Leaving ignition on for electric choke.
37emeralds
37emeralds is offline
PostPosted: Thu Jan 22, 2015 9:26 pm    Post subject: Leaving ignition on for electric choke. Reply with quote
When my engine warms up and the electric choke is open all the way, it runs perfect. But after parking the bus at a store, when I come back and start driving, it runs like crap because when I left it off, the electric choke closed. I have to drive for a few minutes with a bucking, kicking engine until the electric choke opens up again. My question is, can I leave the ignition on with the engine off while I run in the store for a few minutes? This way, there will be constant power to the electric choke and it will stay open. But will leaving the ignition on risk damaging anything? I have a Bosch blue coil and a pertronix ignition. And if I do risk damaging something this way, will it be ok to run a separate switch to the electric choke for that purpose? This way, I can shut the ignition off and flip the switch to only provide power to the electric choke while I run to, say, a store for a few minutes? This problem gets very annoying especially because the choke closes so fast. All it takes is a stop at a gas station for some fuel and I have to either idle to wait for the choke to open, or drive for a few minutes with an engine that feels like it's running on two cylinders!
Tcash
Tcash is offline
PostPosted: Thu Jan 22, 2015 9:44 pm    Post subject: Re: Leaving ignition on for electric choke. Reply with quote
37emeralds wrote:
But will leaving the ignition on risk damaging anything? I have a Bosch blue coil and a Pertronix ignition.
It could burn the Pertronix Ignitor module out.
It would be easier to adjust the choke.
Good Luck
Tcash
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Jan 22, 2015 11:17 pm    Post subject: Reply with quote
I personally think your symptoms are cause by the choke, but the problem is not.
The choke richened the mixture. Cool. So you're saying you have poor drivability during rich conditions; let's look at that. What kind of induction and distributor do you have? Single carb? Duals? Fuel injection? Distributor model number and vacuum setup? Are we still talking about Volkswagens?? Wink
How do you set your mixture with your above system? If your baseline mixture is too rich, then the choke system could be pushing you over the pleasant edge. If your mixture was happy, you might notice a little high RPMs as your warm up systems settle in, (different for carb or fuel injection.) on the other hand, if your mixture was too lean, you'd be having the opposite problems.
Robbie
I know the OP mentioned a "choke" which is inherent to stock carbs, but the FI system has the AAR and CSV that play the role of chokes. That way my reply helps more future readers... Allegedly... Cool
www.airschooled.com
Wildthings
Wildthings is offline
PostPosted: Thu Jan 22, 2015 11:23 pm    Post subject: Reply with quote
You sure don't give us much info. As guess I would say you have either a progressive carb on a Type 4 engine or maybe a OEM centermount Solex on a Type 1 engine but with a non functioning heat riser.
madmike
madmike is offline
PostPosted: Fri Jan 23, 2015 5:36 am    Post subject: Reply with quote
Just adjust them, adjust when COLD, just so they close very lightly.when u crack the throttle open,,re-tighten screws,,,,, Done
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
[email protected]
ptjjb@yahoo.com is offline
PostPosted: Fri Jan 23, 2015 5:49 am    Post subject: Reply with quote
X2. I find I need to readjust from summer to winter and back when it warms up again. I need to do that only twice a year, unless we have an stunning warm spell.
Maybe that is why John Muir hated that auto choke so much, a little practice with a manual choke and you hit it right on every time.
Tom Powell
Tom Powell is offline
PostPosted: Fri Jan 23, 2015 8:33 am    Post subject: Re: Leaving ignition on for electric choke. Reply with quote
and/or the coil AMHIK
Aloha
tp
37emeralds
PostPosted: Fri Jan 23, 2015 10:06 pm    Post subject: Reply with quote
My apologies for not providing enough info.
1970 VW Transporter with a 1600cc engine code AK. Single carb. Solex 30 PICT 2 carb. 009 distributor no vacuum advance. The AK engine came with a vacuum only advance dizzy, so yes, I do have a slight flat spot issue.
I will adjust the choke tomorrow. I am kinda starting to understand why Muir liked the manual choke.
airschooled
Air-Schooled
PostPosted: Fri Jan 23, 2015 10:15 pm    Post subject: Reply with quote
37emeralds wrote:
…009 distributor no vacuum advance… …I do have a slight flat spot issue…
…I am kinda starting to understand why Muir liked the manual choke.
So rather than go back to the correct distributor, you would rather disable ANOTHER system that the VW engineers designed to give you supreme drivability and efficiency? The choke and fast-idle cam work perfectly with a twice-a-year adjustment if you have all four seasons. If your distributor can passes the vacuum test, I would SERIOUSLY give it a shot before messing with anything else.
Muir was good at getting broken down cars back on the road, but following his advice is a slippery slope to timing be ear and putting a hole in your pistons.
www.airschooled.com
Wildthings
PostPosted: Sat Jan 24, 2015 9:52 am    Post subject: Reply with quote
Check to see that your intake manifold is getting nice and hot, it should be quite hot within minutes of startup. Your intake air preheat stove needs to be working correctly as well.
Set your choke to the lean side if anything. You want it to fully open after a cold start in just 3-5 minutes, if the carb is getting the proper heat then you should not have to reset it seasonally.
37emeralds
PostPosted: Sat Jan 24, 2015 12:12 pm    Post subject: Reply with quote
I do realize that I need to go to the stock distributor. And I do agree that the system is properly engineered. But the problem is, it's hard to find a good vacuum advanced only distributor. I do not want aftermarket crap, and if original ones do pop up on thesamba, they are usually in a very poor condition. A good hunt takes patience!
My preheat stove is not working correctly due to the missing cable that runs from the fan. This is another project on hold till spring.
airschooled
Air-Schooled
PostPosted: Sat Jan 24, 2015 12:25 pm    Post subject: Reply with quote
Forget about the cable- wire your air cleaner in the "warm air intake" setting in the winter and let it take in cold air in the hottest summer months.
www.airschooled.com
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 24, 2015 12:39 pm    Post subject: Reply with quote
what others said and
the choke should not close while you are in a store. When it is adjusted right, it will only take light pressure to open it cold - literally just barely closing by itself. If it dies at a stop sign a minute or two away, you need a tiny bit more pressure. If it takes more than 3 - 4 minutes to warm up that is too much pressure. On automatic choked cars that I have owned they sometimes need a little tiny tweak between the summer and winter to run perfect when starting.
The 1971 had automatic pre-heat setting on the snorkel, so it may have warmed up a bit quicker than the snorkels with the manual setting. That can also affect how it runs.
37emeralds
PostPosted: Sat Jan 24, 2015 2:08 pm    Post subject: Reply with quote
a little tiny tweak
Define a little tiny tweak. The marking on the housing is at about 10 o'clock. The marking on the choke was aligned perfectly. I unscrewed the three screws and moved the making to about 12 o'clock. Took it for a run and it runs fine on cold now Cool
SGKent is offline
PostPosted: Sat Jan 24, 2015 3:43 pm    Post subject: Reply with quote
37emeralds wrote:
a little tiny tweak
If it runs Ok now leave it.
Assuming mixture and idle speed are properly set so it runs well when warmed up, this is the test I use for a carbed engine - Step on the gas part way and release when cold. That will set the choke. Push down about 1/3 the way on the throttle and crank it. It should start almost immediately. Gently rev it a little to make sure all cylinders are firing (do not race a cold engine, especially in low temperatures, or it may damage an oil cooler or toss a rod) You drive off gently. About two minutes later if it is stumbling from being too rich you need less choke. Or, if it is dying when you take your foot off the gas when you come to the first stop sign or light, it needs more choke. A tweak is like moving the line 1/16" to 1/32" at a time until it doesn't do that anymore. It may take several mornings and changes in weather to get it just right. When you are sure it is right for the season, make a scribe line when you find the sweet spot in summer, and another in winter and you can go right back too it next winter/summer. The factory lines on the carb are close but not perfect. If you ever have to change the element due to it burning out, the spot will change a little again so don't make too deep a scribe line that you can't add another or change it.
Abscate Premium Member
Abscate is offline
PostPosted: Sat Jan 24, 2015 6:44 pm    Post subject: Reply with quote
The note about running warm air in winter and cold in summer will work in CA, but not in MA. In -10F, you need air cleaner preheat, exhaust preheat, and the choke to be all working and adjusted correctly.
airschooled
Air-Schooled
PostPosted: Sat Jan 24, 2015 7:25 pm    Post subject: Reply with quote
Absolutely! Heck, you need all those things here in San Diego if you want new-car-like drivability. I only brought that up because the OP talked about missing the rare early bay warmup cable.
www.airschooled.com
SGKent is offline
PostPosted: Sat Jan 24, 2015 7:29 pm    Post subject: Reply with quote
I did not know MA was -10F in summer but I will stand corrected. I thought it was warmer there in summer, and that is why you could fix the preheat in summer position during the summer months.
37emeralds
PostPosted: Sun Jan 25, 2015 7:36 am    Post subject: Reply with quote
It seldom gets -10F during winter here! Rolling Eyes
Wildthings
PostPosted: Sun Jan 25, 2015 10:25 am    Post subject: Reply with quote
One thing that I do to help keep my engine warmer in the winter is to block off one of the pillar vents. This keeps wind from blowing in one vent and out the other cooling the carb and intake manifold in the process. I have thought about building a shield that I could install under the engine as well, kind of like what VW had for the Vanagon Diesels.
