Photo Resizing
Page: Previous  1, 2, 3
Forum Index -> Site Share: Facebook Twitter
Raymond73
Raymond73 is offline
PostPosted: Sat Mar 05, 2011 8:52 pm    Post subject: Reply with quote
If anyone has a product they can recommend for Windows7, please post it here so I can add a link to the first post in this thread.
Thank you.
Windows Paint that comes pre-installed will resize pictures. Just make sure to select the Maintain Aspect Ratio so it doesn't look all weird.
I am using Windows 7 (64 bit). Gimp version 2.6.11 works fine on my computer too.
Nuthin2It
Nuthin2It is offline
PostPosted: Fri Aug 17, 2012 7:11 am    Post subject: Reply with quote
I use Picasa 3 on my computer to resize photos for the gallery.
Highlight the pictures to be exported and select "File", "Export Picture to Folder . . . .". A screen will appear for the destination and a slide to select image size. I left it on 800 pixels. The photos are copied to the folder I created; from here they can be uploaded to the gallery.
kevnmarcie
kevnmarcie is offline
PostPosted: Mon Aug 25, 2014 9:43 am    Post subject: Reply with quote
Is there anything available for Windows 8.1? I am still trying to figure out this system after years of being perfectly happy with XP. The only way it wants to let me upload to my Samba ads is through OneDrive - which I am highly suspicious of, because it seems to want to copy every file on my computer. I also have not been able to find a resizer through this method. I would prefer to resize the pic on my machine and then upload it to my Samba ad directly from my machine. If anybody has any pointers, I would sure appreciate them.
Baffled by new technology...
Thanks,
Kevin
PostPosted: Mon Aug 25, 2014 5:21 pm    Post subject: Reply with quote
Does the one listed for Windows 7 not work for 8.1?
I don't have Windows 8 myself but everything else I have tried on Windows 7 has worked on 8.1.
kevnmarcie
PostPosted: Fri Oct 03, 2014 8:35 pm    Post subject: Reply with quote
Thanks Everett,
I downloaded the Windows 7 version. When I click the Browse button in the ad form, it brings up the OneDrive page in 8.1. I've discovered that if you click the down arrow next to the OneDrive header, you can select This Computer and access the pictures stored on your machine. They will resize automatically when they are posted to the ad.
MaximumFinishes
MaximumFinishes is offline
PostPosted: Mon Oct 27, 2014 7:58 am    Post subject: Reply with quote
There is an adjust size feature in the edit section of preview for Macs.
'64 Type 3 "Noback" - Frank
'68 Squareback - Charlie
'73 Westy - Mac
'98 Honda CR-V - Dee
'97 Subaru Impreza Outback - Dennis
jimf909
jimf909 is offline
PostPosted: Sun Sep 04, 2016 11:17 am    Post subject: Re: Photo Resizing Reply with quote
Is there a recommended solution for shrinking photos to avatar size on an iPhone? I've downloaded several resizing apps and none shrink photos down to 12 kb.
Any tips welcomed!
- Jim
Butcher wrote:
Guilty as charged.
PostPosted: Mon Sep 05, 2016 8:20 am    Post subject: Re: Photo Resizing Reply with quote
Any tips welcomed!
Do you know what size it's getting down to with the software you are using?
This is a common problem for people, I bumped up the size to 20KB as of right now to see if that helps.
Jan Steinman
Jan Steinman is offline
PostPosted: Tue Sep 27, 2022 12:51 pm    Post subject: Re: Photo Resizing Reply with quote
Avatar won't accept. "400 Bad Request — cloudflare".
I see a lot of people on this ancient thread saying it has to be under 100x100 and under 6kb.
But the instructions right under the "Choose file" button says, "width can be no greater than 120 pixels, the height no greater than 120 pixels, and the file size no more than 64 KB"
So, I made a 120x120. Size was 7kb. It won't take it.
So, in case the text under the button was wrong, and the ancient (~2007) requirements in this thread are right, I made an 80x80, under 3kb. Still won't take it. Same error message. This was an image stripped of all EXIF info.
Is anyone able to change their avatar? Do you need so many "points" or something? Is there a secret password?
Thanks!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Sep 27, 2022 12:57 pm    Post subject: Re: Photo Resizing Reply with quote
It was increased to 120x120.
Is your image a .jpg?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
PostPosted: Tue Sep 27, 2022 2:24 pm    Post subject: Re: Photo Resizing Reply with quote
Yes, is it a JPG image?
Email it to me, I'll check it out.
My email is in my signature below
Jan Steinman
Yes. Here it is.
Whoops. Won't let me load it in my gallery, either.
Let's see if this works…
That's the same 120x120, uploaded to Flickr, but if I put that URL into the "URL" field for my avatar, it returns immediately after "Submit", and the avatar isn't installed.
Strange.
PostPosted: Tue Sep 27, 2022 2:38 pm    Post subject: Re: Photo Resizing Reply with quote
I don't know what went wrong - I uploaded it into your profile and it worked fine for me.
It may be different than your original as I can see Flickr modified it internally
Jan Steinman
PostPosted: Tue Sep 27, 2022 2:44 pm    Post subject: Re: Photo Resizing Reply with quote
YAY! Thank you! I be avatar'd now!
Reply to topic    Forum Index -> Site All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 3 of 3
