High low beam relay
heb
heb is offline
PostPosted: Wed Mar 30, 2005 2:16 pm    Post subject: High low beam relay Reply with quote
Hello all I have a 66 Square I am restoring right now and I am currently redoing all the electrical under the dash because the PO had there own idea as to how things should have been wired. Any how I was wondering if anybody knows what relay handles the high low beam. That is the last part I need to get working. Could it be the switch itself that is built into the turn signal?? Thanks for any help.
PostPosted: Wed Mar 30, 2005 2:22 pm    Post subject: Reply with quote
It's the turn signal relay, the black box under the dash. The switch on the turn signal arm just causes a switch to flip back and forth inside the relay
heb
heb is offline
PostPosted: Wed Mar 30, 2005 2:26 pm    Post subject: Reply with quote
Thanks Everett that is awesome. Now another question my 66 has a blue relay switch box. Will that make a difference.
PostPosted: Wed Mar 30, 2005 2:35 pm    Post subject: Reply with quote
Woops, I think I was wrong. Looking at the Type 3 wiring diagrams, there is a separate high/low relay for the headlights
It works the same though.
heb
heb is offline
PostPosted: Wed Mar 30, 2005 2:52 pm    Post subject: Reply with quote
Is this a common problem for the switch not to work on these? Is there another fix for this.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Mar 30, 2005 6:24 pm    Post subject: Reply with quote
The wires inside the T/S arm do break ocasionally. Right where they flex when the T/S are used.
Gary: OK. Ima poop.
cool blue
cool blue is offline
PostPosted: Wed Mar 22, 2017 9:13 pm    Post subject: Re: High low beam relay Reply with quote
similar prob... my blue light is on in the dash, indicating "high beams"
so i guess my low beams are not working, did the filament burn out in the bulbs,?then the previous owner replaced the yellow fuses? also: when i turn on my hazards, the relay buzzes, and no lights are flashing outside the car...still pluginn
stonecoldcars
stonecoldcars is offline
PostPosted: Mon Mar 27, 2017 9:07 am    Post subject: Re: High low beam relay Reply with quote
My high/lows were not working on mine. Turned out to be the turn signal switch itself. The little contact points plastic arms had broken.
My build thread(The desert Rat). http://www.thesamba.com/vw/forum/viewtopic.php?t=653395
cool blue
PostPosted: Wed Mar 29, 2017 8:33 pm    Post subject: Re: High low beam relay Reply with quote
hmm, in realized after i ordered a new headlight switch, the numbers don't match. e.g; 58b is not 58b... its some other #
i gotta contact cIP1 in the morn.
hey, i saw your ride u got from Arizona. nice, are those Hellas u have for front lights ?
stonecoldcars
PostPosted: Thu Mar 30, 2017 12:02 pm    Post subject: Re: High low beam relay Reply with quote
My amber front fogs? they are old Unity lamps that I inherited from my grandfather who ran them on his 53 Buick way back. They were 6v clear lamps. I found some later amber 12v's and installed them.
