 19, 2014 7:55 am Post subject: |
what a neat little car, congrats , get er goin! _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Kirk Samba Member
Posted: Fri Sep 19, 2014 12:08 pm Post subject: |
| Mike Fisher wrote: |
Got to get that air conditioning working & just enjoy the rare center console & rain gutters!  |
Center console is rare? _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
Posted: Fri Sep 19, 2014 12:48 pm Post subject: |
| Kirk wrote: |
Center console is rare? |
Not really rare, just not seen that often. The under dash AC unit is more rare.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Kirk Samba Member
Posted: Thu Oct 23, 2014 6:25 am Post subject: |
More work was done today under the supervision of a couple friends!
"Look it looks like a dealership in 1973!" - Matt
"Looks like a ford dealership!" - no one
So basically today I wanted to get some small stuff done. Wheels off, studs in.
Whatttttttt?
Yuuuuupppp
Let's keep it goin! _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
Kirk Samba Member
Posted: Thu Oct 23, 2014 6:27 am Post subject: |
Now let's look at the exhaust. New header:
High temp paints..
Bear
Fasty
Super |
Kirk Samba Member
Posted: Thu Oct 23, 2014 6:34 am Post subject: |
Off with the old...
On with the new, hardware and gaskets.
Fits perfectly.
Bear
Fasty
Super |
Kirk Samba Member
Posted: Thu Oct 23, 2014 6:36 am Post subject: |
I'm pretty stoked! Next, time for carbs! We checked the tank and it looks clean. New lines and we are getting close to trying to fire it up and drive.
Getting there! _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
Kirk Samba Member
Posted: Thu Oct 23, 2014 6:57 am Post subject: |
Scored a hood today in the right, "Texas Yellow!" Had to do some research with my data assistant Parker from afar, but I believe this to be the right color!
Only a little surface rust too.
The underside has surface rust from sitting. Nothin major.
A little buffing and this is gonna shine I think!
Bear
Fasty
Super |
