Dodesvw Samba Member
Joined: July 26, 2012 Posts: 32 Location: Los Angeles, California
Posted: Wed Oct 08, 2014 2:43 pm Post subject: Steering box adjustment 67 bug |
Hello
Last night I was parked facing down hill with my wheel turned facing the curb. When I left, I made the mistake of turning my steering wheel while at a dead stop, and I felt the steering slip a little bit as I was turning the wheel. Sure enough when I drove away the steering wheel is no longer centered more like 45 degrees while driving in a straight line.
I checked the pitman arm and tightened the screw on top of the steering box which took up some of the free play. Do you think it's safe to drive as is? Is the steering box just worn out? I am hesitant to drive it again after I felt the steering slip...
Thanks |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Wed Oct 08, 2014 2:50 pm Post subject: |
Safe to drive? Do you feel lucky?
check the connections at the steering coupler.
Turning the wheel at a stop should have nothing to do with anything except something not right _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
Posted: Wed Oct 08, 2014 3:59 pm Post subject: |
| 60ragtop wrote: |
Turning the wheel at a stop should have nothing to do with anything except something not right |
I just checked the steering coupler, every thing was pretty tight already. The tie rod ends and tie rods are good as well. |
Posted: Wed Oct 08, 2014 4:08 pm Post subject: |
So basically now my question is
Can the steering box being out of adjustment cause the steering to slip?
I tightened the slotted stud on top of the steering box about 1 turn |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Wed Oct 08, 2014 4:30 pm Post subject: steering box |
NO, something moved. Sounds like the spline coupler at the rag joint.
Spin the steering wheel to full stop and force it while someone is watching with a light. This sounds fairly serious IMO.
The adjustment on the box is to remove freeplay at the CENTRE position only. Anything off centre will need some kind of play. This helps return the wheels to straight. |
WD-40 Samba Member
Posted: Wed Oct 08, 2014 4:53 pm Post subject: Re: Steering box adjustment 67 bug |
| Dodesvw wrote: |
| Do you think it's safe to drive as is? |
Absolutely not!
Another thing to check is the big nut holding the steering wheel on. If it is loose, there is a good chance you stripped the splines on the steering wheel and/or steering column. _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Wed Oct 08, 2014 5:39 pm Post subject: |
| Something is still definitely slipping...I just parked with my tire on the curb and it doesn't take much effort to get the wheel to slip. Now I guess time to take stuff apart. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36331 Location: Conejo Valley, CA
Posted: Wed Oct 08, 2014 9:28 pm Post subject: |
If your box isn't clamped tightly to the beam it can cause this slippage.
There aren't many things that can make you totally lose control of the car. THIS IS ONE OF THEM! |
VolkswagenVMan Samba Member
Joined: September 25, 2003 Posts: 186 Location: Valparaiso , Indiana
Posted: Thu Oct 09, 2014 8:03 am Post subject: |
Don't drive the car till you figure it out!!!!!!! _________________ Master Tech at Team Volkswagen
VW's at work , VW's at home!!!!
1967 EMPI GTV
1966 Bug early
1966 Bug late
2017 Jetta
2025 Jetta |
Posted: Thu Oct 09, 2014 9:15 am Post subject: |
I definitely won't be driving it until this is fixed. Last night I had my dad watch as I forced the steering wheel against the curb. When it slipped, the steering shaft going into the box spun, however the pitman arm did not move. Is this something that can be fixed with adjustment or do I need a new box?
Thanks again everyone |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Thu Oct 09, 2014 9:31 am Post subject: |
If the shaft going into the box moved but the arm did not then the gears inside are shot. I suggest taking the box off and opening it up. IF there is no damage whichI doubt then rebuild it and adjust it. If there is damage then either get new parts or replace the box. I would simple replace the box. This IS a big deal. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
Posted: Thu Oct 09, 2014 10:04 am Post subject: |
| tb03830 wrote: |
| If the shaft going into the box moved but the arm did not then the gears inside are shot. I suggest taking the box off and opening it up. IF there is no damage whichI doubt then rebuild it and adjust it. If there is damage then either get new parts or replace the box. I would simple replace the box. This IS a big deal. |
Ok thanks that makes sense. My local vw place has the trw steering box in stock. I've read mixed reviews about them. What's everyone's opinion on the trw box? |
Posted: Thu Oct 09, 2014 11:10 am Post subject: |
I would like to know also.I need to replace mine due to the gap i nthe turning I have. it is getting worse and is fine at slow speeds but in the high way can be a danger.
Has anyone had any luck with other than TRW boxes? _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
WD-40 Samba Member
Posted: Thu Oct 09, 2014 11:11 am Post subject: |
| Dodesvw wrote: |
It certainly can't be any worse than what you have now!  _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
Posted: Thu Oct 09, 2014 11:20 am Post subject: |
| tb03830 wrote: |
Has anyone had any luck with other than TRW boxes? |
I started another thread about the trw boxes and someone posted a link with a bunch more threads on them...reading through them now |
Posted: Thu Oct 09, 2014 6:43 pm Post subject: |
| WD-40 wrote: |
| Dodesvw wrote: |
It certainly can't be any worse than what you have now!  |
Actually...it can. Just got done installing it. And it had more free play than my old box did. I would say about 6" at the steering wheel. As I adjust it it just gets harder to turn...no reduction in free play |
KTPhil  Samba Member
Posted: Thu Oct 09, 2014 10:06 pm Post subject: |
A new box needs no adjustment. You have overtightened it and are probably ruining it with every turn of the wheel.
Your play is elsewhere. I am guessing you may be missing the clamps at one end of the coupler or another, or maybe they are stripped and loose. |
Posted: Fri Oct 10, 2014 6:37 am Post subject: |
I thought the samething, so I installed my box and moved on aftereplaceing the entire front end of my bug, but it got worse as time goes on. After about 6 month I began to adjust it and it has never worked right. I am begining to believe that TRW has a bad product. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
rcooled Samba Member
Joined: September 20, 2008 Posts: 2852 Location: Santa Cruz, CA
Posted: Fri Oct 10, 2014 8:05 am Post subject: |
The OG steering box on my '67 Ghia finally ran out of adjustment (screw was flush with locknut), so I recently installed a new TRW box. The free play on-center is now within tolerance, but the steering is quite stiff. Before installing the new box, I checked the amount of play between the input & output shafts and found it to be minimal, but there was one thing that did seem a bit unusual. As I turned the input shaft, it didn't feel smooth. It felt somewhat like a ratchet...clicking from detent to detent as it turned. My old box felt the same way. Is it normal for a steering box to feel like that?
I attributed the stiff steering feel to the fact that the box is brand new, as are all the tie-rod ends. Will the steering feel eventually lighten up as all the components start wearing in a bit? _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
KTPhil  Samba Member
Posted: Fri Oct 10, 2014 9:33 am Post subject: |
It may loosen up. Mine was replaced about 6-7 years ago with a TRW box and it was also stiff. I did not tighten it, figuring it would ease up a bit, and it did.
More boxes are ruined by overtightening than almost any other cause. This is often because they don't understand it has to be adjusted with wheels off the ground, steering wheel turned 90 degrees. It is designed to have far more play when turned than when centered. You should also check that the box is centered, center the steering wheel on the shaft splines, and THEN set the tie rod ends to set toe-in and center the drive wheels. |
