Stock Distributor Advance Curve Diagrams
PostPosted: Tue Jan 20, 2015 4:56 pm    Post subject: Stock Distributor Advance Curve Diagrams Reply with quote
With thanks to mikedjames for posting these in the Gallery
[Edit: dupes removed]
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Jan 20, 2015 6:43 pm    Post subject: Reply with quote
Shocked
So beautiful! Thank you!
Very Happy
www.airschooled.com
Road trip reports and tech blog:
Tcash
Tcash is offline
PostPosted: Sun Feb 15, 2015 11:35 am    Post subject: Advance curve for Bosch ZV PAU 4R5 distributor Reply with quote
Tcash
Tcash is offline
PostPosted: Sun Feb 15, 2015 11:36 am    Post subject: Advance curve for 36hp bus distributor VJUBR8 Reply with quote
Multi69s
Multi69s is offline
PostPosted: Sun Feb 15, 2015 2:31 pm    Post subject: Reply with quote
Sticky ? Very Happy
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Feb 15, 2015 8:39 pm    Post subject: Reply with quote
X2
Although I have to ad that some of those diagram labels do not ad up to a recognizable distributor - at least not for VW.
Roads Scholar
Member# 2059
67 Sunroof
67 Sunroof is offline
PostPosted: Sun Feb 15, 2015 10:41 pm    Post subject: Reply with quote
I'll be the first to ask.....awesome but what do they mean?
Which is right for me? How can I tell?
Juanito84
Juanito84 is offline
PostPosted: Mon Feb 16, 2015 10:30 am    Post subject: Reply with quote
What do they mean?
These graphs show the acceptable advance curves for VW distributors. So if you have one of the distributors listed on any one of these graphs then all you have to do is check your advance curve(s) and see if your distributor is still within spec.
Some graphs only have one curve on them, measured against vacuum (mm HG) with no RPM listed. These are vacuum only distributors like the ones used on 1970 and older manual transmission VWs. There are some with two advance curves, one marked "a" (vacuum curve) and the other marked "b" (centrifugal curve). These are SVDA style distributors. The ones with three curves (one of them bends down) are DVDA style distributors.
Note that the degrees are distributor drive degrees. To get crankshaft degrees you will need to multiply the number of degrees by two.
Generally, this is just to make sure your distributor is within spec, not for chosing a distributor. Normally you would chose the distributor based off the number on the carb. But I suppose you could put it on a dyno and find a distributor with a curve that matches your engine even better.
If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine?
67 Sunroof
PostPosted: Mon Feb 16, 2015 5:38 pm    Post subject: Reply with quote
Thanks man! I have several of the above distributors. I have no idea which to use with my stock 1600dp with baby dells (34b) carbs.
I've been told the svda would be best (205) but have only dvda distributors. If I leave the retard advance disconnected I assume it would only affect the third curve?
Thanks again Very Happy
Juanito84
PostPosted: Mon Feb 16, 2015 7:47 pm    Post subject: Reply with quote
Correct. Just leave the vacuum retard disconected.
As far as the curve, I'd try the most agressively advancing curve.
modok
modok is offline
PostPosted: Mon Feb 16, 2015 7:52 pm    Post subject: Reply with quote
Nice to see this info all in one place! Thanks.
now, I guess I need to get a better computer. it nearly locks up trying to load all those images Laughing
furgo
furgo is offline
PostPosted: Mon Jan 15, 2018 8:51 am    Post subject: Re: Stock Distributor Advance Curve Diagrams Reply with quote
This is a fantastic post, but every time I've tried to find the info for a particular distributor I've spent quite a lot of time actually finding the post in the first place. Once you've found it, you then need to look at all curves to find the right distributor, as the part numbers are only on the images, which preclude a quick text search.
As I found myself doing this for the nth time today, I went ahead and added the VW part number code to each image, so that the distributor curve can now quickly be found by hitting Ctrl+F on the browser and searching for it. This should also make this post appear on the forum/Google search when giving a distributor part number as search query.
While I was doing this, I noticed there were quite a few image duplicates, which I removed. If you look at the post source you can see which images were actually removed, as their file names are all in sequence and the missing ones can easily be spotted.
To the mods: if you find this useful, please feel free to update the original post with the extra info (or replace the contents), and then remove my post to avoid duplication.
Here it goes:
Legend
111 905 205 T vacuum control curve
113 905 205 K vacuum control curve
113 905 205 L vacuum control curve
315 905 205 vacuum control curve
315 905 205 B vacuum control curve
311 905 205 T vacuum and centrifugal control curve
311 905 205 S vacuum and centrifugal control curve
131 905 205 G vacuum control curve
311 905 205 Q vacuum control curve
311 905 205 P vacuum and centrifugal control curve
311 905 205 M vacuum and centrifugal control curve
311 905 205 L vacuum and centrifugal control curve
311 905 205 AK vacuum and centrifugal control curve
311 905 205 AJ vacuum and centrifugal control curve
311 905 205 AH vacuum and centrifugal control curve
311 905 205 AG vacuum and centrifugal control curve
311 905 205 AF vacuum and centrifugal control curve
311 905 205 AE vacuum and centrifugal control curve
311 905 205 AD vacuum and centrifugal control curve
311 905 205 AC vacuum and centrifugal control curve
311 905 205 AB vacuum and centrifugal control curve
311 905 205 AA vacuum and centrifugal control curve
113 905 205 AL vacuum and centrifugal control curve
211 905 205 S vacuum and centrifugal control curve
211 905 205 Q vacuum and centrifugal control curve
211 905 205 N vacuum control curve
211 905 205 P vacuum control curve
181 905 205 centrifugal control curve
113 905 205 AN vacuum and centrifugal control curve
113 905 205 AM vacuum and centrifugal control curve
022 905 205 P vacuum and centrifugal control curve
022 905 205 Q vacuum and centrifugal control curve
022 905 205 H vacuum and centrifugal control curve
022 905 205 E vacuum and centrifugal control curve
022 905 205 D vacuum and centrifugal control curve
022 905 205 A vacuum and centrifugal control curve
021 905 205 L vacuum and centrifugal control curve
021 905 205 K vacuum and centrifugal control curve
021 905 205 J vacuum and centrifugal control curve
021 905 205 H vacuum and centrifugal control curve
021 905 205 G vacuum and centrifugal control curve
021 905 205 F vacuum and centrifugal control curve
021 905 205 E vacuum and centrifugal control curve
021 905 205 C vacuum and centrifugal control curve
021 905 205 B vacuum and centrifugal control curve
021 905 205 A vacuum and centrifugal control curve
021 905 205 vacuum and centrifugal control curve
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
furgo
furgo is offline
PostPosted: Mon Jan 15, 2018 9:59 am    Post subject: Re: Stock Distributor Advance Curve Diagrams Reply with quote
One of the reasons I was looking for this post today was because I found a piece of information that relates to my distributor, for which there don't seem to be any curves available (although the data itself is on Bentley).
There is a M107 technical note on the late Michael Knappmann's site that, once translated from German, reads:
5 - Ignition system
a - Distributor
4/1800 022 905 205 S
4/1800 021 905 205 P
The advance values for both distributors correspond to distributor 021 905 205 G (see Repair Manual section M 3.2/1-3 and M 3.3/5-20).
A while ago I plotted the distributor curve for 022 905 205 S / 021 905 205 P (which are essentially the same part, the only difference being that ..205 P has a RPM-limiting rotor):
Comparing it to the curve of the 021 905 205 G distributor, and bearing in mind that on the diagram below the RPM and advance values need to be multiplied by 2 (they refer to distributor rpm and degrees, vs. crankshaft rpm and degrees on the above):
The curves look similar enough. Comparing the actual data from Bentley and the Repair manual, there seem to be just slight differences of 0.5 advance degrees.
Decode your M-Plate
nos64notch
nos64notch is offline
PostPosted: Wed Feb 15, 2023 5:38 am    Post subject: Re: Stock Distributor Advance Curve Diagrams Reply with quote
Anyone know where I can find a curve for VW 311-905-205D?
tzepesh
tzepesh is offline
PostPosted: Thu Oct 19, 2023 1:19 am    Post subject: Re: Stock Distributor Advance Curve Diagrams Reply with quote
Does anybody have the advance curves for 043905205L and 022905205S?
'74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Korosi red (extra glitter)
Wildthings
Wildthings is offline
PostPosted: Tue Dec 19, 2023 12:19 am    Post subject: Re: Stock Distributor Advance Curve Diagrams Reply with quote
The curve for the 022-905-205s has been shown in several places in the above posts.
