alaskadan Samba Member
Joined: January 09, 2013 Posts: 1937 Location: anchor pt. alaska
Posted: Fri Dec 05, 2014 8:41 am Post subject: audi parts |
Theres a 99 audi A4 for sale up here for 700 bucks 1.8t with 150k on it. Says was running fine then wouldnt start not a mechanic could be easy fix. I know could be anything. Are there a bunch of parts on it worth getting for my syncro? Bigger brakes , the engine for a conversion on my other syncro? Seems im always hearing about audi stuff getting put
on vanagons. Theres a cheap quattro too. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15367 Location: Syracuse, NY
Posted: Fri Dec 05, 2014 9:53 am Post subject: |
rims, maybe brakes if you're handy.
the engine is a great DIY 1.8T (again if you're handy)
but pop the upper timing belt cover off and verify it's still on there tight and 1 piece..
the no start could be as simple as a corroded starter wire.
could be a mashed timing belt.
for $700 I'd drag it home.. but I have a 99 1.8T in my van. _________________
Abscate wrote: |
Posted: Fri Dec 05, 2014 10:03 am Post subject: |
Thanks. Are all 1.8t s created equal? (Dumb question but...) im handy. |
hans j Samba Member
Joined: May 06, 2006 Posts: 2741 Location: Salt Lake City UT
Posted: Fri Dec 05, 2014 10:51 am Post subject: |
Sounds like a timing belt to me too. Open the cover and have someone crank it, watch the cam pulley to see if it turns.
That engine is based off the earlier block design (058), big intake port, no secondary air to deal with, 150hp, possible sludge!
Sounds like kind of a lot for a non runner if it's major engine damage. Could even be a fuel pump or a crank position sensor. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Fri Dec 05, 2014 10:52 am Post subject: |
NOPE not all created equal but the (AEB) code 1.8Ts are great intro units.
they are only 150hp stock. vs the 02+ 180hp 1.8Ts. but there's a chip to bring the AEBs to 190hp.
the AEB 1.8Ts have the same external waterpump as the earl I4 ABA engines.
this is both a benefit or a hindrance depending on what belted accessories you want/need to run.
the 150hp 1.8Ts are easiest to adapt the wiring harness. and the ECU doesn't require a flash to overcome the lock-out function.
there's a few 1.8T info threads out here, so take the time to study (maybe print for hi-liting)
alaskadan wrote: |
Abscate wrote: |
_smoker_ Samba Member
Joined: July 24, 2009 Posts: 108 Location: Farmville, VA
Posted: Fri Dec 05, 2014 10:53 am Post subject: |
alaskadan wrote: |
No. But none of the versions have huge downsides. The earlier AEB has a larger port head, and lots of the Audi guys going for big power like them better. _________________ I like Volkswagens. |
vdubdr70 Samba Member
Posted: Fri Dec 05, 2014 10:58 am Post subject: |
hans j wrote: |
Sounds like kind of a lot for a non runner if it's major engine damage. Could even be a fuel pump or a crank position sensor. |
The AEB engine also has no immobilizer to deal with, But the sludge issue is huge. These engines spent the first few years of their lives with a oil capacity of 3.9 Quarts, Until a larger oil filter was made to bring the capacity up to 4.5 Quarts. I prefer the newer 06a 1.8t blocks over the older 058.
I was at the junkyard yesterday and there were 9 Passat and Audi a4 Cars with engines in them. Some had the valve covers removed and the internals were just plain nasty. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Fri Dec 05, 2014 11:49 am Post subject: |
Flint even figured out how to install the AEB under the lid at fifty degrees with diesel bits _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2725 Location: East Nassau, NY
Posted: Fri Dec 05, 2014 5:48 pm Post subject: |
What can be used on your syncro from an A4 Quattro
Wheels
Engine
Transmission
Driveshaft
Brakes
Gauge cluster
Rear diff
Radiator fan resistor
ABS/traction control system (untested as of yet) |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1350 Location: PNW - its a dry rain.
