Installing Door Panels
Tcash
Tcash is offline
PostPosted: Sat Jun 14, 2014 2:53 pm    Post subject: Installing Door Panels Reply with quote
To link to this post copy and paste
Code:
[url=http://www.thesamba.com/vw/forum/viewtopic.php?p=7242921#7242921]Installing Door Panels[/url]
Removed old panels. Cleaned with 409 and used brake clean on a rag to remove the old adhesive.
Applied rope caulk to doors. I bit thick, so I rolled it out between my hands to make it thinner. Cleaned an lubed door latches.
Installed 12 mil plastic purchased in a roll at the hardware store. Used a x-acto knife to trim plastic. Installed clip seals (condoms) not pictured. Note: next time I am in there I am going to install pieces of plastic on the inside of the openings to form flaps. So moisture will run off the plastic in the inside of the doors.
Note: replacement clip on the left and oe on right. I found it necessary to squeeze the barbs slightly on the replacements for installation.
I coated the backs of the panels with a acrylic spray or lacquer spray. To waterproof them. Lined up the clips and gently installed the door panels.
Rust-Oleum Never Wet
https://www.rustoleum.com/product-catalog/consumer-brands/neverwet/neverwet-kit
Tcash
guymon
guymon is offline
PostPosted: Mon Nov 17, 2014 4:40 pm    Post subject: Red? Reply with quote
Where did you find those red panels. They look great. I want some for my 72
Brian
Brian is offline
PostPosted: Mon Nov 17, 2014 4:46 pm    Post subject: Reply with quote
3m Rope Caluk
Ace Rope Caulk
Home Depot plastic sheet
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 6:04 pm    Post subject: Re: Red? Reply with quote
They are TMI.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Nov 17, 2014 8:32 pm    Post subject: Reply with quote
Nice job TCash. Just curious as to why you didn't install some sound deadener inside the doors? I know I want to do that with my 70'. The doors are so light, hollow and tinny...
The Samba member since 2004.
Brian
Brian is offline
PostPosted: Mon Nov 17, 2014 8:36 pm    Post subject: Reply with quote
I took out the material and it makes shutting the door so loud.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Tcash
Tcash is offline
PostPosted: Mon Nov 17, 2014 8:44 pm    Post subject: Reply with quote
Did not think about it. Good idea!
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Nov 17, 2014 8:51 pm    Post subject: Reply with quote
I did mine last month, and anytime someone comes over and compliments my bus to my housemate, she opens and shuts the doors and everyone comments on how quiet and GERMAN they sound. Rolling Eyes
I enjoy making these cars sound like they should.
www.airschooled.com
Road trip reports and tech blog:
SamboSamba22
SamboSamba22 is offline
PostPosted: Tue Aug 18, 2015 8:26 pm    Post subject: Reply with quote
Nicely done Tcash, thanks for the link. Good, clean work.
curtis4085
curtis4085 is offline
PostPosted: Wed Aug 19, 2015 2:32 pm    Post subject: Reply with quote
That vapor barrier is missing the inner flap
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
airschooled
Air-Schooled
PostPosted: Wed Aug 19, 2015 2:40 pm    Post subject: Reply with quote
Does anybody here know for certain if the factory installed the flaps on early bays without the flow through ventilation vents? I have never gotten a 100% certain answer.
www.airschooled.com
curtis4085
PostPosted: Wed Aug 19, 2015 2:56 pm    Post subject: Reply with quote
I have never seen them on early bays. But it's good measure to help direct the water to the holes in the door rather than between door panel and door.
Special Thanks to:
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Aug 19, 2015 3:20 pm    Post subject: Reply with quote
yes. I can verify that on 69, 70, 71 they had flaps. never parted a 68 so I cant say for sure
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Thu Aug 20, 2015 9:44 am    Post subject: Reply with quote
Bravo good sir! An inspiration!
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
airschooled
Air-Schooled
PostPosted: Thu Aug 20, 2015 12:57 pm    Post subject: Reply with quote
Cool, thanks.
www.airschooled.com
SamboSamba22
PostPosted: Mon Aug 24, 2015 10:48 pm    Post subject: Reply with quote
I'm working on this very project, what flap are we referring to?
'74 Westy with vented doors (blue slider openings on door panels)
kreemoweet
kreemoweet is offline
PostPosted: Tue Aug 25, 2015 7:38 am    Post subject: Reply with quote
The plastic moisture barrier had an extra flap on the outside which draped down into the bottom channel of the door. It kept the
inevitable leakage past the window seal from splashing onto the barrier and running down to accumulate between the barrier and door metal,
and likely eventually soaking into the door panel.
'67 bug: seized by the authorities
airschooled
Air-Schooled
PostPosted: Tue Aug 25, 2015 12:00 pm    Post subject: Reply with quote
Halfway down the first post, with the purple and red lines:
http://www.thesamba.com/vw/forum/viewtopic.php?t=445486
www.airschooled.com
Tcash
Tcash is offline
PostPosted: Tue Aug 25, 2015 12:10 pm    Post subject: Reply with quote
Thanks to amskeptic.
Vapor Barrier Replacement How-To
Dana Champion
Dana Champion is offline
PostPosted: Tue Aug 25, 2015 12:24 pm    Post subject: Reply with quote
For door panels, those are pretty sexy!... Nice job!
