Stuck Oil Drain Plug
BoWingo
BoWingo is offline
PostPosted: Sun Dec 02, 2007 7:50 pm    Post subject: Stuck Oil Drain Plug Reply with quote
I started the process of changing fluids in my '85 Westy today that has been parked by the PO for at least five years. However, at the end of the day, I had made NO progress and become very stressed.
I can't get the oil drain plug to budge and I'm pretty sure that I've rounded the head trying. Googling the topic seems to tell me that I should get a pair of vise grips and a new drain plug. However, there is a lip all the way around the drain plug that I'm afraid will keep me from getting the grips on the bolt. I can't even get a wrench on there, only a socket.
Anyone ever had and solved this problem?
--Bo
Waldemar Sikorski
Waldemar Sikorski is offline
PostPosted: Sun Dec 02, 2007 8:02 pm    Post subject: Reply with quote
Drill and extract is one way.
?Waldo?
?Waldo? is offline
PostPosted: Sun Dec 02, 2007 8:07 pm    Post subject: Reply with quote
You can often get a small pipe wrench on one. A pipe wrench works better than vice grips in any application where it can be used, as it continually grips tighter and tighter into the metal whenever additional pressure is applied as opposed to a pair of vice grips which are set initially to their tightness. Another alternative is to pound a slightly smaller 12 pt socket over the rounded off head. That often works very well as the pounding helps to loosen the fastener as well. Heat from a propane torch can also help.
Andrew
foodeater
foodeater is offline
PostPosted: Sun Dec 02, 2007 8:16 pm    Post subject: Reply with quote
Sears sells stripped nut/bolt removers. They have four or five deep threads that grip tighter and tighter on the bolt the harder you turn it to get it off. I have had great results with these things. Buy the kit the kit that has the most sizes, as a few times the bolt that I was trying to remove fell in between the sizes of the removers. Its like $30 for a kit of 9 (I think), and worth every penny.
-Glenn
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
BoWingo
BoWingo is offline
PostPosted: Sun Dec 02, 2007 9:31 pm    Post subject: Reply with quote
I like the idea of the nut/bolt removers from Sears. Just to make sure, is one of these sets what you're talking about? I'm thinking it's the first one.I can see these coming in handy in other places on my 23 yr. old van.
--Bo
foodeater
PostPosted: Sun Dec 02, 2007 11:56 pm    Post subject: Reply with quote
Yup, those are the ones. they have turned out to be one of those things that I never knew how much I needed until I got them. You will find plenty of uses for them. My only complaint is that you cant put a ratchet on them, but its not too big a deal.
-Glenn
BoWingo
BoWingo is offline
PostPosted: Tue Dec 04, 2007 12:58 am    Post subject: Reply with quote
You guys are lifesavers!
I got the Craftsman Bolt-Out kit today and had the oil drained within an hour. It sure did tear the drain plug up, but it got it out. I went to the auto parts store and picked up a replacement for a few bucks.
It's amazing how much small victories can improve morale.
Thanks, guys.
--Bo
Tully Mars
Tully Mars is offline
PostPosted: Tue Dec 04, 2007 4:34 am    Post subject: Reply with quote
Are you sure you got the right plug?
I had the same problem a few months ago. I now have a nice set of "Bolt Grips" by the Vise-Grip people.
But.... it took me three trips and about five different flaps before I came to the realization that the right plug is almost impossible to find. I finally went to a VW dealer. About six bucks as I recall. The washer is special too.
morymob
morymob is offline
PostPosted: Tue Dec 04, 2007 5:51 am    Post subject: Reply with quote
I have found the best way to cut down on rounded off plugs etc is i always use 6point sockets/wrenches.Also i only carry 6-pt sae sockets/wrenches as this fits metric too. Has worked fine for years & only 1 set to carry.
BoWingo
BoWingo is offline
PostPosted: Wed Dec 05, 2007 6:14 pm    Post subject: Reply with quote
Tully:
You made me nervous with your "sure you got the right plug?" I bought a generic M14-1.50 oil drain plug and a package of M14 nylon washers at Advance Auto Parts, came home and read your post, and started to wonder until I tried them. They fit with no problem.
morymob:
I agree. I'm going to make sure all of my future socket or wrench purchases are 6-point. It's hard to find 6-point sockets and wrenches anywhere nowadays, though.
tencentlife
tencentlife is offline
PostPosted: Wed Dec 05, 2007 9:33 pm    Post subject: Reply with quote
The major chain FLAPS (Checker, AZ, Pep Boys, etc. in our area) carry generic plugs in lots of sizes, and those nylon washers, too. I've bought Vanagon ones before. The plugs are pretty good, wide-shouldered, and the nylon washers seal much better than copper ones without needing nearly as much torque.
Now, in Baja, I dunno.....
guzyk
guzyk is offline
PostPosted: Fri Oct 03, 2014 5:39 am    Post subject: Irwin extractors from Amazon worked for me Reply with quote
I had a very rounded/mangled drain plug that would not budge. Even tried drilling is out with reverse drill bit but gave up cause drill wasn't centered.
I ordered this extractor set, tapped one on with a hammer and voila, drain plug out in 2 minutes. (probably the same set that Sears sells)
http://amzn.com/B0000CCXVZ
Well worth the $20
And make sure you order a new drain plug with new crush washer then only tighten to 10 ft pounds.
Team WorldTour
Team WorldTour is offline
PostPosted: Fri Oct 03, 2014 6:45 am    Post subject: Reply with quote
A guy came into my shop yesterday with an old '84 Transporter. He wanted an oil change. The PO used a SPARK PLUG with a Heli-coil Shocked
Engine purrs nicely though....
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
wenholzm
wenholzm is offline
PostPosted: Fri Oct 03, 2014 9:31 am    Post subject: Reply with quote
On a trip in Montana a small shop helped me take off a stripped oil drain plug. The 13mm socket would not grab so he got a 1/2 inch socket and tapped it ever so lightly onto the bolt and was able to get a hold of it and take off the plug.
vanagonjr
vanagonjr is offline
PostPosted: Fri Oct 03, 2014 10:01 am    Post subject: Reply with quote
Yep BTDT - here's another tip, If you have a stripped out internal hex (Allen head), bang the next size Torx bit into it. Worked amazing well for me recently on a recessed bolt.
Also, heed Andrew's tip on the pipe wrench - used that on some stripped out CV bolts years ago.
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
16CVs
16CVs is offline
PostPosted: Fri Oct 03, 2014 10:55 pm    Post subject: Reply with quote
I wouldn't put a stock sized drain plug back in a WBX that still has good threads or even marginal at the surface.
I use one of those extended drain plugs from "JP Werks" I buy these and hand em out to people who need them.
Here is the Ad # Ad id: 1344190 .Sorry I don't know how to link it .
Stacy
Samba member # 14980
westyman71
westyman71 is offline
PostPosted: Sat Oct 04, 2014 5:54 am    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1344190
Here's the link
I use these in all my Vanagons.
Great product, nice guy selling them
fleet_maintenance
fleet_maintenance is offline
PostPosted: Sat Oct 04, 2014 6:02 am    Post subject: Reply with quote
^^^I just got a new drain plug earlier this month from JP Werks. Although the threads in my case were almost shot, it sealed the hole and gas stopped the drip. Super easy transation, quick shipper!
/semi-threadjack Very Happy
dart330
dart330 is offline
PostPosted: Sat Oct 04, 2014 8:34 am    Post subject: Reply with quote
I'm curious how does threading a bolt further into the engine case make it easier to get out?
My first Vanagon, an 85, the drain bolt was stuck and stripped when I got it as the last person who changed the oil hadn't installed a washer. Ended up having an 18yr old Carl Edwards, the NASCAR driver who's father ran a VW shop back in the day, tack weld a 1/2" bolt onto the stripped plug. Was able to break it loose using the good bolt head. I prob wouldn't try that at home, but it worked fine at the time.
Funny, even though Carl's dad ran a VW shop he had never been in a Westy. I ended up popping the top and giving him a tour.
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
?Waldo?
?Waldo? is offline
PostPosted: Sat Oct 04, 2014 8:38 am    Post subject: Reply with quote
It doesn't make it easier to get out. It can, however, seal when the shorter drain plug has stripped out the case.
The shorter drain plug does not engage all of the threads in the case. Often, the aluminum threads that are engaged with the plug will strip out due to the aluminum being soft. Even after the shorter drain plug has stripped out, often the longer plug can be used to engage the remaining threads in the case. The longer plug is also assists in preventing stripping the threads out of the case by engageing more threads making the force required to strip the threads that much greater.
