Placeing the copper manifold gaskets.are there cutouts
1970bay
1970bay is offline
PostPosted: Sun Nov 23, 2014 7:47 am    Post subject: Placeing the copper manifold gaskets.are there cutouts Reply with quote
Recently i changed the exhaust on my 1700cc aircoole
It took two days before i unbolted the four manifold tubes to drop exhaust heater boxes in one Sad then cut off the old exhaust,
When i put it all back i didnt have the copper manifold joints(gaskets)nor it seems had the previous owner, who had hammered out copper washers Shocked
Now i have four new joints Rolling Eyes -"gaskets"
In the morning the local garage will let me use the lift to fit them.Do i 'ballence" them on the tube top and hope they stay in possition Sad or is there a cutout to drop them in?
If not.do i glue them with greace to stop?them moving as i refit the exhaust heaterbox
Travels with my camper:
http://flickr.com/photos/30879804@N08/
Built in 1971 The engine was changed from 1600cc to a 1972 flat 1700cc engine in 1974 otherwise nothings been changed std twin vw carbs
grandpa pete
grandpa pete is offline
PostPosted: Sun Nov 23, 2014 8:16 am    Post subject: Reply with quote
you can cut "slots " from the outside edge into the bolt holes to slide the gaskets on
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
1970bay
1970bay is offline
PostPosted: Sun Nov 23, 2014 8:30 am    Post subject: Reply with quote
Cant i or we if i have help will have the manifold tubes jammed on the pushrod tubes or better resting
Then ill put the copper joints on the tubes and push the whole thing-exhaust heatboxes -back up to the heads where i hope Sad ill get the bolts in and the whole thing bolted up
At the moment the camper fillis with smoke
The joints i want that the exhaust gas goes into the exhaust & out Very Happy
There is still a leaking pushrod tube which i can then get on with
The entire exhaust heater system weighs a LOT so im not sure the joints wont be wageleg out of place as i we push the pipes up to the heads
busdaddy
busdaddy is offline
PostPosted: Sun Nov 23, 2014 8:47 am    Post subject: Reply with quote
There is a recess they fit into to keep them aligned, glue them up there in place first with grease or something sticky. Before installing heat them with a propane torch until they turn blue and let them cool to soften them, also run a large flat file over the ends of the flanges to ensure they are all flat and level with each other.
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Sun Nov 23, 2014 10:37 am    Post subject: Reply with quote
The manifolds should push up between the pushrod tubes. Some tubes have flattened area to give more space for the manifolds, if so then rotate the tubes so the flats are on the sides verses being otherwise positioned. The gaskets in general are a tight fit up into the head, but using grease or something else to help hold them can assure the job goes better. I use copper silicone in the recess and then let it set before installing the heater boxes. Most of the silicone will squish out as you tighten down the nuts and the rest will burn off eventually from the heat.
This is my technique for dealing for replacing the pushrod tubes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=420944
aeromech
aeromech is offline
PostPosted: Sun Nov 23, 2014 11:48 am    Post subject: Reply with quote
Please follow Busdaddy's advice about using the torch. The first time I installed these copper gaskets I didn't do it. Later, it leaked so the second time I heated them up red hot and let them cool. They were significantly softer than before. I also made sure that the F pipe had smooth, even tips where they contact the copper gaskets. I used super glue to hold them in place prior to installing the F pipe. I also tried to torque the nuts evenly as I drew the pipe to the head.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Nov 23, 2014 11:58 am    Post subject: Reply with quote
Also worth reading is this from Bob Donalds....
http://www.suburbanengine.com/articles/hbmanifold.htm
and this
http://www.ratwell.com/technical/Exhaust.html
dugfresh
dugfresh is offline
PostPosted: Sun Nov 23, 2014 12:04 pm    Post subject: Reply with quote
This is a video I made of Anealling my copper gaskets per the above instructions.
https://plus.google.com/u/0/photos?pid=6030503069397997666&oid=118086300295259808382
**EDIT** Uploaded to Youtube as well
http://youtu.be/UObYuQmfEqg
78 Riviera
http://flic.kr/s/aHsjDRJPa1
1967250s
1967250s is offline
PostPosted: Sun Nov 23, 2014 10:08 pm    Post subject: Reply with quote
What I do- Once you have the copper gaskets annealed, see how they fit into the recesses. Then carefully tap it on the curved ends with a hammer LIGHTLY, so it spreads a little bit, fit into recess. If you have done it right, they will need a little tap to go in and will hold there without any help. The grease idea sounds good, too.
'72 Elm Green Deluxe
1970bay
1970bay is offline
Sad OH.not so easy Sad
Im at the French Spanish fronteir and have no more than a clean area of blacktop on which the bay is standing,
To change the exhaust i found a French garage with three lifts and a help.One of the lifts has broken.
Now i have the copper joints,ive found a Spanish garage with one lift,and if im not done in about half an hour he might lower the lift and push me out done or not Sad i have no choise.
I didnt see any gas bottles there?i have known garages & plumbers that have been out of gas
At 8am i will be there by 9am it will be done.i certainly will do what i can to heat the copper,but i wont drop the tubes below the pushrod tubes.last time i had to use a tyer leaver to ease past the tubes.I cant be worse than it is with tin gaskets cut out from normal manifold gaskets
If its still not sealed today,ill buy four more copper joints and hope the French garage.lets me back when the lift is fixed in two weeks
1967250s
1967250s is offline
PostPosted: Sun Nov 23, 2014 10:13 pm    Post subject: Reply with quote
Maybe find a stove with gas, or a someone with a propane torch?
1970bay
1970bay is offline
Im useing a slow 3G connection and tethering to post from my tablet.The connection is sooo slow youtube wont play
Ill look for a cafe they dont open until 7am and are FULL until 8am
1970bay
1970bay is offline
PostPosted: Sun Nov 23, 2014 10:21 pm    Post subject: Reply with quote
Yes.ive taken the sink stove unit out for the moment to give more room but i have a camping gas unit which ill try
Stupidly i left the copper joints at the garage.When he said i could do the work on Sat.I thought he meant his mechanic,but he said id have to do it by myself and i wasnt ready for that
Its a bit of a disaster.I wish id known what i had to do to start with.I had no idea it would be so much work just changeing the exhaust
Wildthings
PostPosted: Mon Nov 24, 2014 2:02 am    Post subject: Reply with quote
Annealing the copper gaskets is unnecessary unless one or both of the sealing surfaces is quite messed up. Don't sweat it if you can not do this added step that is not mentioned in the Bentley or any service bulletin that I am aware of. If you are using used gaskets then yes anneal them. Do get the flanges flat and then round the edges slightly so they don't dig into the soft aluminium heads as you slide the heads into place. I would also recommend not drilling the holes in the flanges any larger if the heads will slip readily into place without doing so, I certainly would not go a couple of steps larger as mentioned in the Boston Bob article. Running an 8mm or very slightly larger bit through the holes to clean them out is a good idea though. You want to be cleaning out the rust, not removing metal unless the flanges just will not fit easily over the studs in the heads.
If you have some blacktop to work on and a few blocks you can position under the rear tires to lift the rear end up 100cm or so you don't need a lift. I would recommend installing each heat exchanger separately and not trying to install the entire exhaust at once, though some people do do it that way.
Amskeptic
Amskeptic is offline
PostPosted: Mon Nov 24, 2014 8:46 am    Post subject: Reply with quote
I was going to say . . .
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
jtauxe Premium Member
jtauxe is offline
PostPosted: Mon Nov 24, 2014 9:04 am    Post subject: Reply with quote
Agreed. Most of us do work on pavement, without access to a lift. If you can raise the rear end onto blocks, that certainly will be helpful.
As for installing the components, I would recommend not attempting to install a completely assembled exhaust all at once. It will inevitably need to be taken apart, or at least loosened up, to get everything to fit. In my experience, exhaust systems never line up nicely, even if they are the same system that was just on there.
I would recommend installing the F-pipes first, leaving the header nuts a bit loose so that things can wiggle. The install the heater boxes and the muffler, again with all the nuts and bolts in place, but loose. Once everything is hooked up, start with the header nuts and get them torqued properly. Then work your way through the joints of the exhaust, tightening nuts along the way.
Bonne chance, mon ami!
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
1970bay
1970bay is offline
PostPosted: Tue Nov 25, 2014 2:34 am    Post subject: Reply with quote
Monday was a nightmare.
I arrived at the Spanish garage to find the lift in use.I asked about heating the joints,which fell on deaf ears.While i waited i set up the camping gas,cooked the joints by hanging one on each arm,then plunging each in turn into water.
That done i could drive on to the lift.I showed the mechanic what had to be done.The manifold bolts were off and the heat units unscrewed.We pulled and the whole unit fell the exhaust hitting my head.
At this point the mechanic was told to get on with another job.
I was told i had to do the work alone Confused I remembered what id read hear and had brought locktight,i cleaned the ports filed the manifold tops with care- the entire system now on the garage floor, the joints "glued"in place.I asked for help to lift the unit back into place Sad
A mechanic came to help,we lifted the untit up put a plank under it,then there was the garage owners wife telling the mechanic to get back to work,and shouting at me,i had to do the work alone Sad Confused Shocked
I went to ask for help but the wife told me her husban had gone out.
The garage was a mess tools in no order and poor condition,i asked for wooden block or somthing to put in place as i lifted the unit up from the plank.The mechanic were afraid of there boss and more of the awful wife
One of the braver mechanics who spoke French came to put a new bulb in the lamp and helped lift.but had to flee when the wife came out again
I thought then of putting the unit in the VW and asking to escape,but blocked in,i decided to do what i could as on the lift it was better than on the ground
Eventualy i found jacks & leavers got one side In place.the otherside was almost in place.At 11.00 my hair soaked in oil hands black the owner was back.I told him i needed help,and got it with two of us pushing and tapping with hammer and chisel it slid into place
Bolts on and tight the wife was back shoulting at me,
The lift was lowered i put covers heating tube no in place nuts bolts glue in the camper.put tools back,helped push the car blocking escape out.and flead
Alone with no help i drove off the lift avoiding cars and out.Then came back to pay,was alowed to wash.then the owner said i had to pay nothing at which his wife came out of the office
My Camper flew accros the frontier to France a hot shower and change of cloths.i was still black
Work will continue on the park place this afternoon,
Will i have to retighten the manifold bolts,will the copper joints compress further with the engin run??
busdaddy
busdaddy is offline
PostPosted: Tue Nov 25, 2014 7:37 am    Post subject: Reply with quote
Wow! quite the adventure!
Yes, you'll have to retorque or tighten up the nuts at least once soon and maybe check them again in a week.
Слава Україні!
aeromech
aeromech is offline
PostPosted: Tue Nov 25, 2014 9:41 am    Post subject: Reply with quote
Well you got half right. Heat the copper gaskets until they are red hot and then let them air cool. Do not quench them in water. That's the difference between annealing and tempering.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Heyfishguy
Heyfishguy is offline
PostPosted: Tue Nov 25, 2014 4:16 pm    Post subject: Reply with quote
Cool story, sounds like an adventure!
Copper is too soft to temper. Quenching in water is the standard way to anneal copper.
Tom
