wpicotte Samba Member
Posted: Sat Jan 03, 2015 1:45 pm Post subject: GoWesty All-Terrain Suspension Bundle -- Worth It?? |
Hi everyone - I have a manual 87' Vanagon camper (Clio) with 15" wheels. I'm considering an upgrade to GoWesty's 16" all-terrain bundle, and would greatly appreciate any insights that you can share based on experience with 16s on a Vanagon.
My rationale for the upgrade:
> The existing tires are at the end of their life, so I have to plunk down for new rubber regardless. That's 25% of the total cost of this upgrade package, any which way I go.
> We're frequently off road on rough jeep roads / double tracks (Clio also sports Peloquin's LSD), in very remote locations like Three Corners, on the Owyhee in eastern OR. My assumption is that beefier tires will decrease the likelihood of a puncture in such locales, at least relative to what standard 15" tires can withstand.
> Clio's original suspension is still functional, but not that tight (she has about 160k original miles and leans through turns like a drunken lady). We carry kayaks on the roof on a regular basis, and my expectation for the suspension upgrade would be improved handling (ha ha) in general, and greater stability when carrying stuff on the roof. The 15s are a nice wheel upgrade to begin with, and I guess I'm trying to determine whether the assumed improvements or safety benefits described here are (1) realistic and (2) enough to justify the upgrade's hefty price tag
The package includes 215/70-16 BFG All Terrain tires mounted on 16" wheels, springs, fox shocks, spacers for the lift, etc. (GoWesty also recommends their calibrated speedometer, as well, due to the larger tire size). The shocks are another 25% of the upgrade's cost, and I really have no idea if going higher end has any real benefit. The standard replacements are half the cost, and I've been told that there is very little difference in terms of performance or build quality across the range of available options.
Thanks in advance for any feedback you can provide!
Wesley |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4634 Location: East Kootenay, British Columbia
Posted: Sat Jan 03, 2015 2:03 pm Post subject: |
Remember, if you have a stock engine, the larger tires will slow you down.
You might be better off staying with the 15" wheels you already own, get some 15" BFGs, OME (Old Man Emu) shocks and save some serious coin. Money better spent would be on rebuilding the suspension with new bushings, etc.
You don't say what size tires you currently have, but keeping closer to stock size gives better performance, Plus if you do go with a larger diameter tire than stock, the 15" wheel will give you more sidewall. Better for airing down off road. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
kbeefy Samba Member
Joined: March 10, 2006 Posts: 600 Location: Central Oregon
Posted: Sat Jan 03, 2015 2:06 pm Post subject: |
$2500 is quite a bit of money. There is a significant difference in shocks, I'm sure the Fox's are worth it but not sure they are going to fix any handling issues that a normally functioning shock wouldn't also fix.
The stiffer springs would probably reduce the leaning, but the added height from the springs and tires would probably offset it.
Have you considered just replacing your existing tires with an LT rated tire
(if available). Given the lack of power I'd probably avoid doing anything to reduce my final drive ratio. I have slightly larger tires than that package along with a subaru 2.5 and would definitely appreciate lower gears.
Have you checked the condition of bushings etc? at 160k it should all have been replaced, probably a couple times by now. _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
'86 Syncro Westy. Stock for now.
2000 F350 7.3 CC LB 11' Northland Cabover
2006 Subbie OBXT
2002 Tacoma DoubleCab 4x4
1969 Mustang Basket Case 351c/FMX/9
http://kbeefy.blogspot.com/ |
kbeefy Samba Member
Posted: Sat Jan 03, 2015 2:07 pm Post subject: |
haha..... What they said! _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
2006 Subbie OBXT
Posted: Sat Jan 03, 2015 2:26 pm Post subject: |
Very helpful feedback. The van still has the original engine and I'm also researching a replacement for this, but that's in the offing. Had not considered the implication to overall speed of the larger wheels / tires. The current tires are 15" LT - don't know the exact size. I certainly like the idea of saving money--the price tag is hard to swallow.
Thanks for weighing in. |
kbeefy Samba Member
Posted: Sat Jan 03, 2015 2:31 pm Post subject: |
If you already have LT rated tires then you probably won't gain a whole lot of puncture resistance. Keeping the higher aspect ratio of the 15's have several benefits off-road, the only benefit of the 16 might be better on-road handling (along with a harsher ride) and maybe more tire options. _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
2006 Subbie OBXT
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12422 Location: Santa Cruz, CA
Posted: Sat Jan 03, 2015 2:43 pm Post subject: |
| kbeefy wrote: |
| Have you checked the condition of bushings etc? at 160k it should all have been replaced, probably a couple times by now. |
That makes a big difference on how it rides in all conditions and is well worth the effort/money. That would be my first plan of attack regardless of whether you buy their kit or not. |
insyncro Banned
Posted: Sat Jan 03, 2015 2:56 pm Post subject: |
I have those shocks and have used the springs before.
If budget minded it is a good place to start but there is much better available, my opinion, if you are willing to spend a bit more money.
It all depends upon what you are looking for, true offroad performance or just a cool looking van. |
insyncro Banned
Posted: Sat Jan 03, 2015 2:59 pm Post subject: |
I also agree with the other comments.
If you are not planning on refreshing all bushings and bearings, along with CV halfshafts, you may not be overwhelmed with the performance gains and will definitely hear your van making some noises it hasn't ever made before.
This is a geometry thing and with all new parts plus a proper alignment, you will be very pleased. |
Posted: Sat Jan 03, 2015 3:18 pm Post subject: |
| insyncro wrote: |
Definitely after performance, but we're not out there to push the van's capabilities. We just get to the places we love and this sometimes entails travel on rough roads. The cool look is cool, for sure, but totally secondary to reliability and safety. |
Posted: Sat Jan 03, 2015 3:31 pm Post subject: |
| insyncro wrote: |
OK, I'm convinced that this is where I should focus, while keeping the 15" wheels and replacing the tires as needed.
While I have everything pulled apart, the question then becomes whether it is worthwhile to replace the existing springs / shocks? I do think that compared to when we purchased the van about 20k miles ago, the suspension is looser / springier.
Assuming there's a tangible to gain from replacing existing parts, how much difference exists between standard vs. upgraded replacements if, as I mentioned in a different reply, I'm not trying to create an off road monster but rather ensure reliability / performance (while keeping things pragmatic) because we do get remote. |
insyncro Banned
Posted: Sat Jan 03, 2015 3:40 pm Post subject: |
Stock is stock, no way around that, BUT stock Syncro is pretty darn good if you ask me.
The sky is the limit for upgrading.
My advice, get as many ride alongs in differently set up vans with drivers of different styles and you will find the combo of parts that matches your needs perfectly. |
Posted: Sat Jan 03, 2015 3:51 pm Post subject: |
You should start from the beginning. Bushings- stock rubber or poly and work from there. Shocks and springs are a hot topic but build it on a solid foundation.
Shocks, springs and tires can take up a lot of your research time while refreshing the suspension bushings is gratification that you can feel quickly.
Do a search on GW springs there are topics where some people are happy while others aren't as much.
Custom control arms, custom trailing arms, custom valved shocks, full custom suspension that requires body mods, flamethrower out the tailpipe there are lots of options depending on what you are willing to spend.  |
insyncro Banned
Posted: Sat Jan 03, 2015 3:54 pm Post subject: |
Right on Mario.
$yncro  |
Posted: Sat Jan 03, 2015 4:06 pm Post subject: |
If their GW link is correct they are rolling a 2wd adventure vehicle. |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1342 Location: Snoqualmie (WA)
Posted: Sat Jan 03, 2015 4:41 pm Post subject: |
Also note that BFG AT tires are not that great according to this tire review from Expedition Portal. I'm likely to take their lead and do Cooper Discoverer AT3 for my set of 16" tires. _________________ '91 Double Door Transporter |
DontBeAfraid Samba Member
Joined: August 09, 2012 Posts: 94 Location: San Franfuckingcisco
Posted: Sat Jan 03, 2015 5:33 pm Post subject: GW Suspension Bundle Weigh In |
Hey,
It is quite a bit of coin for all that gear.
I can't speak for the performance of any of this equipment, but I will share my setup with you.
I purchased syncro.org 2wd springs (similar price point to GW springs) and Monroe 58253 front and 58632 rear springs and installed them myself. I also added General Grabbers 27x8.5R14LT onto stock alloys. At the same time I added fresh tie rod ends and upper ball joints.
I had similar aspirations as you do, and a similar budget, it sounds like. The more expensive setups were very appealing, but in the end I decided to go the cheaper route. The Grabbers were the most inexpensive tires available for the 14" alloys (and the tread pattern is ideal for what I (and you) want), the shocks were $140 for all four, and the springs were around $300. I can always change the shocks later, or add the taller springs if I want.
All told my setup ended up costing less than $1200 and it rides like a different vehicle from the worn out stock setup.
We just arrived back from five days in the Mojave for New Year's, and I am very impressed with the capability of Klaus given the roughly 18" ride height and larger offroad tires. We took several "4x4 only" roads, and granted we had to turn back eventually, we made it through some hairy spots with only two wheels working!!
Of course I have to give you a disclaimer about my setup. The Grabbers do not meet the ideal load rating for Vanagons. After 10,000 miles I have had no catastrophic failure. The Monroe shocks are nearly bolt on, but they are not stock for Vanagons. They work great, and many users here have enjoyed problem free service from this budget option.
Let me know if you want some detail about the Monroes; I compiled all the info from thesamba I needed to make a decision/install them into one document, and I'd be happy to share it with you! _________________ Dave
1989 Westfalia 2.1 Four-on-the-Floor |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Sat Jan 03, 2015 5:35 pm Post subject: |
| luVWagn wrote: |
| Also note that BFG AT tires are not that great according to this tire review from Expedition Portal. I'm likely to take their lead and do Cooper Discoverer AT3 for my set of 16" tires. |
Expedition Portal just reviewed the latest BFG. It wasn't available for the first test...it looks much better, not as good as the Cooper, but still better than the old BFG. _________________ www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab |
insyncro Banned
Posted: Sat Jan 03, 2015 5:36 pm Post subject: |
| I really enjoy my Syncro.org springs as well. |
Posted: Sat Jan 03, 2015 5:53 pm Post subject: |
FWIW here is my van now:
[img][/img] _________________ Dave
