Best distributor for 1600 engine with Weber Progressive carb
donemoto
donemoto is offline
PostPosted: Wed Jan 21, 2015 3:23 pm    Post subject: Best distributor for 1600 engine with Weber Progressive carb Reply with quote
I have a 75 Bus with a 1600 dual port engine. It currently has a Weber Progressive carb and a 009 German distributor. I am not getting a good range of advancement. I have to fan the gas petal to get it to run at start-up. I t is sluggish when driving it around the block. I'm guessing the springs are worn or streched out. I plan to keep the Weber and replace with a VW vacuum distributor. What kind is best for this set up? The engine is a low mileage recent rebuild. I've done tune-up job...timing , valves, ect.
1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1980 Honda Cub 70
Danwvw
Danwvw is offline
PostPosted: Wed Jan 21, 2015 4:16 pm    Post subject: Reply with quote
It probably needs stronger spark! Single center mount is not the best set-up for them. I would consider getting a much better distributor and coil. Perhaps the Pertronix Flame thrower set-up in that new Vacuum Advance Distributor your thinking of buying.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
busdaddy
busdaddy is offline
PostPosted: Wed Jan 21, 2015 4:53 pm    Post subject: Reply with quote
Sadly there's no distributor that fits in a VW engine that plays well with the vacuum signature of that Weber, it makes vacuum at idle, no VW carb does that. The 009 is pretty well the best choice for that combination.
That said, the symptoms you describe sound more like jetting and setup issues with the carb, in cooler weather preheating the intake air also helps a lttle bit.
Слава Україні!
Tcash
Tcash is offline
PostPosted: Wed Jan 21, 2015 5:52 pm    Post subject: Reply with quote
Make sure you do a full tune up first. The carb is the last thing adjusted.
Centermount, progressive, 2BBl carb on Type IV doesn't suck
How to make a progressive work properly on a VW engine
Good Luck
Tcash
Wildthings
Wildthings is offline
PostPosted: Wed Jan 21, 2015 7:10 pm    Post subject: Reply with quote
I haven't done it on a Type 1 engine, but I would expect that disabling the power valve and jetting the carb a bit richer would work on a Type 1 just the same as it works on a Type 4. With the power valve operating the carb will tend to run lean coming off idle and then run overly rich at cruise, this is just not what you want. Note that most carbs used on these engine do not have power valves and at least one carb even uses a reverse power valve. The power valve mod is easy to do and easily reversible if it doesn't work.
aeromech
aeromech is offline
PostPosted: Wed Jan 21, 2015 7:59 pm    Post subject: Reply with quote
Maybe you need to fix your 009 or replace it. Best to hook up a timing light and watch the advance while you crank the throttle. Might just need some lube or it has a broken spring.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash
Tcash is offline
PostPosted: Wed Jan 21, 2015 9:01 pm    Post subject: Reply with quote
Lubing the Distributor
madmike
madmike is offline
PostPosted: Thu Jan 22, 2015 5:58 am    Post subject: Reply with quote
not a big fan of progressives Rolling Eyes
1 out of 10 work on a vw motor(remember the 'Pinto'??)
The sweetest set up I've even come across is a pair of 40 idf's an a 034 dizzy
My 2 cents Wink
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Esher127
Esher127 is offline
PostPosted: Thu Jan 22, 2015 6:15 am    Post subject: Reply with quote
Good Luck
Tcash
So much this. The difference between a weber progressive out of the box and one that's been properly jetted/tuned for a bus is absolute night and day. They also need to be HOT, and run like crap if they aren't.
1970 Westfalia Pop-Top
