Where to use Permatex on type4 Engine...
Henrik_K
Henrik_K is offline
PostPosted: Mon Dec 22, 2014 12:21 am    Post subject: Where to use Permatex on type4 Engine... Reply with quote
I'm planning on putting my cylinders and heads on during the Chrismas.
I've seen Jack Ruby putting Permatex on the bottom end of the cylinders - but how about the top end?
Since my heads have been machined, Im planning on using the head gaskets to have enough clearance..
Thanks,
Henrik
timvw7476
timvw7476 is offline
PostPosted: Mon Dec 22, 2014 1:24 am    Post subject: Where to use Permatex on Type 4 engine Reply with quote
Probably use Permatex where ever you choose, but.....
most apply it at cylinder base, with shim(s), spacers, or what
you need for piston squish area.
Sealants are usually deleted at the head to cylinder area,
head gaskets, or no head gaskets, lightly oiled threads & 23-24 ft/lbs torque.
Jack Ruby shot Lee H. Oswald, who may or may not of shot JFK.
Jack Raby is the type 4 engine developer applying Permatex.
My apologies for our unsettled national history.
Enjoy assembling your engine!
oscarsnapkin
oscarsnapkin is offline
PostPosted: Mon Dec 22, 2014 6:47 am    Post subject: Re: Where to use Permatex on Type 4 engine Reply with quote
They played in a band together too.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
SGKent Premium Member
SGKent is offline
PostPosted: Mon Dec 22, 2014 8:30 am    Post subject: Reply with quote
RTV at the cylinder base.
I use a little copper coat on the top of the cylinders before the heads are put on. Many of us lap the cylinders first to be sure that the surface is even.
George Carlin:
Skills@EuroCarsPlus:
raygreenwood
raygreenwood is offline
PostPosted: Mon Dec 22, 2014 10:31 am    Post subject: Re: Where to use Permatex on Type 4 engine Reply with quote
Oh thats excellent! Laughing
Ray
Oil Phil-M
Oil Phil-M is offline
PostPosted: Mon Dec 22, 2014 11:27 am    Post subject: Reply with quote
For the cylinder - head interface you do not want to use the gaskets. Even VW themselves told their mechanics to stop using them. If you need more clearance you have to shim the cylinder from the bottom or it some cases you can have the pistons shaved. I did the later as I had dished pistons and needed to increase the compression ratio.
When it came time to assemble I used some copper based high temp permatex spray form-a-gasket stuff. I think at first I tried the brush on version but it was too difficult to get it evenly applied
http://www.permatex.com/products-2/product-categor...ant-detail
Once I figured out which cylinder was going where, I lapped the head with the cylinders using ajax with just enough water to make it a paste. Work all the cylinders evenly (same pressure, same number of rotations). After thorough cleaning spray the cylinder head's cylinder mating surface with this copper stuff. Make sure the spray is done evenly then I believe I gave it a very short dry time before assembly.
This gasket stuff is designed to seal the head for a bit of time while the carbon buildup is developing inside the combustion chamber which has a further sealing effect
Wildthings
Wildthings is offline
PostPosted: Mon Dec 22, 2014 12:47 pm    Post subject: Re: Where to use Permatex on type4 Engine... Reply with quote
Thanks,
Henrik
If yours is a 2.0L engine, 94mm bore, you don't want to use sealing rings on the heads. With the earlier 1.7 and 1.8L engines the sealing rings were not a big problem, but are usually deleted anyway. The cylinder base gaskets can be had in different thicknesses to give the deck height you want. Machining the heads doesn't affect deck height unless they had a step originally, it does affect head volume. You want to keep the deck height from being excessive as too big a deck will give disappointing performance.
Jake Raby
Jake Raby is offline
PostPosted: Mon Dec 22, 2014 11:17 pm    Post subject: Reply with quote
The Volume 8 Bug Me Video is now 15 years old. Sealant development has come a long way in that time, PLUS we wanted to use something in the video that was easy to get.
Today I use Dreibond 1248 on cylinder bases.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
Henrik_K
Henrik_K is offline
PostPosted: Tue Dec 23, 2014 3:29 am    Post subject: Reply with quote
Thanks guys,
Sorry about the misunderstanding of US shooting-history Smile
I just curious; Why is no head gaskets more important on a 2.0 than 1.7/1.8 ?
Tcash
Tcash is offline
PostPosted: Tue Dec 23, 2014 7:56 am    Post subject: Reply with quote
Wildthings wrote:
Tcash wrote:
Sunken Valve Seat
Good example of a 2.0L head gasket failure as well.
raygreenwood
PostPosted: Tue Dec 23, 2014 8:53 am    Post subject: Reply with quote
Do you like to let it tack up or dry or just install it wet? I understand the carbon seal benefit. Previously I have used Indian head in this same way with good results.....but if the head comes off for any reason....it pretty, much takes bead blasting to remove it cleanly.
Does the coppercoat come off any easier? Ray
SGKent is offline
PostPosted: Tue Dec 23, 2014 9:06 am    Post subject: Reply with quote
If the head is lapped then the coating is so thin it easily comes off. The copper particles are so small they are almost microscopic. Anything that carbonizes would work I think. It is just added protection. Usually I re-torque the heads the next day before putting the tin on, and if they come off one can see where the cylinders have indented the aluminum so it is probably overkill. Also, if the engine is ever out and the tin off I will re-torque the heads as a precaution in case they have loosened from heating and cooling cycles.
George Carlin:
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Dec 23, 2014 9:15 am    Post subject: Reply with quote
The 94mm pistons (2.0) had clearance/scuffing issues due to uneven heat expansion of different metals. Eliminating the gaskets brought the head heat to the cylinder walls quicker so the expansion rates of all components would be more coordinated.
Robbie
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
Jake Raby
PostPosted: Tue Dec 23, 2014 9:19 am    Post subject: Reply with quote
The factory head gaskets are comprised of 3 thin (.007") aluminum folded over each other. When the engine gets hot and goes through thermal shock the head studs can loosen.
Once this happens cylinder pressure and heat will torch the head gaskets, then the cylinder head, then the cylinder.
I haven't used a head gasket since the mid 90s, and never will again.
Jake Raby
raygreenwood
PostPosted: Tue Dec 23, 2014 10:36 am    Post subject: Reply with quote
Thanks. I lap my cylinders in. I guess its just the indian head. It leaves a film either way...actually more of a discoloration. ....and very thin but you can tell its still there.
I will try the coppercoat on this next engine. Ray
Tcash
Tcash is offline
PostPosted: Tue Dec 23, 2014 10:48 am    Post subject: Reply with quote
Here's one for you. I was watching a program about building a air cooled airplane engine.
They applied sealant to the case. Then they laid down two pieces of thin silk thread and joint the cases.
I remembered years ago, splitting a case and finding thread and thinking what the heck.
The program brought it altogether for me.
Any thoughts on this process?
Thanks
Tcash
Jake Raby
PostPosted: Tue Dec 23, 2014 10:52 am    Post subject: Reply with quote
Been doing that for years... Waxed dental floss split in half works wonders too.
Jake Raby
busdaddy
busdaddy is offline
PostPosted: Tue Dec 23, 2014 11:03 am    Post subject: Reply with quote
Thanks
Tcash
http://www.lycoming.com/Portals/0/techpublications...alants.pdf
Слава Україні!
