TDI PD130/150 intake manifold upgrade in AHU vanagon
tclark
tclark is offline
PostPosted: Fri Dec 26, 2014 12:38 pm    Post subject: TDI PD130/150 intake manifold upgrade in AHU vanagon Reply with quote
This only for those with tdi conversions installed
My ahu tdi conversion was throwing a 1403 err, I checked and the egr diaphragm is busted...
I dont want to do a egr delete & I do want to move to a vnt turbo down the road ....
It looks like a good replacement when installed in mk3 jetta ahu is to use pd130 intake manifold with a standalone egr valve
pd130 038129713AJ driver side inlet & egr 038 131 501 AN ?
Now i have never seen how a pd130/150 is installed in a car so what orientation
(driver side or passenger side inlet) on the pd intake manifold is used when installed in our vans with a AHU TDI?
If anyone knew the correct parts# that would remove all confusion
thx tim
89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold)
zeohsix
zeohsix is offline
PostPosted: Fri Dec 26, 2014 2:04 pm    Post subject: Reply with quote
If you want it to point towards the rear of the van...passenger side inlet, front of the van use a drivers side inlet. I have a spare passenger side inlet PD150 intake I can make someone a deal on, most installations will use the rear facing inlet ( passenger side )
I'm Cheap! I'll build that Syncro Westy myself and save money but, my labor is "FREE" especially if I ever go to sell it! One thing is I will know the quality of the parts and labor that went into the build and rest better when I'm actually driving said Westy down the road!
hans j
hans j is offline
PostPosted: Fri Dec 26, 2014 2:46 pm    Post subject: Reply with quote
I've been thinking about using one for my upcoming AHU conversion if I can find one cheap. If not I am thinking about deleting the EGR, cutting and flipping it around to point towards the back of the van.
The ALH intake also points to the back of the van and it's what I have on my syncro, but with EGR delete.
I believe the PD intakes do flow more, but only really see a gain when big turbos and software is used? I might be wrong though.
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
BavarianWrench
BavarianWrench is offline
PostPosted: Fri Dec 26, 2014 3:44 pm    Post subject: Reply with quote
tclark I'm curious about adding a VNT turbo to the AHU? Not to derail things but it is intake related, somewhat. I have heard the PD intake fits. I can only reference internet research. I have not used one personally, but am interested in that install as well. Anything that cleans up and or adds some power to the install I'm interested in. Thanks in advance to those with the experience!
tclark
tclark is offline
PostPosted: Fri Dec 26, 2014 3:54 pm    Post subject: Reply with quote
Good info zeohsix
Do you know which orientation provides the most trouble free orientation with regards to interference
1. Towards rear that is where the turbo is located for now that would be a kkk03
But when that turbo dies ill go to vnt, i know i need a new custom motor mount but
If the intake is also rear facing is that even more fab work or is it the best compromise
Will the egr still have clearance or do u always do egr delete with a vnt turbo ?
2. Towards the front if i install the egr valve will that have enuff clearance
Of the firewall
Is that when done on vanagon tdi conversion or a regular mk3 jetta update ?
Also in either case the pd 130/150 looks a bit wider is there any interference against the driver side inner fender
Sure would be nice to see a pic of pd130/150 install in a vanagon Smile
njt1rider
njt1rider is offline
PostPosted: Fri Dec 26, 2014 5:31 pm    Post subject: Reply with quote
I have an AHU swap in my Eurovan. I am using a PD130 manifold facing the driver side and a VNT-17. I deleted my EGR so no help there. Sorry I can't help you with best direction in a Vanagon either but the 130 manifold and vnt17 work together but I am unsure if you will be able to keep the EGR without some custom fab work. Are you trying to keep the EGR for emission test reasons? I think once you mod the engine that much, most people just delete the EGR. Don't forget you will need the EGR deleted in the tune as well as tuning to use the VNT. You will also need the proper N75 Valve to make everything work.
lloydy
lloydy is offline
PostPosted: Sat Dec 27, 2014 2:25 am    Post subject: Reply with quote
i have the pd manifold on mine, and have the one that faces the front of the van. Then a 180 bend onto the intercooler.
EGR is removed on mine
16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.”
lloydy
lloydy is offline
PostPosted: Sat Dec 27, 2014 2:00 pm    Post subject: Reply with quote
as per pm..
Allard EGR delete pipe
This is one off a longitudinal engine, like passat/A4/A6 ect.
One from a transverse engine will point to the back of the van
lloydy
lloydy is offline
PostPosted: Sat Dec 27, 2014 2:06 pm    Post subject: Reply with quote
your right in no real difference to be noticed, i fitted it so the whole inlet tract was 70mm instead of going up/down in sizes, more joins ect.
njt1rider
PostPosted: Sat Dec 27, 2014 4:03 pm    Post subject: Reply with quote
lloydy, where did you get the hoses connecting your airbox to manifold?
hans j
hans j is offline
PostPosted: Sat Dec 27, 2014 5:20 pm    Post subject: Reply with quote
In the states, check siliconintakehoses.com. They also sell the water/air intercooler parts.
Hammy1
Hammy1 is offline
PostPosted: Sun Dec 28, 2014 5:57 am    Post subject: Reply with quote
Jegs and summit racing also sells them. As well as aluminum and stainless intake pipes.
Jon H.
CdnVWJunkie Premium Member
CdnVWJunkie is offline
PostPosted: Sun Dec 28, 2014 7:37 am    Post subject: Reply with quote
What lloydy has is a pd130 intake. The pd150 faces opposite. The 2.0L BHW TDI engine uses the pd130 intake but has emissions provisions on it where the Euro unit does not so it's cleaner looking but not quite as easy to get ones hands on here in NA.
lloydy
lloydy is offline
PostPosted: Sun Dec 28, 2014 7:41 am    Post subject: Reply with quote
i could be wrong, but as far as i am aware the 150/130 thing doesn't dictate what way the inlet faces. Thats down to whether its a longitudinal or transverse engine.
tclark
tclark is offline
PostPosted: Sun Dec 28, 2014 10:53 am    Post subject: Reply with quote
lloydy
Thx for the pic you are the first person in the world to post a public pic of a pd manifold installed into a t3 Smile
Is there any difference in the width of ahu manifold compared to the pd 130/150 from longitudinal engine,, drivers side inlet
Its little dark in the pic i cant quite see is there a fair amount of room
after the manifold is mounted up between the manifold & the driver side inner fender/firewall ?
The pic does not quite show how far forward the manifold goes...
how much clearance is there between the end of the 180degree hose and the front of the firewall
(for emission reasons i am thinking of installing a 038 131 501 AN then the
180degree hose,...)
my thinking this could be a drop in replacement for a std ahu manifold with the built in egr, then no ecu tune no more 1403 = pass emissions Smile
hans j
hans j is offline
PostPosted: Sun Dec 28, 2014 11:17 am    Post subject: Reply with quote
If you are interested, I'll just trade you my AHU intake for yours. There is still a tiny bit of carbon in mine but it's pretty clear. I'm going to delete EGR anyway so I don't need one that works. I'll probably even cut the entire thing out and reweld it where I want it.
tjet
tjet is offline
PostPosted: Sun Dec 28, 2014 11:52 am    Post subject: Reply with quote
Here are the different PD150 intakes. The one considered to be a direct swap in an ALH Mk4 TDI is the AF unit below - but any should work in a swap.
For reference, here is an "AF" PD150 next to a stock ALH intake
And a stock (AUH?) vs a "BC" below
[/img]
Outback Kampers
Outback Kampers is offline
Done a couple years ago. PD130 intake, MTDI, VNT17 also mechanically controlled. Ungodly low end torque but I unfortunately grenaded the engine due to another unrelated scenario. Crying or Very sad
Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI
lloydy
lloydy is offline
PostPosted: Sun Dec 28, 2014 11:54 am    Post subject: Reply with quote
tclark wrote:
lloydy
180degree hose,...)
Lol, those pics have been on my build threads and Facebook for a fair while!
There is lots of room all round the manifold, i can get a few more pics for you. I'm out in the van for the next day or two, so it'll be after that
lloydy
lloydy is offline
PostPosted: Sun Dec 28, 2014 12:05 pm    Post subject: Reply with quote
its interesting seeing the route of your air intake, in that you have gone across the engine and down in the corner. I see this a lot on American tdi's, how do you connect to the turbo? as the intake on the turbo points to the back of the van.
