Rebuilt 2.1L Throttle Body Experiences
Snort
Snort is offline
PostPosted: Sat Dec 20, 2014 7:10 am    Post subject: Rebuilt 2.1L Throttle Body Experiences Reply with quote
I'm thinking it's time for me to start looking for a rebuilt throttle body for my stock Digifant motor. Does anyone have good/bad experience they can relate about which vendor they bought from and how it's worked out? Reading websites from at least four vendors seems to show that they are all doing their own work with various styles of throttle plate material, bored housing, various coatings, bearings, shims and o-rings. Thanks.
insyncro
Banned
insyncro is offline
PostPosted: Sat Dec 20, 2014 7:33 am    Post subject: Reply with quote
I have experience with:
Van Cafe
RJE
Go Westy
And my own version after seeing all the others.
All good and done the same as I can tell.
The bore of two are larger and that means you need a larger vane and tight seal to take advantage of any performance gains Laughing
Get a VSM from whomever you choose, it helps smooth things out even more
dart330
dart330 is offline
PostPosted: Sat Dec 20, 2014 8:56 am    Post subject: Reply with quote
I have been looking into getting one of these as well as my original has over 125k miles on it. There is a very wide price range. Any reason not to go with the cheapest? I really wouldn't have expected that to be GoWesty...
GoWesty $250: http://www.gowesty.com/ec_view_details.php?id=23904&category_id=&category_parent_id=
Rocky Jennings $270: http://www.rockyjennings.com/WBX%20Vanagon.htm
Vanistan $300: http://www.vanistan.com/other_accessories.html
Van Cafe $365: http://www.van-cafe.com/home/van/page_1131_1324/rebuilt-throttle-body.html
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
AtlasShrugged
AtlasShrugged is offline
PostPosted: Sat Dec 20, 2014 9:08 am    Post subject: Reply with quote
Looks like the GoWesty has a reconditioned throttle switch included..and at a lower price. Add in the GoBucks deal and that is a good purchase
AtlasShrugged
hdenter
hdenter is offline
PostPosted: Sat Dec 20, 2014 2:39 pm    Post subject: Reply with quote
GoWesty has a steep core charge compared to VC and Rocky. Vanistan does not mention a core charge.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
AceTaylor
AceTaylor is offline
PostPosted: Sat Dec 20, 2014 5:47 pm    Post subject: Reply with quote
I bought the GoWesty rebuilt throttle body. One of the best things I ever did. Engine ran and idled like new. Prompt return on the core charge.
dart330
dart330 is offline
PostPosted: Sat Dec 20, 2014 6:30 pm    Post subject: Reply with quote
Well I just ordered one from GoWesty, don't want them to see this thread and jack the price up. I've had a bit of off idle hesitation, hopefully this will clear that up.
Love My Westy
Love My Westy is offline
PostPosted: Sat Dec 20, 2014 8:29 pm    Post subject: Reply with quote
I bought a rebuilt from Van Cafe several years ago. My mechanic told me it looked like beautiful work, and it solved my high idle problem and my van has run great ever since.
dart330
dart330 is offline
PostPosted: Mon Feb 23, 2015 7:33 am    Post subject: Reply with quote
I finally installed the GoWesty Rebuilt Throttle Body I purchased in Dec. The old one came out pretty easily and the old seal was no longer soft rubber, more of a 25 yr old hard plastic. Installing the new one required using the cruise control linkage off the old one. The TPS wiring bracket also had to be widened to accept the new plug.
Getting the new one on took some force to get the screws started as the new gasket was so much larger than the old and needed to be compressed down. Fired right up afterwards and the idle is noticeably a little lower and the pedal has much less resistance due to the smooth new spring action. No more off idle hesitation.
I definitely recommend doing this. Much easier to install than I expected and once you feel how stiff and not smooth the old throttle body bearing & spring is you really appreciate the quality of the new one.
plummerdesign
plummerdesign is offline
PostPosted: Mon Feb 23, 2015 1:06 pm    Post subject: Reply with quote
Now if there was a rebuilt throttle body for the DigiJet 1.9.....
It is old and green and it makes me grin.
1984 Westfalia 1.9
insyncro
Banned
insyncro is offline
PostPosted: Mon Feb 23, 2015 1:25 pm    Post subject: Reply with quote
I have sold complete 2.1 management that owners put on to a 1.9 just for this reason.
One of the strongest running WBX engines I have is this configuration and no BS double switches to deal with creating a funky idle.
Pascal
Pascal is offline
PostPosted: Thu Apr 30, 2015 5:42 am    Post subject: Reply with quote
Rocky Jennings rebuilds the 1.9 TB
'84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby
