-Zodiac- Samba Member
Joined: September 22, 2014 Posts: 782 Location: Pensacola/milton, florida
Posted: Sat Oct 04, 2014 9:26 pm Post subject: Painted dash, or face? |
Doing a 73 coupe and started glue removal, the PO removed most of the black plastic and the paint is pretty nice below the glue. There is some surface dust and I'll have to do touch ups. I've been kicking the idea of a wood grain dash cover around in my head, but the painted dash looks pretty nice Aswell. Looking for some opinions
Start
Slow progress
Close to finish
Yes I need to fix the dash pad :p |
DorianL Samba Member
Posted: Sun Oct 05, 2014 2:36 am Post subject: |
I toyed around with the idea of a painted dash as well - and I LIKE the idea. However, I found that to make it look the way I wanted, I'd have to plug quite a fez holes near the dash pad. The holes peek out from under the pad. There are quite a few other holes that would need to be plugged up as well. To my taste, it would really have take a lot work to get it where I wanted.
I finally opted for the woodgrain and never looked back. Get a decent quality face and take your time to apply it, it looks sharp. |
That fasten seat belts light is cool. |
O2COOLED Samba Member
Posted: Sun Oct 05, 2014 3:33 am Post subject: |
DorianL wrote: |
X2 on this, like Dorian I looked at painting and decided woodgrain for the same reasons. I think it really boils down to personal preference and how much time and effort you are willing to put into it. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
"At my age time is too short to respond to people with short minds"
Current: '69 Ghia Coupe
VW History:'63 Bug;'70 Bug;'73 412;'83 Rabbit;'86 Golf;'76 Fat Chick; 67 Ghia Coupe; '70 Bug |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Sun Oct 05, 2014 8:10 am Post subject: |
IMO, the vinyl covered dash face of '67-'74 ghias is one of the worst features of later model ghias. I filled the holes in the dash of my former '69 coupe. The "Show us Your Dash" thread has several examples of '67-'74 with painted dashes:
http://www.thesamba.com/vw/forum/viewtopic.php?t=566389&highlight=dash _________________ 1966 Karmann-Ghia convertible |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8237 Location: San Dimas
John Miller Samba Member
Joined: October 16, 2004 Posts: 735 Location: Elizabethtown KY
Posted: Sun Oct 05, 2014 11:09 am Post subject: |
I'm getting ready to weld up the ones in my '68, hopefully in the next few weeks, so i'll let you know how much of a pain in the ass it really is. _________________ The 68 Ghia
The 62 Beetle
slafa wrote: |
Any suggestions will be appreciated even if they suck and are stupid. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3307 Location: So. Cal. Oceanside GFK!
Posted: Sun Oct 05, 2014 11:38 am Post subject: |
c21darrel wrote: |
Agree with all these guys. Painted looks so much cleaner but all the slots and holes that need to be welded up is a chore. I felt a worthy one. I drilled spot welds, removed my dash 68 and welded in a 67 dash. That was the last year without all the slots in the dash. Heres a recent pic with new additions...EMPI wheel, trip speedo and ghetto mounted Formula Vee tach. HOG's dash cap with a french stich may be the next add-on.
That dash looks really nice, what's with the hole on top?
I also think a French stitch would look great. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Sun Oct 05, 2014 11:40 am Post subject: |
The feedback is much appreciated. I might keep the painted dash look for a while. just a little bottle of good off and it's almost cleaned the whole thing, and the wholes don't bother me as much as they should. I might try and utilize them somehow if I can :p it's a driver so not ready to tear into it just yet,but I might weld the holes in the future. |
Posted: Sun Oct 05, 2014 3:11 pm Post subject: |
Right, check out the thread. There are lots of nice examples of various styles in there with info on what it took to accomplish the results. Should give you enough basis to make a decision. _________________ "Sometimes people forget they signed up to a HELP & SHARE Forum not a pissing contest"
Posted: Sun Oct 05, 2014 7:39 pm Post subject: |
Thinking of a way to plug the holes and thought about putting a three way toggle switch in between the gauges .bottom dim,middle off,and top high. And putting double filament bulbs on the other two holes next to the radio with a length of wire behind them, so I can pull it out and have little lights to see with. I know it's kind of pointless because my phone has a light and I normally have a flash light in the car. But how does this sound to you guys? |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Mon Oct 06, 2014 7:11 am Post subject: |
-Zodiac- wrote: |
I kind of like the idea of using tethered lights to fill the extra holes, even though as you pointed out they are not really necessary.
If you wanted to get fancy, you could even add a rheostat so that the lights could be dimmed.
One of our modern cars has tiny LED lights under the rear view mirror that shine down and illuminate the entire face of the dash (very dimmly, so as not to be too distracting), and inside the door handles to make them easy to find at night.
You could fabricate some sort of small hood to go over your bulbs and direct some very dim light across the dash face.
Then, if necessary, the brightness could be turned up and you could pull the light from the dash and direct it wherever you may need to.
It would be kind of a lot of work for something that really isn't needed, but it would fill in the extra holes in a pretty clever way. |
kingkarmann Samba Member
Posted: Mon Oct 06, 2014 11:59 am Post subject: |
I disliked the dash pad and faux woodgrain. I had the body man go ahead and weld up all the extra holes in the dash. Here's a couple of views of my 67.
Posted: Mon Oct 06, 2014 12:01 pm Post subject: |
Yeah I think I am rather taking to the idea. I like rheostat idea, and I could even fit a ghia knob on it. I would put little shields on them Aswell. I'll going to look at radio shack, or a hardware store and see what they have. I think it's a nice solution and it would be easy to change in the future. |
Posted: Mon Oct 06, 2014 12:07 pm Post subject: |
Beautiful car ! I'll keep the dash pad black because it matches the two tone. I dig the Hand brake, where'd you get that? |
Posted: Mon Oct 06, 2014 1:00 pm Post subject: |
The handbrake cover is a rosewood piece from Flat4. I'm not sure who is a distributor now. Maybe CIP1 or CB? |
retrowagen Samba Member
Posted: Mon Oct 06, 2014 2:24 pm Post subject: |
On a '72-'74, my personal preference would be a faux-woodgrain applique.
I find the original all-black vinyl facing a little too dreary, but a painted face out of character with the rest of the interior accouterments. The woodgrain strikes a nice balance, and is in character with other late 60's / early- to mid-70's interiors from other German manufacturers (think BMW 2002).
Actually, thinking of other early 70's German interiors: I wonder if one could find a nice textured aluminum stock, and make something like the accent panel of a 1965-1967 Porsche 911 as an instrument panel face overlay for a Type 14?:
_________________ David Ruby
President, Karmann-Ghia World Club |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4935 Location: sanger ca
Posted: Mon Oct 06, 2014 2:47 pm Post subject: |
I filled every thing in. Didn't like the way the glove box door fitted so I filled that as well _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
